Old May 30th, 2010, 12:22 PM   #1
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
Question about the washers to use when shimming the needles
Alright I have been reading about shimming the needles here all weekend, I think it will be my next DIY project along with removing the kleen system to get rid of the popping from my new MGP exhaust. My question is I have read about the washers being 3mm or #4 SAE, is this the outside diameter of them or the size of the hole the needle will go through? how big is the outside diameter of them? I have not found any photos of the washers aside from some on the needles. (anyone who could post some it would be great!!!) I just want to make sure I get the right ones the first time... I assume they will tiny little things. also is there anything else I should think of doing while I have her naked?
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old May 30th, 2010, 12:35 PM   #2
Thrak
Motorcycle(s): Lots
you're still talking about your bike, right?
Thrak is offline   Reply With Quote
Old May 30th, 2010, 12:38 PM   #3
http://www.ninjette.org/forums/showthread.php?t=11963
http://www.ninjette.org/forums/showthread.php?t=24845
3mm is the size of the hole.
No change after shimming needles with two washers jasonz1c 2008 - 2012 Ninja 250R Tech Talk 13 January 30th, 2014 08:08 AM
question about shimming those needles fizzer914 2008 - 2012 Ninja 250R Tech Talk 6 June 11th, 2012 03:12 AM
Need 3mm washers for some shimming? Come get'm Hokie11 2008 - 2012 Ninja 250R Tech Talk 16 November 30th, 2010 11:21 AM
FREE!!! 3MM Washers for Shimming Your Carb Needles kkim 2008 - 2012 Ninja 250R Tech Talk 1 September 10th, 2010 02:26 AM
Shimming the needles question Tubesock 2008 - 2012 Ninja 250R Tech Talk 20 August 15th, 2009 12:17 PM
