Old June 12th, 2011, 12:50 PM   #1
Roblas
Motorcycle(s): SV650
'86 Front End Swap?
Hey y'all. I'm new around here. I'm helping a friend completely rebuild an '86 ninjette. It wasn't terribly well cared for by the previous owner (who thought pink duct tape was sufficient for repairing wiring) and the result is a whole lot of rust, among other things.
The inner fork tubes are pretty well rusted and I'm looking for options for repairing/replacing them. Rechroming is somewhat expensive, as are new parts. One thing I'm considering is finding the front end from an '88-'07 and swapping the whole thing out. This would also fix the problem of the bent clip-on that we can't seem to find a replacement for.
Has anyone ever done this? Is it even possible? I could be wrong, but I think they may have totally different steering head bearings.
Roblas is offline   Reply With Quote
Old June 14th, 2011, 12:26 PM   #2
Jinx250
Smoker
Motorcycle(s): Guess....
IDK about hte steering head bearings, but if you swap the entire fornt end, you'll need to do the gauges too, since the speedo gear on the 86/87 was on the other side.
Jinx250 is offline   Reply With Quote
Old June 21st, 2011, 02:36 AM   #3
fjyang
fjyang's Avatar
Motorcycle(s): 87 Ninja 250, 90 Ninja ZX750R, GPZ 900r, 02 Moto Guzzi LeMans, 95 Triumph Speed Triple
The plated parts on the 86-87 250 are built to a price point, back then a new 86 250 cost $2,200. None will hold up if survive till now. Mine fork tubes were rusted and I had it hardchrome for $120 13+ years ago.
Like Bob said speedo drive location will be your issue unless you swap the whole front end. If you are going down the swaping the front end, I could skip the 88-07 250's as it still use 16" rims and find yourself a 94 or newer EX500 front end as it was updated to 17" rims already.
fjyang is offline   Reply With Quote
[motorcycle.com] - Weekend Awesome Front Wheel Swap During a Wheelie Ninjette Newsbot Motorcycling News 0 November 22nd, 2014 07:30 AM
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal 1LoneWolf Items Wanted 3 July 8th, 2013 02:50 AM
Gixxer front end swap nguyener 2008 - 2012 Ninja 250R Tech Talk 4 June 20th, 2013 01:53 PM
2011 front sprok swap eddiekay 2008 - 2012 Ninja 250R Tech Talk 2 July 12th, 2012 01:05 PM
15t front sprocket swap! play2pwn 2008 - 2012 Ninja 250R Tech Talk 3 October 17th, 2011 09:17 AM
