Go Back   ninjette.org > Marketplace > Motorcycle-related
Old August 30th, 2011, 10:20 AM   #121
headshrink
headshrink's Avatar
KC,
For the second list, are you taking customizations yet, or waiting to get list one completed first?
Old August 30th, 2011, 10:21 AM   #122
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
There is a lot of work to be done to get it into the dash. If yky have a problem cutting plastic to make room then you might as well put it somewhere else
Posted via Mobile Device
Old August 30th, 2011, 10:23 AM   #123
Kevin2109
KThanksBye
Kevin2109's Avatar
Originally Posted by headshrink View Post
I did see those.... I was just wondering what the remote LED looked like prior to installation. This is to help visualize mounting options/methods.
Well its just a couple leads of wire so it doesn't matter really what led you use. The normal led is 5v at 35ma, if you want to do what I did and add a 12v strip of LEDs you must hook up a relay and a transistor
Old August 30th, 2011, 11:06 AM   #124
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Correct I can wire any LED of 5v up to 35mah up to the gauge within seconds.
Any way you need it wired. Any shape LED within those ratings.
If you want to supply the LED because of special shape or choice, I will agree with that and supply you wires to solder your LED to.
Otherwise I just use a standard 3mm LED on some mall hookup wire.
As long as you need the wire to be.
For list two, I will take payments in full for each gauge before I begin ordering parts for them and taking customizations. I don't have capitol to keep making the gauges on front.
You guys have a bit of time to think how you want it while I get the last gauge on to Adrians bike, finish up Welcraft and Jdoucet and then write the shift program upgrade before I take payments for group two.
Seems like so much yet to do still!
I was about to go get some switches today but I got stuck mowing the entire property for weed control. haha. Yard looks nice now though. This fall I'm gonna try and plant some grass and get a new lawn going! I may head down for the switches now anyways.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old August 30th, 2011, 12:31 PM   #125
headshrink
headshrink's Avatar
In that case, I better send you some $$!
I'll PM you for details.
EDIT: Oops, I misunderstood the part about NOT taking payments yet.
Last futzed with by headshrink; August 30th, 2011 at 09:13 PM.
Old August 30th, 2011, 12:32 PM   #126
headshrink
headshrink's Avatar
Ah, I did it AGAIN! I meant LED Digit, not the regular LED light.
Old August 30th, 2011, 02:01 PM   #127
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I can make the digit on a remote ribbon cable about 12" or so max.
Same with the LED. I you want to drive something larger than an LED I can make you that circuit also for a small additional fee.
I was out today,
looks like the electornics shop is keeping stock of the switches as fast as I can buy them out which is good.
I also picked up another tiny relay like we used on Kevin's bike, some more gauge plugs and a tiny little aluminum project case that should fit my gauge just perfectly that cost me about $8.
I figure I can paint the case if I don't like the color.
LMFAO!
Weaksauce
Old August 30th, 2011, 02:03 PM   #128
Kevin2109
KThanksBye
Kevin2109's Avatar
I was out today,
Why is only that one switch $2.08? lol
----> My Youtube! <----
Old August 30th, 2011, 02:06 PM   #129
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I don't know if I could get any closer to a perfect sized case
LMFAO!
Weaksauce
Old August 30th, 2011, 02:07 PM   #130
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
It has a slightly longer lever than the others.
LMFAO!
Weaksauce
Old August 30th, 2011, 02:17 PM   #131
how much HP does it add?
also, are those switches waterproof?
Old August 30th, 2011, 02:19 PM   #132
Kevin2109
KThanksBye
Kevin2109's Avatar
Old August 30th, 2011, 04:33 PM   #133
headshrink
headshrink's Avatar
I just had an idea for future customizations.... Originally the idea of reflecting the digit off the windshield as a HUD was tossed around. Since this would show a mirrored image, programing (or wiring) the digit to read backward would be reflected as a corrected image (not sure if it would need to be upside-down too).
Old August 30th, 2011, 05:18 PM   #134
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Yeah, I can set it up inverted and flip flopped for a HUD.
I am the program creator, I can make it how you guys want it.
Kevin wants the program changed around on his bike too because he takes off in first gear without giving the gauge the proper boot up sequence lol.
Alex, part of the instructional video instructs you to put hot glue over the switches when you are done to waterproof them.
I also instruct people to remove the gauge in the rain since it has no case so the switches aren't connected in the rain anyways (hopefully). For the guys that do permanent install they need to do a bit of waterproofing with hot glue.
LMFAO!
Weaksauce
Old August 30th, 2011, 05:26 PM   #135
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Thanks for the video bro!
Gauge looks to operating flawless. Now we just need your dash parts all working again and we are set with you! Let me know when you can come by for me to rip your gauges out again.
LMFAO!
Weaksauce
Old August 30th, 2011, 06:28 PM   #136
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
1)Key3thermal
2)Swampotter
3)Bob Headshrink (remote Yellow/Amber LED, remote digit)
4)EddieNewYork
5)Ytse Frobozz
6)ichibunkid.206
7)pilotgeorge747
8)mvc2demon ?
9)ducducgooseit (remote Red LED, remote digit)
10)...............
Please update the lists accordingly:
If you want the LED on the board or extension wires (remote LED or onboard LED)
If you want the digit on the board or extension wires (remote digit or onboard digit)
Then specify LED color.
Red, Blue, Yellow, Amber, Green, White, Orange
LMFAO!
Weaksauce
Old August 30th, 2011, 09:16 PM   #137
headshrink
headshrink's Avatar
Will dirt/road-grime be a problem for the switches?
Old August 30th, 2011, 10:30 PM   #138
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Hasn't on my bike yet but I'm sure some of us get their bikes dirtier than others.
It's possible I suppose but it's never happened to me before for any reason to where dirt was any issue.
LMFAO!
Weaksauce
Old August 30th, 2011, 10:50 PM   #139
Momaru
Momaru's Avatar
I expect a quick blast o' compressed air would clear the dirt out of the switch for the most part. Or worst case, replacing the switches would be what, a $5 venture including a little for soldering supplies?
Proud member of the Blue Army
Old August 31st, 2011, 08:32 AM   #140
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I'm going to get a measurement of how far away you guys should place the switches from the shift clamp for optimal use. You basically place them somewhat far away and bend the tabs on the switches outward a bit until you get the switches sensing in the gauge. The clamp has to be pointing int he right direction too.
If you mount them too close it looks like they can be destroyed and false sense opposite shifts.
I took some video on this but I think I want to take a better video soon.
It's not so professional.
LMFAO!
Weaksauce
Old August 31st, 2011, 05:08 PM   #141
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Check this one out.
I finished another gauge ready to sell. Anyone from group one want this gauge?
Welcraft? Adrain? If not, somebody from list two can buy it.
It's inside a housing! =)
I need to ask a bit extra for the extra work I put into this one and extra parts.
LMFAO!
Weaksauce
Old August 31st, 2011, 05:42 PM   #142
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
1)Key3thermal
2)Swampotter
4)EddieNewYork
5)Ytse Frobozz
6)ichibunkid.206
7)pilotgeorge747
8)mvc2demon ?
10)EsrTek (remote red digit to go by fuel gauge) no need for the shift light if okay.
Old August 31st, 2011, 05:45 PM   #143
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
If you guys want to send me your gauges I can do the install for you for a small fee. You will still have to install the switches though.
Nice to see group two filled up.
I'll PM everyone when I am ready and finished with group one.
I still have to finish up two people and tweak Honey Badger's rig a bit more.
LMFAO!
Weaksauce
Old August 31st, 2011, 05:57 PM   #144
ungluck
sleeper
ungluck's Avatar
Motorcycle(s): '10 250r, '10 690 duke
how much for one remote(both) with a blue LED indicator?? i would assume this would now come in a housing? perhaps i am confusing myself.eitherway, i'm in hawaii so we get rained on sporatically throughout the day somewhere,sometime lol.
SauSponte
ungluck is offline   Reply With Quote
Old August 31st, 2011, 06:04 PM   #145
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
If you go remote LED and remote digit you won't need a case..
I'd assume you will be mounting it behind the dash for installing the digit in the gauges?
A housing is more for an all in one unit for grab and go when needed.
The remote stuff is more for permanent mounting to get the digit where you need it while keeping the circuit board out in the air to stay cool.
No case they cost $75. With a case I am going to ask $95, as I have to hand cut all the holes and the case is about $8 extra for me to buy. If you really want, I can make yours remote with a case but I wouldn't see the purpose. It seems like either or would benefit from it's own way.
I would have to put you on group #3!
LMFAO!
Weaksauce
Old August 31st, 2011, 06:08 PM   #146
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Group 2:
1)Key3thermal (?,?)
2)Swampotter (?,?)
4)EddieNewYork (?,?)
5)Ytse Frobozz (?,?)
6)ichibunkid.206 (?,?)
7)pilotgeorge747 (?,?)
8)mvc2demon ? (?,?)
10)EsrTek (remote red digit to go by fuel gauge, no shift light)
Group 3! (Sign up below, as long as you guys want them I will make them!)
1)???????????????
2)
3)
4)
5)
6)
7)
8)
9)
10)
LMFAO!
Weaksauce
Old August 31st, 2011, 06:12 PM   #147
wellcraft
wellcraft's Avatar
Motorcycle(s): Ninja 250R
How much for that one with the case?
If you like pm me.
wellcraft is offline   Reply With Quote
Old August 31st, 2011, 06:28 PM   #148
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
You still receive group one no profit gauge price.
I'm asking $60 from you for a gauge with no case.
Add a case and that's $8 and then I added hardware and a day or work to get it into the case.
For you with group one price and a case I am asking $80 shipped to be fair to me for the work I put into it! It took me two full days assembly time!
For group two or three, a cased gauge is $95 shipped.
Remember, there is others out there on the market like mine, but nobody is promising a shift light upgrade in the near future! I can provide you guys with close customer support as well. No other gauge has a switch bracket made just for our ninjette like this.
My only issue is you guys remove the gauges in the rain if they aren't installed inside your stock dash. That's why they include a big plug and velcro mounts.
LMFAO!
Weaksauce
Old August 31st, 2011, 06:40 PM   #149
headshrink
headshrink's Avatar
When we are talking about LED colors, I'm assuming we are only talking about the shift light, and the Digits all come in red... is that right?
Old August 31st, 2011, 06:47 PM   #150
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Correct this particular digit I can only get red and green.
I would assume the other colors aren't so bright. I think they have yellow and orange too.
I went with this digit because I know it will be easy to source for a long time to come. I can get them many places.
I'm already out of processors again.
It's just about time to finish group one and start the shift light programming fasting. lol
This is really cool to see something I made working out for you guys. When the shift light addition is done you all will thank me. It's totally gonna happen.
LMFAO!
Weaksauce
Old August 31st, 2011, 07:16 PM   #151
pilotgeorge747
pilotgeorge747's Avatar
Motorcycle(s): 08 Ninja 250r 03 Yamaha R6 (Project bike)
I'm still undecided if I am going to go with the remote gauge or not. However I was wondering if it would be possible to put the digit in the stock Tach housing instead of the fuel gauge housing? I personally think it would be a little easier when glancing down at the RPMs to also see the gear your in instead of having to switch between Tach and Fuel gauge.
pilotgeorge747 is offline   Reply With Quote
Old August 31st, 2011, 07:49 PM   #152
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
To be honest,
I'm not certain!
That is a good question
I'm sure it's probably possible to shoehorn it in there somewhere.
On a side note,
just did some stand up wheelie testing with the gauge in the case.
Seems to be working ok! No problems to report.
It doesn't get too hot because there is a heatsink inside and the whole thing is bolted t tohe metal case. Seems to work good!
Couple fun slow stand up wheelies outside the house feels pretty good too hehe. The ninjette does them rather well once you get it down.
LMFAO!
Weaksauce
Old August 31st, 2011, 08:17 PM   #153
headshrink
headshrink's Avatar
That's cool. I was just clarifying incase there was confussion between LED color and Digi. I actually wanted the digi in red,
Old September 1st, 2011, 03:03 PM   #154
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Anyone want to take the one in the case?
It's ready to go! Tested it again through idyllwild today nice long twisty ride. Gauge was workin' fine!
LMFAO!
Weaksauce
Old September 1st, 2011, 05:48 PM   #155
pilotgeorge747
How much for the one in the case? I may be interested.
Old September 1st, 2011, 10:28 PM   #156
Momaru
Momaru's Avatar
Indicator showed up today. For about 5 seconds I was confused, wondering "Why did I get a miniature helicopter?"
Gonna need at least some clues on the wiring (or just tell me to read the bloody thread again, I'm tired). I'm fairly sure I can figure it out but it's faster, and safer for the hardware, for me to just ask.
EDIT: Found it earlier in the thread (post 71). See? I can read!
Will probably start on the install this weekend with it as-is to do an ops check. Then I'll worry about getting it all tucked in, etc.
Last futzed with by Momaru; September 1st, 2011 at 10:49 PM. Reason: I'm silly
Old September 2nd, 2011, 05:49 AM   #157
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Cool.
I used to be sponsored for flying those type of helicopters. lol
I notice if you are going to tap into the stock cluster, the red and blue wire going to either end of the cluster's "backlight" bulbs is good for taping switchable power.
This would be the orange wire and yours might have a fuse on it in yellow also.
The motorcycle frame is grounded.. connect the black wire to ground.
Brown is the neutral sensor input wire.
I taped it down near the neutral sensor on my bike and had no problems. Ran the wire along with the switch wires to the gauge.
Yellow and green are the switch input up/down sensor wires.
I will get a measurement on the distance from the clamp to the switches today and also a photograph of what angle the shift clamp should be installed at.
LMFAO!
Weaksauce
Old September 2nd, 2011, 05:51 AM   #158
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
PM sent.
The gauges are starting to add up in cost for me with a case on them and all the hours of work. But they will be the only gear indicating gauge with an adjustable shift light on them after the upgrade, which will be free a month or two down the road.
Group two will have this automatically included. Group one will have to be upgraded later as I haven't written the code for the upgrade yet. But they can install the gauge and get the taste for gear indication for the time being.
There will also be a very minor programming bug fix that Honey Badger pointed out and I'm going to add some more hidden features I will describe later.
LMFAO!
Weaksauce
Old September 2nd, 2011, 06:44 AM   #159
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
Motorcycle(s): Blue 2009 250r Kawasaki Ninja
Group 2:
1)Key3thermal (?,?)
2)Swampotter (?,?)
8)mvc2demon ? (?,?)
Group 3:
1)AeroXtasy (Can I get a blue LED + shift light?
2)
3)
4)
5)
6)
7)
8)
9)
10)
Four wheels move the body. Two wheels move the soul.
AeroXtasy is offline   Reply With Quote
Old September 2nd, 2011, 09:43 AM   #160
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I still have a gauge from group one left to sell but nobody wants it?
Anyone in group two want the gauge in a case? lol
LMFAO!
Weaksauce
Anyone use a gear indicator? Ducati999 General Motorcycling Discussion 34 March 15th, 2014 09:12 PM
Shift Light, Gear Indicator, Temp Gauge - WHERE ARE YOU???!!! 2013 kawi girl 2013 - 2017 Ninja 300 General Discussion 14 October 21st, 2012 12:00 AM
Gauging Interest: Gear Indicators (one with shift light, one without shiftlight) SlowBoyRacing Motorcycle-related 13 March 2nd, 2012 11:27 PM
WTB: Rear OEM 2008+ Ninja250 Tail Light/Brake Light FerociousNINJA Items Wanted 5 March 29th, 2010 08:52 AM
