Old July 21st, 2009, 07:16 PM   #41
zartan
zartan's Avatar
Motorcycle(s): 08 250 R
I just had my kickstand shortened about an 1" 20 bucks at the welding shop. I could not handle the RT blingy one. Some like it but I don't ...
"Don't let adverse facts stand in the way of a good decision" Colin Powell
zartan is offline   Reply With Quote
Old July 21st, 2009, 07:22 PM   #42
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
They didn't have the regular black one so they gave me the chrome for the same price. I love chrome and i can tell my bike apart from the others especially now with all the new scratches i got on sunday night. I don't have much confidence in welders even though i know they say they guarantee their work.
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old August 1st, 2009, 12:56 AM   #43
Finder
Motorcycle(s): F650GS Dakar, FJR1300, Ninja 250R
Regarding these riser/lowering blocks, can they be installed without raising the fork tubes and not negatively affect the strength of the bars? I'd like to raise the height of the bars a bit but not lower the front end. These seem like a pretty cheap solution.
Cheers!
Finder is offline   Reply With Quote
Old August 1st, 2009, 01:17 AM   #44
shouldn't be a problem.
Old August 5th, 2009, 11:49 PM   #45
im_a_ninja
im_a_ninja's Avatar
zartan.....did you also post the pics for the rear links?
I had mine lowered with the roaring toys links and it looks WAY low.
In some picures I saw on he wiki article that I think you posted the pic shows the link in the position where there are 3 other holes below the one being used. One is to the left, center and right. My bike is on the center setting...do you know how low that makes it? Does that seem safe?
Just to clarify....in the pics shown, my bike is in the hole directly below the one used in those pics.
im_a_ninja is offline   Reply With Quote
Old August 6th, 2009, 05:09 AM   #46
JaeL
Bike Thrasher
JaeL's Avatar
Motorcycle(s): 2008 EX250r
I feel like this post is missing something....
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns
JaeL is offline   Reply With Quote
Old August 6th, 2009, 08:55 AM   #47
im_a_ninja
im_a_ninja's Avatar
someone posted a DIY for lowering their ninja with a roaring toyz lowering links that I used too. In their pics they used a different hole on the adjustable links so I was trying to figure out, in comparison to the one in the pics posted, how much lower is my bike.
Im asking bc my bike looks too low...like it's cant even take a turn and I am wondering if maybe they used the wrong hole on the links.
Here, I edited the picture that was posted in the DIY...the DIY is the blue arrow and the box that says "my bike" indicates which hole is being used on mine.
The guy at the shop said that my rear needed to be lowered 1.5 inches but it look lower than that. I'm just trying to figure out which hole lowers the bike what amount.
Old August 6th, 2009, 05:06 PM   #48
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
that's my bike there My understanding is that the top row would give you the stock position, one inch, and two inches, and that he bottom row would give you a half inch and one and a half inches
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 6th, 2009, 06:11 PM   #49
im_a_ninja
im_a_ninja's Avatar
sooo
You would guess that mine is 1.5 inches in that hole I circled then?
Maybe..
Im going to compare stock seat height to current seat height tomorrow.
Thanks!
Did you do the handlebar blocks too?
Old August 6th, 2009, 06:22 PM   #50
noche_caliente
I did - the only thing I didn't do was the kickstand...
As for height, I would actually think your's is only at .5", as it is still towards where the links are the longest... the shorter end would be the other one, as it is making the link shorter... but it was totally a guess for me as to where it went - we tried to do it with math, and that seemed to get it to the right place. As I'm sure you saw, RT had virtually NO documentation with the kit
Old August 6th, 2009, 07:52 PM   #51
im_a_ninja
im_a_ninja's Avatar
I like your theory....but it can't be right. :P
My bike is in that hole I indicated and it is SO low to the ground that if you went lower it scrubbed the tire in the fender.
Did you see a pic of my bike post lowering?
I'll add it again just in case you didn't. We discussed in a different forum that it may look a little lower since it's tied down....but it is still low.
Old August 7th, 2009, 12:28 AM   #52
zartan
zartan's Avatar
I did not use a RT kit. My tuner used a dogbone from another model. It was before the kit came out. I got the bike early on. They modified one to work.
I just got the kick stand shortened a couple of weeks ago. It needed it.Glad I finally got it done.
Old August 16th, 2009, 08:14 PM   #53
JaeL
Bike Thrasher
JaeL's Avatar
thanx for the diy! finally got my front end lowered in prep for the clips on wed....?
Old August 16th, 2009, 08:39 PM   #54
im_a_ninja
im_a_ninja's Avatar
ok, so I measured my bike and it is lowered nearly 3 inches! what!?!?
yeah! so, needless to say, it IS low.
I rode 100 miles today by myself out and about in town. Hit a little rain and some curves...no issue with anything that I can tell. I definitely want to raise it up some. But, I like being completely flat footed. I'll get comfy for a bit and raise it up.
Old August 16th, 2009, 08:56 PM   #55
The bad thing is if the rear is lowered 3 inches, the front can only be lowered 1.5 inches w/ blocks. That means your steering geometry has changed and most likely are having a hard time turning in parking lots and through fast corners the the bike will be more apt to fight you when doing quick maneuvers. Not the best combo for someone learning to ride, in my book.
Old August 16th, 2009, 09:21 PM   #56
im_a_ninja
im_a_ninja's Avatar
i completely agree...which is why I TRIED to get it lowered 1.5 inches in the rear.
It's just a major pain in the butt to get it back to the shop.
The borrowed trailer has been reclaimed and the shop is 45 minutes away, on the 4 lane highway and I'm afraid to take the highway right now.
ugh!
I live in rural ga and so far I've taken a ton of curves cruising around town. Usually at 55-65 mph and for a first time rider, that seems fast around a curve. lol
I agree that tight turns in a parking lot or something might be an issue.....but I havent run across it yet.
Wind seems to be the biggest issue ive had in general.
Old August 16th, 2009, 09:55 PM   #57
Can you post a picture of your linkage? Perhaps we can help you figure out what hole it needs to be moved to to balance it out at home.
Old September 19th, 2009, 09:02 PM   #58
subiegy2010
noob in training
Motorcycle(s): '08 Ninja 250R (sold) '05 SV650S
Do you guys think lowering the back 2" is safe? I'm worried that it will rub and expose some wires like somebody else's bike on here. I have a 26" inseam and measured 3" from my heal to the ground with the bike between my legs so I'd like to lower it as much as possible without encountering problems.
Sounds like lowering 3" is a bit much so 2" might be the next best thing. On the other hand, maybe I should only lower the back 1.5" to match the lowered front and retain the stock steering.
subiegy2010 is offline   Reply With Quote
Old September 19th, 2009, 09:30 PM   #59
I'd recommend 1.5" in both the front and back, max.
what's your inseam measurement?
Old September 19th, 2009, 09:56 PM   #60
subiegy2010
noob in training
It's actually about 26.5-27", not 26" as previously mentioned.
Old September 19th, 2009, 10:03 PM   #61
My inseam is 28-29 and I don't have my bike lowered. I can barely touch the ground tippy toes, but have learned to angle the bike when at a stop. If the angle is not that severe, you can support it without problems if you plan ahead for your stops. You don't need to have both feet, flat on the ground.
I think with your inseam, you should try the 1.5" on both ends and see how you like it first. If you need it lowered more, consider cutting your seat foam down for a bit more lowering.
Old September 19th, 2009, 10:17 PM   #62
subiegy2010
noob in training
This is my first bike and I've never ridden before so I feel like if I can flatfoot it (or come close), it will be much easier for me to learn. As the bike stands right now, I'm not very confident on it to say the least. On my first ride, it stalled going up a tiny incline, which was my fault because I didn't know I had to warm it up for so long, and I ended up dropping it. If it was lower I would've been able to put my feet down and prevent the whole situation.
Old September 20th, 2009, 12:48 AM   #63
very few people can flat foot on a sports bike. To want/need to flat foot with both feet would be unrealistic. I understand your dropping the bike due to it being too high for you. I'm saying it doesn't need to be as low as you're looking to go to be comfortable with it.
Lower it in stages and find a happy medium.
Old September 20th, 2009, 07:52 AM   #64
SROL
SROL's Avatar
i had my bike lowered and they accidentally lowered it 3 inches. I havent raised it back up yet bc I like the way it feels. Although, I will say that it DOES NOT take turns from a stop....say at a four way, turning left or right, like I think it should. It just cant do it bc the stock steering is messed up. But, there are no wired even close to touching anything else. I read that somewhere too and double/triple checked. I can't even see which wires they could be talking about.
I dont recommend lowering it 3 inches, but if you feel more comfortable with it being 2 then do it 2....you can always raise it back up. I have the roaring toyz lowering links that have 5 height options in one link.
I say this as a novice rider...but integrity of factory steering versus temporary safety until you get comfortable seems like a no-brainer to me. As long as you are learning your bike and how it handles. I mean, if you didn't know how it handled before and you lower it and learn the bike that way. I dont see how it can be dangerous. Just learn your limits and your bikes limits. But, I felt better touching the ground when I was learning. Now I would jump on a cbr or something without lowering it much quicker bc Im more comfortable on a bike in general.
Good luck
shannon
SROL is offline   Reply With Quote
Old September 20th, 2009, 07:53 AM   #65
SROL
SROL's Avatar
I just realized that I posted this under the boys user name.......he was already logged in. Sorry! my user name is really im_a_ninja
shannon : )
Old September 20th, 2009, 08:53 AM   #66
subiegy2010
noob in training
I think I will try 1.5" first and if I feel that that isn't enough, I will go down to 2".
Old September 20th, 2009, 09:14 PM   #67
subiegy2010
noob in training
What cables should I be worried about rubbing against after the bike is lowered?
Old September 20th, 2009, 09:39 PM   #68
If you lower the bike too much in the rear, it the rear tire can eat through the plastic under fender liner and eat the cables that run through right above it. One of those cables is is one which can disable the bike. It's happened to others which is why I recommend lowering it only as much as really needed. Nothing is a free lunch and some actions can have disabling results.
Old September 20th, 2009, 10:12 PM   #69
zartan
zartan's Avatar
Yep I wish I didn't have to lower. I have to pay attention to so much.
Speed bumps. Can't keep my spools on ( will hit the pipe) have to remove them when done working on the bike. Now I just got that Framm aftermarket horn and it is bigger than stock so it hits the back of the front fender. I am going to have to make a bracket for it. Would be so much easier if I could have left it stock.
Old September 28th, 2009, 12:49 PM   #70
subiegy2010
noob in training
So on the rear links, which hole is 1.5" and which one is 2"?
Old September 28th, 2009, 02:26 PM   #71
Old July 24th, 2010, 12:05 AM   #72
BIGT94z
Motorcycle(s): 2008 ninja 250r
i cant get my front brake grommet to move up to the new holding clips location. how hard did u mess with yours? im thinking of just ziptieing it due to the fact it doesn't have that much slack anyway
BIGT94z is offline   Reply With Quote
Old July 24th, 2010, 12:10 AM   #73
what front brake grommet? I don't remember having to fool w/ anything like that.
Old July 24th, 2010, 12:32 AM   #74
BIGT94z
take from the tutorial:
Ok now I did have problems with my Brake hose being too tight. So I removed the line from its holding bracket. The grommet had to be moved down a bit and then the hose reattached to the holding bracket.
mine was to short so i had to take it off its holder too but cant adjust it back to its new holder location
Old July 24th, 2010, 12:41 AM   #75
ah, okay... you might want to PM Zartan. When I did mine I didn't have to move that.
Old April 7th, 2011, 01:15 PM   #76
EddieNewYork
"Hey, That's My Bike"
EddieNewYork's Avatar
Motorcycle(s): 88 Honda ZB50, 01 Honda Monkey, 07 CRF50, Honda CBR 600RR Phoenix Edition
Question... is a front stand needed to raise the front end and does it require 2 people?
EddieNewYork is offline   Reply With Quote
Old April 7th, 2011, 01:43 PM   #77
JaeL
Bike Thrasher
JaeL's Avatar
No and no. But having a extra hand is always useful.
Old April 7th, 2011, 02:02 PM   #78
EddieNewYork
Thx JaeL, I've worked on smaller bikes but not a full size like this so I was concerned with the weight. So if I loosen the triples, will it be very heavy for a person to lift the triples back up, will it fall and hit the front fender if I'm careful and loosen it too much?
Old April 7th, 2011, 02:08 PM   #79
JaeL
Bike Thrasher
JaeL's Avatar
Oh yes go very slow so it doesn't drop! But I did single handedly lifted one side back up to make them even...
Old April 7th, 2011, 03:08 PM   #80
EddieNewYork
Ok, cool thx.
Clipons for lowering front forks instead of risers gptoyz 2013 - 2017 Ninja 300 Tech Talk 19 August 7th, 2014 05:44 PM
Raising the bike, removing lowering links! [HELP] Diegone 2008 - 2012 Ninja 250R Tech Talk 3 May 8th, 2014 07:59 PM
Lowering Front-end question Justanothermp5 2008 - 2012 Ninja 250R Tech Talk 4 September 27th, 2010 02:59 PM
DIY: Lowering the back with Roaring Toyz lowering links noche_caliente 2008 - 2012 Ninja 250R Tech Talk 49 July 26th, 2010 12:22 PM
Front end lowering kit for sale?? stealth250 2008 - 2012 Ninja 250R Tech Talk 6 June 21st, 2009 07:44 PM
