Old October 7th, 2014, 12:01 PM   #1
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
Gixxer rear shock question - rear stiffness too high
I installed a gixxer rear shock on my 2008 250. The shock was off a 2008 750 and the rider was about 210 lbs. I used the stock 250 swingarm and linkages, but I had to get all new bolts and some spacers. I also had to grind the clevis of the shock to accept the 250 linkage. I've checked everything over a couple times and I can't find anything obvious that is binding. The rear of the bike feels almost solid - as in I'm not getting the linkage to travel. It seems as if the shock is stiffer than the subframe and the swingarm. When I push on the rear end, I feel like the movement I'm getting is the subframe and swingarm flexing instead of the shock compressing, but I honestly can't tell if that's what is happening or if it's in my head. My guess is that the settings on the shock are set pretty heavy and I need to lighten them up a bit. I don't have everything back on the bike yet and I'm wondering if the chassis is too light.
Has anyone else had this issue? When you installed the gixxer shock, did the swingarm still have a lot of travel or did the rear seem almost solid?
cookiebug79 is offline   Reply With Quote
Old October 7th, 2014, 12:05 PM   #2
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
it does sound like something is binding, can you get something under the bike or footpegs and check for droop from the swingarm? Bike should have relatively normal suspension travel with the shock swap. Something is wrong.
Old October 7th, 2014, 12:12 PM   #3
cookiebug79
n00b with the b00bs
The bike, while farther along than this pic, is actually suspended from the rafters. When I put the rear stand under the swingarm, it just raises the subframe/whole bike. So that's why I'm wondering if it's normal for the gixxer shock to be so stiff that the weight of the 250 doesn't compress it at all, if the compression/rebound setting is just really far off on the shock, or if I need to find a detail of something that is binding and isn't entirely obvious.
Old October 7th, 2014, 12:17 PM   #4
sharky nrk
sharky nrk's Avatar
It may not settle much with just the weight of the bike on it if the preload is jacked way up and or compression adjusters. Take all the preload off the rear spring and back the clickers all the way back (count the turns just in case and write them down) and sit on it. Bike should squat enough for you to notice.
Old October 7th, 2014, 12:50 PM   #5
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ this
back the preload way out first.
If you don't notice it getting any easier to compress make sure the spring is clearing the inside of the swing arm and not binding up
Also check that you have movement in the linkage and nothing is binding up there.
The gsxr shock is pretty stiff with the OEM spring. I wasn't crazy about it.
Old October 7th, 2014, 01:04 PM   #6
cookiebug79
n00b with the b00bs
Interesting. I will try this tonight and report back. Thanks!
Old October 7th, 2014, 01:04 PM   #7
I believe the 08 600 and 750 share the same rear spring. Lemme know and I will go out and take my settings and post them for you. Can do pics if ya need.
People do silly stuff to suspension because it's like some voodoo black art.
Old October 7th, 2014, 01:09 PM   #8
cookiebug79
n00b with the b00bs
LOL I love the pic!
Yeah, they should be the same spring. The guy I bought the shock from had dynoed it, so I'm betting he left it on the last setting he dynoed, which would be all the way turned in on both high speed and rebound.
I would LOVE any pictures or settings that you could share. I'm building this bike from the frame up and it wasn't completely assembled when I got it. While I'm pretty sure I'm doing it right, I'd love to confirm what I'm doing!
Old October 7th, 2014, 01:26 PM   #9
K, will get you some settings #'s and pics when I get a chance. Give me a bit and I will hook you up. Turned it up all the way, on any setting would pretty much a no go when putting a gsxr shock on a 250. lol
Old October 9th, 2014, 03:36 PM   #10
cookiebug79
n00b with the b00bs
I checked the shock and both knobs were turned all the way to the right and there was a bunch of pre-load on the spring. No wonder! Thanks for pointing me in the right direction.
I took out all of the preload and turned the clickers all the way to the left and now the rear end moves. Hooray! Now for the tuning. I changed the fork oil before I re-installed the forks, so this weekend I'll try to get it all in a happy place a the track. But any advice on initial settings would be greatly appreciated! I'm also bringing the stock shock with me just in case.
Old October 9th, 2014, 03:41 PM   #11
Oh snap! I didn't forget but I still need to share my baseline with ya.
Old October 9th, 2014, 03:44 PM   #12
dont forget to spring up the front after doing the rear or you'll be sliding the front all over the place
Old October 9th, 2014, 03:45 PM   #13
cookiebug79
n00b with the b00bs
Alex, can you explain a little more what you mean by that? Thanks!
Old October 9th, 2014, 03:51 PM   #14
if the rear is oversprung compared to the front, the front will move a lot more from cornering forces and will throw the bike geometry all out of wack and makes it really easy to bottom out the front and start pushing out
Old October 9th, 2014, 03:57 PM   #15
cookiebug79
n00b with the b00bs
Thanks for the clarity!
Stiffer springs are on the list of things to accumulate. I also have emulators but they are not installed. I did swap the oil to 15 wt instead of 10 wt. This thing is gonna be a hoot to figure out!
Old October 22nd, 2014, 01:09 PM   #16
Here is my settings on my gsxr rear shock. They are still not perfect, and I am currently tweaking rebound.
Preload - 3 threads above the collar
Low Speed Damping - 1 turn
Hi Speed Damping - 3 turns
Rebound - 1 turn
These will not be your setting as our riding styles could vary quite a bit. Also, I brake super hard and late, so my rebound is set pretty open compared to normal as I work my issue.
Oh, this has the stock spring still on it.
Old October 22nd, 2014, 01:15 PM   #17
Bike suspension itself is not really all that hard. The hard part is trying to figure out what the rider means when he/she talks to you about how the bike feels and make the changes that will give them the end result they are after. It's an exercise in communication and interpretation skillz.
These two videos helped me when I first started getting into suspension.
Old January 17th, 2015, 12:07 AM   #18
spent_too_much
spent_too_much's Avatar
Excellent instructional videos!
Old January 17th, 2015, 04:16 AM   #19
green_bread
green_bread's Avatar
Motorcycle(s): Ninja 250R & CBR250R
Commenting a a bookmark for later. Thanks @csmith12
green_bread is offline   Reply With Quote
Old January 17th, 2015, 05:28 AM   #20
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Rebound - 1 turn
For "damping" you mean "compression," right? Rebound is also damping.
And are those turns in from full soft or turns out from full stiff?
Old January 17th, 2015, 08:19 AM   #21
Yep, that is what I mean. Pardon my paddock slang there, and sorry for not being clear. In the suspension world, it is assumed that the adjusters are turning all the way in to full stiff and the turns are full turns "out".
Don't use these settings on your gixxer, they are most likely not even close to what you would need or what.
Rear shock question LoneRonin 2008 - 2012 Ninja 250R Tech Talk 5 September 22nd, 2014 03:09 PM
Rear shock set to high (rear wheel slipping)? passive101 2008 - 2012 Ninja 250R Tech Talk 6 August 10th, 2014 08:45 PM
rear shock question ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2010 05:43 AM
Quick rear shock question demp 2008 - 2012 Ninja 250R Tech Talk 6 May 11th, 2010 12:14 PM
ZX600 Rear Shock Question krbreton 1986 - 2007 Ninja 250R Tech Talk 4 June 15th, 2009 11:31 AM
