Old July 18th, 2019, 09:31 PM   #1
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Using Wide Scissor Lift Stand?
I've just bought a scissor lift that I wanted to experiment with, but I can't find a good point to put the scissor lift under that allows me to lift the bike up while being balanced. Any tips with using these scissor Motorcycle lifts?
https://ibb.co/qrFV671
Old July 19th, 2019, 06:31 AM   #2
That might be a tough one.
Those are great for frames with double down-tubes where the engine sump doesn't drop below the frame - like most Big Twins.
With the Ninja's frame type (lack of lower frame) and pipe/sump design you may have a tough time getting a flat surface to lift from.
You may be able to make some type of plate out of wood that could get you a flat surface to lift from, but be careful. With that in-place it would be hard to change the oil.
A rear stand would be handier I would think. A front wheel chock is also super handy to keep the cycle stable when using other stands.
Old July 19th, 2019, 10:08 AM   #3
Yikes! Those scare me!!! Too easy for bike to topple off. I’d much prefer to hang a bike, then it can’t fall because it’s at lowest point already.
Old July 19th, 2019, 10:28 AM   #4
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Haven't lifted a Ninja with a flat lift. The guys have lifted their dirtbikes with one, but for the Ninja and his Triumph we use this one:
https://abbastandsusa.com/product-de...ky-lift&pid=44 h
Pins go in the swing-arm pivot point.
Old July 19th, 2019, 11:43 AM   #5
ducatiman
ducatiman's Avatar
That flat type of lift would require you to become inventive in effectively creating some sort of "cradle" to safely secure and balance the bike package. Specially crafted for the particular bike you are working on. Short of that, I'd be quite concerned with stability and toppling.
A rear paddock stand and a lower triple, pin type front stand have had a Triumph 675 lifted up in my garage a couple months now....quite steady and secure. Affordable, these are more generic stands and can be (and have been) used on many different bikes, certainly not limited to 1.
I seem to remember a recent thread on front and rear stands ...was it here or another forum?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; July 20th, 2019 at 08:34 AM.
Old July 19th, 2019, 02:17 PM   #6
Yup, I've done as Jay's suggested. Take piece of wood and cut out holes for oil-filter and oil-drain bolts. Then shape wood to extend and touch across swing-arm pivot. Then use scissor-jack with centre below somewhere between oil-filter and swing-arm pivot so bike is balanced on top. Even then, it's still tipsy top-heavy and scary.
Physics dictates that 3 contact points are most stable. Three-legged tables are more stable than 4 and can sit on uneven surfaces.
Lifting bike by 3 points, such as rear swingarm stand along with stem lift in front is most stable. Or I like hanging front end from ceiling rafters.
Old July 25th, 2019, 01:50 AM   #7
nocturncal
nocturncal's Avatar
Awesome thanks for the advice. Sounds like making a wood plate is the best way to go.
I've got front and rear stands so it may be a while before I try to take a plate. I swear my little garage in San Francisco is running it of room from all the garage farkles I've been getting, wrenching is addictive!
Old July 25th, 2019, 08:47 PM   #8
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike
Man are you actually paying the full $700 for that lift on a 88-07 250?
Racer, Mechanic, Enthusiast. Vendor for Norton Motorsports
Subscribe to my Instagram and YouTube: Instagram
YouTube
NinjaBraap is offline   Reply With Quote
Old July 26th, 2019, 09:30 AM   #9
CaliGrrl
CaliGrrl's Avatar
Husband bought it to lift his Triumph, actually. But it works for the Ninjette, too.
Old July 26th, 2019, 03:58 PM   #10
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Ah gotcha. Surprised it worked on the Ninja, usually those style lifts require specific adapters for the bike it's lifting. I bought a cheaper version for my ZX6, but they don't even make the pin for my year, so I'm having it fabbed.
YouTube
E4S SMI2092R Paddock Stand (Frame Center Lift Stand) NinjaBraap General Motorcycling Discussion 1 January 22nd, 2019 08:49 PM
why use bike lift stand? maxwellca21 General Motorcycling Discussion 18 November 12th, 2010 12:10 AM
