Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 Tech Talk
Old September 18th, 2020, 03:04 PM   #1
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Cylinder coolant seal issues
Another issue seems to be getting more common on the 400s. The rubber seal for the coolant passage between the crankcase and the cylinder jug can deform, causing a small coolant leak on the front of the engine.
It's not a huge catastrophic failure, but it's labor-intensive to replace. Some people have reported their dealerships getting Kawasaki to cover the repair even after the warranty has ended.
Once again, Jesse to the rescue with the Norton Racing Replacement Cylinder Coolant Seal. Rather than just being a rubber O-ring, it's a machined aluminum body with captive O-rings on top and bottom, to provide seals on both surfaces without any deforming worries.
This isn't really something you'd replace preventatively on a street bike (due to the labor involved for a problem you might never run into), but you may want to on a race bike where you can't accept failure and/or are already doing engine work. If you've run into this problem and are repairing it, you should definitely look into this upgrade. The OEM part (92055-0888) is only about $4 vs. $40 for the Norton part, but $36 is going to be a drop in the bucket of the overall cost of this repair, especially if you have to do it a second time due to another failed OEM O-ring later on.
Old October 16th, 2020, 02:39 PM   #2
Sounds like a reasonable solution!
Old August 12th, 2021, 02:49 PM   #3
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike
Thanks for the write up!
Racer, Mechanic, Enthusiast. Vendor for Norton Motorsports
Subscribe to my Instagram and YouTube: Instagram
YouTube
NinjaBraap is offline   Reply With Quote
Oil seal and dust seal front bars Darksik 2008 - 2012 Ninja 250R Tech Talk 3 March 13th, 2019 06:03 AM
Possible Coolant Issues and Overheating on an Ex-Ninjette Bike Noobman The Ex-Ninjetters Lair 9 July 26th, 2017 08:09 AM
OEM Brand New Fork Oil Seal, Dust Seal (08-12) capriccio Motorcycle-related 3 June 9th, 2013 05:11 AM
Fork Seal Leaking broken neck 2008 - 2012 Ninja 250R Tech Talk 16 June 2nd, 2013 11:40 AM
front brake issues. master cylinder? Solunatic 1986 - 2007 Ninja 250R Tech Talk 13 June 25th, 2012 11:34 AM
