Old January 3rd, 2011, 07:46 AM   #1
gamma500
gamma500's Avatar
Synch. carb setup hint
Last year I added a T fitting to the 2 vacuum lines that run from the carbs to the fuel switch, et. al. and capped off the open ports which were to attach to my synch guage when needed with rubber vacuum capoffs from AutoAdvance. A few months latter, hard starting got me checking things and found these caps had split..replaced them and same thing happened once more. Apparently there is enough gas fumes in these lines to deteriorate the Buna rubber. Made a set of cap offs from 1/8" ID fuel rubber line lengths and blocked the ends with RTV/plastic plugs and should prevent this from reoccurring.
gamma500 is offline   Reply With Quote
Old January 3rd, 2011, 08:20 AM   #2
dubojr1
dubojr1's Avatar
I've noticed mine have also started to dry rot. Guess I'll know the first thing to check if I have any future "start" or "run" issues. Thanks for the heads up.
Old January 3rd, 2011, 01:11 PM   #3
zdoc
Motorcycle(s): 09 ninja 250r
Im assuming thats the 3/16 vacuum caps? Im about to do mine this weekend so maybe i will just go with fuel line instead.
zdoc is offline   Reply With Quote
Old January 3rd, 2011, 01:19 PM   #4
Craig,
thanks for the heads up.
Old January 4th, 2011, 07:13 AM   #5
gamma500
gamma500's Avatar
Afraid I eyeballed what size since i had an assortment of T-fittings and vacuum caps..did end up using the 1/8" ID fuel line though. Just out of curiousity, would it make any difference if I connected the 2 T-fitting open ports designated for sync. use together with a length of fuel line instead of capping them off separately ?
Old January 4th, 2011, 12:35 PM   #6
you mean like looping the ports together using a length of hose??? if so, that would work.
Old January 4th, 2011, 02:39 PM   #7
gamma500
gamma500's Avatar
Yes, I was thinking that would work just as well as individually capping off the ports.
Old January 8th, 2011, 01:41 PM   #8
headshrink
headshrink's Avatar
Brilliant!
Old January 12th, 2011, 01:22 PM   #9
wyckedflesh
wyckedflesh's Avatar
Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion)
You can also use a piece of aluminum rod in the end with a small hose clamp. Leave enough of the rod sticking out to grab or even better, drill a small hole through the rod and slip a reusable cotter pin that locks around the diameter of the rod to keep it from being gradually sucked into the vacuum line...
2009 KLE650 LSL bars, Full Muzzy PC-V
1995 900SS/CR mildly modified
wyckedflesh is offline   Reply With Quote
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
[motorcycle-usa.com] - Kawasaki Ninja H2 Videos Hint at Tech Details Ninjette Newsbot Motorcycling News 0 October 9th, 2014 03:50 PM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
[crash.net - MotoGP] - Iannone drops clearest Ducati MotoGP hint Ninjette Newsbot Motorcycling News 0 September 7th, 2012 07:20 AM
[kropotkin thinks...] - A Hint Of The Future: Repsol Honda Team Adds Indonesian Honda Ninjette Newsbot Motorcycling News 0 November 4th, 2010 04:00 PM
