Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 General Discussion
Old February 14th, 2018, 09:31 AM   #1
[motorcycle.com] - 2018 Kawasaki Ninja 400 First Ride Review
Editor Score: 85.25%Engine 18.25/20Suspension/Handling 13.0/15 Transmission/Clutch 9.0/10Brakes 7.0/10 Instruments/Controls3.5/5 Ergonomics/Comfort 8.5/10 Appearance/Quality 8.5/10Desirability 8.5/10Value 9.0/10Overall Score85.25/100Kawasaki may have just found the sweet spot with its new Ninja 400. At a glance, the new motorcycle has undergone a substantial weight reduction treatment, a displacement boost of 103cc, and a sexy styling redesign – all while remaining at the exact same price point. Non-ABS models start at $4,999 while ABS is an additional $300. Kawasaki was out for blood when it went back to the drawing board for its new entry-level motorcycle.
When Kawasaki started to feel the stark competition from bikes like Yamaha’s R3 and KTM’s RC390, they got to work in order to “take back what was theirs,” according to Kawi. That would be the lightweight entry-level sportbike category. With one look at the side by side spec chart, it’s pretty obvious they have done so. After spending a day riding the new Ninja 400 on the winding back roads of Sonoma County and a day of spinning laps at Sonoma Raceway, I am here to report that the 2018 Kawasaki Ninja 400 will be a force to be reckoned with in the entry-level sportbike class.
So, where to start…
Engine: More CC’s, please
Ah, the age-old-adage: There’s no replacement for displacement. While this isn’t always the case, maybe*it is*more often than not. Kawasaki has boosted the cubic centimeters of its entry-level Ninja by 103cc, putting it atop the spec chart when side by side with its classmates. Still a parallel-twin, bore and stroke are increased to 70.0 x 51.8 while compression ratio is bumped to 11.5:1 from 10.6:1 found in the 300.
Engine performance revisions can be seen throughout, including larger diameter head pipes at 31.8mm, a lighter flywheel, more precise tuning allowing for the elimination of sub throttles, lighter forged camshafts, optimized intake and exhaust valves, a new piston with reduced squish and a flatter crown which is also made to be lighter thanks to the oil jets cooling it from below. The cylinder is also sleeveless and uses plated bores.
The radiator has also been redesigned to better direct heat away from components the rider will come into contact with, all while using no new parts says Kawasaki.
Impressively, Kawasaki has managed to increase displacement and optimize performance, all while keeping the engine relatively the same size as the 2017 Ninja 300.
The new downdraft intake provides the most direct path of air into the cylinder for a more efficient intake system.
Also attributing to the not-so-wee Ninja’s new-found performance is the larger 5.8-liter airbox with a new downdraft intake which provides the most direct path of air into the cylinder. This creates a more efficient intake system. The intake funnels themselves are different heights allowing Kawasaki to tune out most dips in the torque curve. Kawasaki says this has been especially important to improved engine performance at high rpm. The airbox was also engineered with more rigidity at the top to eliminate unwanted noise, while still delivering a clear intake note which was present in the best way at high rpm at Sonoma Raceway.
As we can see on our exclusive dyno run of the Ninja 400, the torque curve is impressively flat, peaking at 25 lb-ft of torque at 8,000 rpm. Perhaps more notably, is the fact that 20 lb-ft are available just under 4,500 rpm. Horsepower is also substantially increased from the previous Ninja, as well as the competition, with 44 hp available at 10,000 rpm.
The transmission has also undergone some revision. Close gear ratios and the assist clutch make flipping through gears a breeze, while the slipper function will prevent the rear tire from hopping or skidding during aggressive or accidental downshifts. Kawasaki says the pull at the clutch lever has been reduced by 20% which may be welcomed on the street; however there were times during our track day when it was difficult to feel the engagement point.
Handling: Fully Flickable
To say the Kawasaki Ninja 400 is maneuverable would maybe be the understatement of the year. As I picked the bike up off of its kickstand it became clear just how lightweight the Ninja 400 was. A few corners later it was apparent how much fun I was about to have for the next two days. The usable mid-range power, light clutch pull, and ease of handling make for a fun and unintimidating entry-bike for those looking to begin their foray into motorcycling.
Let’s take a look at how Kawasaki made an already agile motorcycle into a razor-sharp, apex-mauling, corner-killing, Ninja.
When considering the power-to-weight ratio of motorcycles, dropping 17.7 lbs provides a substantial boost in performance. When we had the Ninja 400 on the dyno we also had a chance to weigh it. Full of*3.7 gallons of*fuel, the 2018 Kawasaki Ninja 400 with ABS weighs 366 lbs. The last Ninja 300 we tested, with a 4.5-gallon tank, weighed 381 lbs, so we’re looking at about a 10-lb drop in real weight.
Although I touched on the engine’s weight savings earlier in this article, weight reducing efforts can be found throughout. The new Ninja 400 is built around a trellis-style frame derived from Kawi’s work on the Ninja H2, which adds rigidity while reducing weight. The rigid-mounted engine is also now used as a stressed member, with an aluminum swingarm mounting plate bolted to the back of the engine. This all leads to added stability and less weight.
A quick look at the Ninja 400’s new chassis dimensions also allude to the nimbler character of the 2018 model. The overall wheelbase has been shortened by 1.4 inches, while the steering angle has been decreased by 2.4 degrees putting rake and trail at 24.7°/3.6 in. Seat height has been kept the same at 30.9 inches. The rather upright “clip-ons” set the handlebars back toward the rider by 15mm from the previous model, while the footpegs have been moved 9mm backward.
The suspension has also been upgraded with a non-adjustable 41mm Showa fork from the Ninja 300’s 37mm tubes. A KYB rear shock with a new Uni-Trak linkage is now used out back with five-way preload adjustment. While the suspension is somewhat soft, I never had any bottoming issues, and it soaked up imperfections on the street quite nicely. On the track, stiffer suspension would be preferred, yet it worked well enough for us to thoroughly enjoy the bikes at Sonoma Raceway.
Kawasaki has also upgraded the Ninja’s stopping power up front to a single 310mm rotor clenched by a dual-piston Nissin caliper, while the rear rotor remains 220mm with a single-piston caliper. While braking power was adequate, it became one of the few things most journalists said they would change first if track-duty was the assignment. Steel braided brake lines and a set of racing brake pads would likely fix the sponginess and soft initial bite. On the street, it’s not so much a problem. I did overhear other much faster journalists complain about brake fade (cough* Ari Henning *cough* lap record holder at Sonoma Raceway in the 300 class *cough). I didn’t have that issue.
While revising the entire motorcycle, Kawasaki didn’t stop with the tires. The Ninja 400 now uses Dunlop Sportmax GPR300 rubber, which provided good grip on the street in dry and damp conditions and wasn’t bad at Sonoma Raceway either.
Style for miles
Since 2008, Kawasaki has done a great job at making its entry-level motorcycles look much more like their larger displaced siblings. For 2018 Kawasaki has continued with styling that is undeniably Ninja. *
From the KRT graphics (a $500 upgrade that includes ABS), to the trellis-type frame and tail’s triple-peak motif, the Ninja 400 shares styling and spirit with its bigger bros. LED lighting is found throughout on the Ninja, giving it that premium motorcycle feel. As mentioned previously, the triple-peak motif tail section and small chin spoilers on the bottom of the front cowl were derived from the Ninja H2.
The new five-spoke wheels look slick and are said to be lighter than the previous version.
The cockpit also has refined feel without loose cables or wires hanging around obtrusively, rather everything is well bound and routed neatly out of the way. The dash also looks great while providing a decent amount of information with the gear-selection indicator front and center. In harsh sunlight, the screen can be rather difficult to read.
The Verdict
There seems to be some confusion about the 2018 Kawasaki Ninja 400’s place in the market and Kawi’s line-up. First, Kawasaki will no longer produce the Ninja 300. A lot of folks seemed to think it would continue the 300, but this is not the case. The 400 is now Kawasaki’s smallest sportbike.*
Secondly, this isn’t a bike you’ll get tired of in a week! There are so many comments on Kawasaki’s social media channels coming from guys saying things like: Smallest bike I would suggest for a beginner is a 600, or condescending remarks like, Who’s buying these cute lil things. What happened to men? … Those are real comments from Kawasaki’s Facebook page on the promotional video with Tom Sykes and Jonathan Rea. While I would like to go on a rant about this, I’m going to leave it at that and let you folks duke out your feelings about it in the comments section.
Final thoughts on the Ninja 400: It’s a more versatile, unintimidating lightweight sportbike that motorcyclists can grow with. The Ninja 400 would be an easy first motorcycle that you could get into track days with as well. To me, and many others who have ridden the 400, the boost in displacement feels just right. You have easy-to-use mid-range power that comes on strong without being intimidating, incredibly light and precise handling, and styling for days. And guess what?! They are in dealerships now, so seek out your local dealer or demo day and have a look for yourself.*
What do you think about the increasing displacement of the lightweight sportbike class? Let us know in the comments section. Also, if there is anything I haven’t addressed in this article that you are curious about, leave a comment and I will get you an answer as soon as possible.
+ Highs</p>
  • Incredibly lightweight handling
  • Class-leading horsepower
  • Updated or upgraded at every turn while coming in at the same MSRP of the previous model
– Sighs</p>
  • Braking performance could benefit from the aftermarket
  • Taller riders wished for more seat room
  • Gauges are difficult to see in bright sunlight
In Gear
Street
Helmet:*AGV Corsa (No longer in production)
Jacket:*Dainese Super Speed Textile Jacket
Pants:*Dainese Over Flux Overpant
Gloves: Racer Gloves Sprint
Boots: Alpinestars SMX Plus BootTrack
Suit:*Alpinestars GP Plus V2 Leather Suit
Gloves:*Alpinestars Supertech Glove
Back Protector:*Dainese Manis D1
2018 Kawasaki Ninja 400 SpecificationsMSRPNon-ABS: $4,999
ABS: $5,299-$5,499Engine TypeLiquid-cooled, 4-stroke Parallel TwinDisplacement399 ccBore and Stroke70.0 x 51.8 mmCompression ratio11.5:1Valve systemDOHC, 8 valvesHorsepower44 hp at 10000 rpm (Measured)Torque25.0 lb-ft. at 8000 rpm (Measured)Fuel systemFuel injection: ø32 mm x 2IgnitionDigitalStartingElectricLubricationForced lubrication, wet sumpTransmission6-speed, returnFinal driveChainClutchWet multi-disc, manualFrameTrellis, high-tensile steelFront Suspensionø41 mm telescopic fork with 4.7 inches travelRear SuspensionBottom-Link Uni-Trak, gas-charged shock with adjustable preload with 5.5 inches travelFront Tire110/70R17 M/C 54HRear Tire150/60R17 M/C 66HFront BrakeSingle semi-floating ø310 mm petal disc with single balanced actuation dual-piston caliperRear BrakeSingle ø220 mm petal disc with dual-piston caliperCaster (rake)24.7°Trail3.6 inchesSteering angle (left/right)35°/ 35°Overall length78.3 inchesOverall width28.0 inchesOverall height44.1 inchesWheelbase53.9 inchesGround clearance5.5 inchesSeat height30.9 inchesCurb Weight366 pounds (Measured)Fuel capacity3.7 gallons2018 Kawasaki Ninja 400 First Ride Review appeared first on Motorcycle.com.
Click here for full story...
[motorcycle.com] - 2018 Suzuki Burgman 400 First Ride Review Ninjette Newsbot Motorcycling News 0 February 13th, 2018 08:00 PM
[motorcycledaily.com] - 2018 Kawasaki Ninja 400 ABS: MD First Ride (Bike Reports) (Ne Ninjette Newsbot 2018+ Ninja 400 General Discussion 0 February 13th, 2018 10:42 AM
[RideApart] - 2018 Kawasaki Ninja 400 - First Ride Ninjette Newsbot 2018+ Ninja 400 General Discussion 0 February 12th, 2018 12:00 PM
[motorcycle.com] - 2018 Kawasaki Ninja H2 SX Review – First Ride! Ninjette Newsbot Motorcycling News 0 December 4th, 2017 04:10 PM
[motorcycle.com] - First Look: 2018 Kawasaki Ninja 400 Ninjette Newsbot 2018+ Ninja 400 General Discussion 0 October 25th, 2017 12:00 PM
