Old May 4th, 2010, 05:09 AM   #1
onepeon
Motorcycle(s): 09 Ninja 250r Thunder Blue
Left turn signal lights up both sides
Hello,
So have an issue with my Ninja 2009.
When I turn on the left turn signal both right and left lights up. The indicator light does not turn on.
The right side works perfectly with the indicator light coming on.
Everything is stock.
Is this a fuse fail safe to light up both if it blows out? I changed out flashers from another ninja thinking it would be the issue. Same result.
Is there a wiring diagram for this bike online somewhere? I can read the tech sheet and DIY.
Thanks!
onepeon is offline   Reply With Quote
Old October 13th, 2016, 07:00 PM   #2
ForeverFloating
Motorcycle(s): 2011 250r
Same problem
I am having the same problem, but I have LED indicators with LED relay. I know its an old post, but do you remember your solution?
ForeverFloating is offline   Reply With Quote
Old October 14th, 2016, 12:05 PM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
As mentioned in your thread, this is expected behavior due to the single shared turn signal indicator. You need to do the diode mod to isolate the two circuits.
Turn Signal lights are acting like hazard lights Greyfox 2008 - 2012 Ninja 250R Tech Talk 13 October 15th, 2014 09:51 AM
Peg turn signal lights. agentbad 1986 - 2007 Ninja 250R Farkles 1 February 14th, 2014 10:34 AM
My LED strip turn signal lights .... tc3jg 2008 - 2012 Ninja 250R Farkles 18 January 3rd, 2013 01:43 PM
Turn Signal lights but no blinking Murtasma 2008 - 2012 Ninja 250R Tech Talk 3 August 1st, 2011 06:06 PM
Left Rear Set / Turn Lights HeteronimoFD Items Wanted 0 May 21st, 2010 01:00 PM
