Old March 12th, 2016, 09:50 PM   #1
Jessevelazco
Jessevelazco's Avatar
Motorcycle(s): 2006 Ninja 250
Cam Chain Timing
So I was rotating the engine on my 2006 ninja 250 without the camshaft bearing caps (had them removed to check the gasket) and I'm worried that I might have caused it to skip a tooth and messed up the cam timing. What's the correct way to make sure it's timed correctly and safe to ride? I read on some other forum that the way to check it is by ensuring that the intake and exhaust marks on the cam gears line up with the valve cover gasket and the engine is at "2T". I also counted the chain link pins and they add up to 33. Is this correct ? Thanks for any help.
Last futzed with by Jessevelazco; March 12th, 2016 at 11:19 PM.
Jessevelazco is offline   Reply With Quote
Old March 13th, 2016, 06:03 AM   #2
Originally Posted by Jessevelazco View Post
..........Is this correct ? Thanks for any help.
Yes, it is.
The forces of the valve's springs over the cams make that position difficult to keep for measurement.
The caps are matched to the head journals, because they are machined together in the factory.
It is important that they go back in the exact original position.
I would clean and lubricate the chain tensioner at this time.
need help with cam timing ninja 250 starhobos 2008 - 2012 Ninja 250R Tech Talk 5 December 23rd, 2013 01:42 PM
Ex.side timing chain guide alex.s 2008 - 2012 Ninja 250R Tech Talk 5 September 23rd, 2012 10:09 AM
cam timing verandaman 2008 - 2012 Ninja 250R Tech Talk 0 October 12th, 2011 01:27 PM
Timing chain ticking n4mwd 1986 - 2007 Ninja 250R Tech Talk 15 April 27th, 2011 05:09 PM
