April 26th, 2014, 09:04 AM | #1 |
Join Date: Jan 2014 Motorcycle(s): 2000 EX250 Ninja Posts: 59
Missing idle circuit O rings? see photos...
Was cleaning carbs on my 2000 EX250. I took out idle circuit screws and springs. There were no rubber O rings below the springs. I'm guessing this isn't normal and not done for any good reason and that some PO decided he couldn't be bothered.
I'm also guessing this one of the reasons the bike will not idle. I've also replaced a torn diaphragm and cleaned everything out with carb cleaner and compressed air, follow ninja250 wiki instructions. Anyone know the size of those tiny O rings? thanks, Baz https://www.flickr.com/photos/69874352@N00/14040632603/ https://www.flickr.com/photos/69874352@N00/14020630875/ |
April 26th, 2014, 11:02 AM | #2 |
Ninjette Jockey
Join Date: Oct 2010 Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP Posts: A lot.
I don't see any O-rings in the service manual drawings.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?. |
April 26th, 2014, 01:53 PM | #3 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
Were the idle screws on your model originally blanked ? like the anti tampering stuff in some states. In which case they would be superfluous so not fitted because no air gets drawn past the threads.
(So don't necessarily blame the PO ) |
April 26th, 2014, 04:07 PM | #4 |
I'm not talking about the blanks that are fitted on top of the pilot jet (idle circuit). They were removed by some P.O.
I'm talking about the flat steel washer and rubber O ring that fit beneath the pilot jet spring. When I removed the pilot jets the washer and the O ring were both missing on both carbs, which might explain why too much fuel was leaking past the idle circuits. |
April 26th, 2014, 04:08 PM | #5 |
http://www.partzilla.com/parts/searc...TS/parts.html#
They are parts 92055 and 92022 on the above fiche. |
April 26th, 2014, 04:11 PM | #6 |
Ninjette Jockey
Sorry, I was looking in the wrong manual.
April 26th, 2014, 04:22 PM | #7 |
No probs. I wish I knew the actual diameter of the O ring and the washer. I have a bunch of new tiny washers in my tool box and a few look as if they might fit. I'll might try them before driving 60 miles to the nearest Kawi dealer or ordering online and paying 20 or 30 bucks with shipping for a couple 20 cent parts.
April 26th, 2014, 04:38 PM | #8 | |
No What I am saying is the carbs with blanks don't have the O rings fitted because the blank seals the idle threads. Last futzed with by Ninjinsky; April 27th, 2014 at 03:01 AM. Reason: Zen calmer applied :) |
April 26th, 2014, 09:12 PM | #9 |
Join Date: Oct 2010 Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900 Posts: 80
Don't think that's true Ninjinsky. I have uncapped many EPA plugs and the spring, washer and o-ring have always been present.
j98sprint |
April 27th, 2014, 02:47 AM | #10 |
Cool I Will bow to greater experience
on reflection you would need the o rings for accurate setup before re inserting the sealing blanks. re which it might be an interesting experiment to set the jets to book value and then blank the aperture with a square of duct tape or blue tack and see if the idle smooths out (It was the op misreading and implying I was an idiot confusing the tamper blank with the o ring washers that irked me, as it would any one. ) |
April 27th, 2014, 04:55 AM | #11 |
Join Date: Jun 2011 Motorcycle(s): EX250, C10 Concours Posts: 109
O ring size
O-Ring - 2.7mm x 1.15mm - Keihin Fuel Screw
92055-1002 http://www.z1enterprises.com/ItemDet...tem=92055-1002 The washer is probably a smidge larger ID and a smidge smaller OD. |
July 3rd, 2019, 02:50 PM | #12 |
Is this the same for a 2004 250R?
Idle issues - Idle is different every time I start up. | 106 | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 13th, 2014 04:57 PM |
[motorcycle-usa.com] - MotoGP Circuit of the Americas in Photos 2014 | Ninjette Newsbot | Motorcycling News | 0 | April 15th, 2014 09:20 PM |
What if I'm missing the header gaskets/rings? | peterpayne | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 23rd, 2013 05:37 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
o-rings omnomnom | flyinhawaiian | 2008 - 2012 Ninja 250R Tech Talk | 18 | September 3rd, 2010 09:57 AM |
