Old July 14th, 2019, 03:46 PM   #1
Aodhfin
Motorcycle(s): None yet
Removing head cover
I'm trying to adjust the valves and am stuck removing the head cover. Have removed the coils and can _almost_ sneak the head cover off without doing anything else, but the coolant pipe is in the way. If the coil brackets could come off it would be no problem but they are _just_ in the way. Don't want to pull the coolant pipe off as I'm sure that will spill coolant all over the place. Should the cover come off as is with a fair amount of wiggling, or should I remove something else as well?
Aodhfin is offline   Reply With Quote
Old July 14th, 2019, 03:57 PM   #2
greg737
Motorcycle(s): -
If I remember correctly there's a little metal hold-down tab on the metal pipe that comes upward out of the cylinder head (the coolant outflow at the back of the cylinder head cover). You have to loosen up the pipe and rotate the tab out of the way.
Old July 14th, 2019, 04:01 PM   #3
You can also drain some coolant at water-pump. Then pour it back in later.
Old July 14th, 2019, 04:38 PM   #4
Read through this section - https://faq.ninja250.org/wiki/How_do..._the_valves%3F
You need to drain some coolant and remove the pipe as noted.
Old July 14th, 2019, 05:07 PM   #5
Aodhfin
That's what I ended up doing, not as painful as I had feared. Now I can replace that o-ring as well.
Thanks!
Old July 15th, 2019, 06:34 AM   #6
dodgerdad
dodgerdad's Avatar
I never drain coolant, I just loosen up the radiator and remove the fan as well.
Old July 21st, 2019, 03:44 PM   #7
Aodhfin
Thanks everyone. The pipe came out after I drained the coolant so it worked well. I also ended up pulling off the front fairing (which I was trying to avoid) as well as removing the radiator. Thought if I could just squeeze my hand in it would be fine. Ended up saving more time and effort by just taking things off and being done with it.
Old July 21st, 2019, 07:14 PM   #8
Hey good job! Sometimes, I just drop engine to do valve adjustment. Quicker than trying to move bazillion hoses, wires and stuff out of way!
Old July 23rd, 2019, 09:07 AM   #9
To make this easier in the future, you can also take off the upper engine mounts, drill the spot weld that holds on the coilpack bracket, and touch it all up with paint so it doesn't rust. Then you'll be able to get the radiator loosened up, coil packs removed, and valve cover snaked off the top of the engine without having to undo your engine mounts and dangle everything off the rear two mounts.
Old July 23rd, 2019, 03:29 PM   #10
59096
59096's Avatar
I don’t bother with drilling out the coil pack spot welds, I unbolt the radiator and let it hang by the hoses and then remove the top engine mount brackets with the coils still attached. Plenty of room for big, meaty hands to get in there!
Perpetua Culpa Alterna Vagus
Old July 25th, 2019, 07:29 PM   #11
I started out doing it that way. It's easier and cleaner not to have to dangle the radiator.
Trouble removing valve cover. Floki 2008 - 2012 Ninja 250R Tech Talk 6 January 4th, 2014 06:06 AM
DIY: Removing the Valve Cover on a Pregen n4mwd Videos 1 July 1st, 2013 05:26 PM
Removing the Valve Cover n4mwd 1986 - 2007 Ninja 250R Tech Talk 19 June 24th, 2013 08:25 PM
Removing Mirror Bracket (with removing all the fairings) killermase 2008 - 2012 Ninja 250R Tech Talk 11 May 21st, 2012 11:16 PM
hard time removing the sprocket cover remme 2008 - 2012 Ninja 250R Tech Talk 1 July 28th, 2010 07:12 PM
