Old June 2nd, 2018, 05:46 AM   #161
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
unfortunately when i tested i did not ride in cruise mod 70 mph@9000 rpm.
bike still feels like it’s stumbling or starving. very subtle but noticeable. when i switch to mains disappears. will keep trying.
"trying not to get old"
Old June 25th, 2018, 01:11 PM   #162
bruce71198
bruce71198's Avatar
I have 127's in mine, still a little rich on the top end. May mess with the air bleeds😂😂😂
Old July 7th, 2018, 05:19 AM   #163
maverick9611
MOTM - Feb '18
i set aside a full day and did several carb removals float adjust and jets/needles. i couldn’t make the 100’s work, even, 102’s, transition between mid and mains was affected. i had floats set at 15mm so i know i wasn’t running out of gas. i had fp needles at max/groove 5. i put the 108’s in and everything started working. its still not perfect near redline but transition is much better and cruise mod is perfect. 38 pilots at 3 turns out. i have some 105’s they i will try also.
Old December 27th, 2018, 09:36 AM   #164
Keithb7
2008 & 2010 250cc
Motorcycle(s): 2008 and 2010 Ninja 250
error.
Keithb7 is offline   Reply With Quote
Old June 21st, 2023, 10:14 AM   #165
Shafer
Motorcycle(s): 07 Ninja ex250 blue and 07 Ninja black
YEAR: 2007
INTAKE MODIFICATIONS: KN KA-2586
EXHAUST MODIFICATIONS: Cobra F1
JET KIT OR STOCK? Jet Kit
BRAND OF JET KIT? Dynojet
MAIN JET: DJ098
NEEDLE AND CLIP POSITION: 5
MIXTURE SCREW SETTINGS: 3 / 3 turns out
ELEVATION: 100-1000'
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP:
---Plugs: NGK 7669/CR8HIX Iridium Gap 0.32" (probably going to try .035")
---Thermo Bob / engine ice
---Ninja 300 clutch - oem plates - Barrnet springs
---Rotella T6 5w-30 - K&N 401 filter
---Idle speed - 1350
---Floats - 17mm
---Range: 189-200 on primary
---15k on the odometer
*Dynojet instructions for Stage 1 with K&N drop I filter with stock airbox and high flow slip ons calls for needle clip postion 4.
I found that I had slight lean surges while cruising in 5/6 gear at 1/2-3/4 throttle. 5th clip postion cured that surge and the bike came alive and is extremely fast now for a pregen.
Rips all the way to redline, instant throttle response, and engine is smooth as glass cruising.
Shafer is offline   Reply With Quote
Old June 25th, 2023, 06:36 PM   #166
Awesome report, thanks for details!!!
Hi, which DynoJet kit# are you using?
Do you have photo of needle used?
Interesting that you're only one beside me, that have found higher-power and more responsive engine from downsizing main-jets. I suspect we're one of few that have factory-fresh clean-carbs and aren't making up for clogged dirty carbs by increasing jet size.
Old June 26th, 2023, 03:36 AM   #167
Shafer
Dynojet - JET KIT FOR 1988-2007 KAWASAKI NINJA 250R
SKU#2138 - 2138.002 U.S Models Only
My carb is factory fresh for sure. Ultrasonic cleaning, air and lots of wire does the trick.
No photos of the needles but I'll update my entry with a photo next time I have them out. I can say they are well thought and that's what you are paying for in a Dynojet kit.
I think many people during their jetting pilgrimage, keep stepping up their jets rather than balancing and fine tuning the range. "More fuel more speed mentality", without thinking that the engine's best performance is found when all the fuel can be burned the fastest, more is not always better in this case. At WOT fuel is being taken from all the jets to some degree.
From pregen Dynojet instructions:
https://www.dynojet.com/amfile/file/.../product/3287/
1988-2007 Kawasaki EX250F
Stage 1&3
STAGE 1
For mildly tuned machines using the stock airbox, with stock or K&N filter #N/A
STAGE 3
For mildly tuned machines using individual filters or velocity stacks. K&N filters #RC-1822 Both stages may be used with a good aftermarket xhaust
If you are running an aftermarket exhaust or slip-ons with high
flowing baffles use the DJ098 main jets. Be sure that the jet you are changing is the main jet.
I followed stage 1 instructions because of the high flow Cobra slip ons and KN drop in air filter with air box intact.
*Only changes I made was lowering the needle to 5th postion and 3 turns out rather than the 2.5 out that the instructions asked for.
I'll try going back to 2.5 at some point to see how that affects things but for now it's running great. Or maybe go up to a 38 flow jet from the factory 35.
Idk at this point I'm chasing inches of performance rather than miles. And the bike is lighting fast compared to stock. My GF also rides a 07 pregen all stock and because of our weight different I could never catch her from stops or on hills. Now I find myself overtaking her and having to get off the throttle. Hills are also great now, no more down shifting to keep up, just roll on the throttle and blast up the hill without bogging.
Knowing myself I'll chase those inches
Jetting Database - Discussion Thread bprayogo 2008 - 2012 Ninja 250R Tech Talk 256 September 26th, 2017 04:48 AM
Where's the Factory Pro jetting database for pregens? mr2peak 1986 - 2007 Ninja 250R Tech Talk 3 May 5th, 2014 09:02 AM
Database Errors mgentz Forum Information 11 April 13th, 2014 07:54 AM
Tire Pressure Database Asspire 2008 - 2012 Ninja 250R Tech Talk 15 July 27th, 2013 08:59 AM
Aftermarket Parts Database THE BIG SITT General Motorcycling Discussion 4 October 12th, 2011 08:20 PM
