Notices
View Poll Results: Do you wear earplugs when you ride?
On every ride 89 32.84%
On most rides 57 21.03%
Only on long trips 43 15.87%
Never 65 23.99%
What? 17 6.27%
Voters: 271. You may not vote on this poll
Old July 30th, 2014, 06:34 PM   #441
spldbrt
Motorcycle(s): 2014 Ninja 300 Ebony and Pink
Wind noise gives me a headache and is exhausting! I wear custome made silicone earplugs and they're amazing I recommend them highly
spldbrt is offline   Reply With Quote
Old July 31st, 2014, 09:11 AM   #442
ninjakuma
Stunts Extraodinar
ninjakuma's Avatar
Motorcycle(s): 1999 Ninja 250
Wind noise is starting to get to me, either a new helmet is in order or a pair of good plugs. I'm looking at the kind where you just slip them in and you don't have to wait for foam to expand
Will backflip for tips
ninjakuma is offline   Reply With Quote
Old July 31st, 2014, 09:17 AM   #443
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
http://smile.amazon.com/gp/product/B...?ie=UTF8&psc=1
@NevadaWolf has these too.
I love mine.
Raven's Rejuvenation
Old July 31st, 2014, 09:20 AM   #444
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I'm still on the fence on mine, though I think I have found that its due to me not inserting it correctly. I also have a noisy helmet that isn't helping with the noise.
Going to test them out with my quieter helmet this weekend.
Here is a cheaper option that I have worn for close to a year now. I wash them off every other ride, or when they've been sitting for a week, and the cord has really come in handy. These are now stuffed in my tank bag should I lose my more expensive ones. Readily available at Ace.
http://www.acehardware.com/product/i...uctId=17477616
<-- Linky
Old July 31st, 2014, 01:40 PM   #445
Ralgha
Ralgha's Avatar
Originally Posted by LittleRedNinjette View Post
I dunno, the cheap foam ones attenuate more noise than those, and you have to go through about 600 pairs before you equal the price. I've keep using the same pair over and over again too.
Old July 31st, 2014, 02:01 PM   #446
NevadaWolf
NevadaWolf's Avatar
My problem with the foam ones are it feels like i can never get them in fully, or they fall out, or the noise sounds amplified. The flanged ones to me feel better and fit better. Unfortunately, I'm paying for them too.
<-- Linky
Old July 31st, 2014, 02:47 PM   #447
AmyF
AmyF's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250
I wear the orange foam ones from home depot. I push them.in there pretty good. They then expand but hold inside and definitely dampen the sounds so it's very comfy. I push them until they are pretty well compressed
Present: 05 Kawasaki Ninja 250
Past: 02 Honda Rebel, 09 CFMoto Glory 150
AmyF is offline   Reply With Quote
Old July 31st, 2014, 05:17 PM   #448
LittleRedNinjette
The foam ones cut too much sound for me. These are just about perfect for me.
Old August 4th, 2014, 04:35 AM   #449
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
wind noise
Over the years wind noise can add up and very quietly without you realizing it you begin to have partial hearing loss. I have an Arai custom fitted helmet that reduces the wind noise dramatically because of the fit. I also have the foamie ear plugs and custom fit ones. I seldom go anywhere without ear plugs especially if I'm doing distance.
The foamies can be washed often and should be. When I get into the shower I bring the foamies and wash them with shampoo squeeze and dry thoroughly. Good to go next day. They last a long time.
If you go to any of the larger rallys you can be fitted for custom ear plugs. Note because they are molded they take longer getting used to and if your style of helmet compresses certain parts of your ears then they will be uncomfortable. Because they are $50-75 if you are prone to losing things foamies might be a better purchase.
wardie
wardie is offline   Reply With Quote
Old August 4th, 2014, 06:49 AM   #450
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Ear Plugs Newly Discovered Benefits for Seniors
Been using them since i got a new exhaust and even the little cheapo foam plugs make a big difference for me.
MIne are flesh colored so, leaving them in after helmet is off is also a great way to meet female audiologists, lady ENT specialists and even oncologist-a's as they, from a distance, resemble tumors.
Old August 5th, 2014, 12:27 PM   #451
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 45k miles
earplugs .....
I wear them every time I ride, street or track. Once your hearing is gone, it is not coming back in this lifetime.
'09 Ninja 250R track only SOLD
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
Old August 5th, 2014, 10:29 PM   #452
MagicMike
Motorcycle(s): 2012 EX250J
I use headphones. Cuts some windnoise, and I can listen to music
MagicMike is offline   Reply With Quote
Old April 29th, 2015, 04:59 PM   #453
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Been wearing earplugs more often at work lately,.. it can get freakin' loud in a machine shop, and it made me think of this thread. I've been wearing them when I ride for the last three years and now i don't like taking anything more than a short ride around town without them.
I know the idea of wearing earplugs when riding a motorcycle is foreign to a lot of people so I figured this thread could use a bump. I consider it part of ATGATT since it protects your hearing.
Old April 30th, 2015, 07:19 PM   #454
Yarhj
Yarhj's Avatar
Motorcycle(s): Ninja 250 (2001)
(Apologies if this has already been covered a million times -- I stopped following the discussion in this thread a while back and haven't reread everything).
I've heard a lot of people say that the foam earplugs don't stay in their ears, or don't seem to properly attenuate sound. It turns out those issues are also commonly associated with improper earplug use (Though definitely they can still be issues for people using earplugs correctly! Everyone's ears are different, and some earplugs just don't work with some ear shapes).
The natural way to insert an earplug is to just take it and push it into your ear. It turns out that the obvious method is actually not that great in this case, and leads to the earplugs forming a poor seal in the ear, or just never really getting deep enough into the ear canal, leading to them popping out. Also, in my own experience, pushing the earplugs straight in can cause earwax to get pushed deep into the ear, eventually leading to temporary but significant ear pain and hearing reduction.
Earplugs are so commonly misused that OSHA has developed a correction formula to estimate the actual hearing protection afforded by improperly-worn earplugs: NRR_effective = (NRR-7)/2.
So if you have a pair of foam earplugs rated at 32dB, if you wear them improperly you end up only getting ~12.5dB of actual noise reduction.
This video illustrates the best way to insert foam earplugs. There's also a handy graphic here for the bandwidth-challenged. Rather than pushing the earplug straight into the ear, it must first be rolled into a tight cylinder, and then the top of the ear should be pulled straight up, to straighten out the ear canal. After that you can just slip the earplug into the ear canal (it should go in very easily) and hold it for a moment until it expands enough to not move around.
Yarhj is offline   Reply With Quote
Old May 5th, 2015, 07:25 PM   #455
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
^^ that video is hilarious
"That's what" -she
Roark is offline   Reply With Quote
Old May 5th, 2015, 08:16 PM   #456
Yarhj
Yarhj's Avatar
In addition to blocking out noise, earplugs also promote a sense of peace, harmony, and well-being.
At least, they do for the guy in the video, anyway.
Old May 5th, 2015, 09:52 PM   #457
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
When my gf says "I have so much to tell you about my day", I tell her to give me a sec to pee first....so I won't have to interrupt her with a bathroom break in the middle of her story.
I just pop these bad boys in and just smile and nod for the next 90 minutes.
Riding it like I financed it.
Old May 5th, 2015, 11:03 PM   #458
cuong-nutz
cuong-nutz's Avatar
Just be sure that you can still hear stuff around you, people honking, tires screeching, the whoopies from the wambulance and emergency vehicles.
I like to jam out sometimes when I ride but sometimes it's too loud that I can't hear my surroundings.
HalfFast Racing Team
Old May 6th, 2015, 12:21 AM   #459
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
when i go on long rides, i have manipulated ear plugs into my head phones so i have music and hearing protection. the ear plugs with the strings seem to work best. pull the string and put the ear plug around the head phone.
TEAM ALFALFA
www.apexassassins.com
Old May 6th, 2015, 03:11 AM   #460
LittleRedNinjette
http://www.plugfones.com/
Check those out. I've heard good things about them.
Old May 6th, 2015, 03:18 AM   #461
MrAtom
MOTM - July '15
Old May 6th, 2015, 10:30 AM   #462
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
those are interesting, i wonder if the replacement plugs will work with my ear buds.
TEAM ALFALFA
Old May 6th, 2015, 10:34 AM   #463
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Originally Posted by MrAtom View Post
Thats what I do! except i use the plugs with the string attached pull the string and the hole is already started.
TEAM ALFALFA
Old May 6th, 2015, 10:50 AM   #464
LittleRedNinjette
for $8 for 5 sets it may be worth trying. they do have some motorcycle specific ones.
Old July 10th, 2015, 07:48 AM   #465
95PGTTech
Originally Posted by Sailariel View Post
I don`t use them because the bike is very quiet and because my full face helmet (HJC) fits so well that any wind noise is negligable--I also have a high frequency hearing loss from things that went Boom while I was in Nam, that I probably would not be bothered by wind noise.
my HJC CL15 I go back and forth too. even with a full exhaust at WOT it doesn't seem unbearable (previously I was a mechanic so exposure to loud noise is nothing new).
waiting on my icon airmada to arrive. saw they came out with a first responder version which inspired me to get it shipped to my car painter and have him do an ER nurse version. then off to get the bluetooth speakers installed, first time with those too very excited
95PGTTech is offline   Reply With Quote
Old May 27th, 2018, 12:54 PM   #466
Motorcycle(s): '13 Ninja 300 (white, the fastest color!), '13 R1200RT, '14 CRF250L, '12 TT-R125LE, '15 CRF110F, '13 TT-R50E
Bump.
Old May 27th, 2018, 01:39 PM   #467
TheDuck
Da Duckman
TheDuck's Avatar
Motorcycle(s): '08 250R, '06 Chopper, '80 Puch Magnum II, '01 SV650, '99 CR250/CR500AF Sportbike. '02 CRF450/CR500AF Dirt
Originally Posted by Alex View Post
Bump.
bibbety-bobbety BUMP-BUMP! :-D
TheDuck is offline   Reply With Quote
Old May 27th, 2018, 01:45 PM   #468
Old May 27th, 2018, 02:00 PM   #469
TheDuck
Da Duckman
TheDuck's Avatar
https://www.youtube.com/watch?v=9JHyhr-TImw
Old October 2nd, 2019, 08:52 PM   #470
LadyGogo75
Name: Ladylyn or Lyn
Motorcycle(s): 2010 Yamaha FZ6 S2
When I ride for a few block, I don't. But most of the time, YES. I use something like this from Big Ear.
LadyGogo75 is offline   Reply With Quote
Old November 4th, 2019, 06:16 AM   #471
bnolsen
Motorcycle(s): 2007 ninja 250, 2013 vstrom dl650a
When I was riding my 2007 ninja 250 to work on the highway super early in the morning ~75mph or so I was mostly okay without ear plugs. The air was nice and clean and my helmet seemed fine. I probably should have worn plugs then anyways.
Once I changed bikes over to a vstrom 650 I got myself some of those "vibes" earplugs and now wear those whenever I'm going to be on clear highway. For traffic during commuting I typically don't bother as I'm not rarely breaking 50mph.
https://www.amazon.com/Vibes-High-Fi.../dp/B018WPOQSG
bnolsen is offline   Reply With Quote
Old November 4th, 2019, 06:47 AM   #472
MonsterMash
Corporate Thug
MonsterMash's Avatar
Motorcycle(s): 2010 Victory Cross Roads, 1992 Ninja 250
wear the same silicone ones that I use at the range for when I am riding.. My helmet is a little louder than i like but I noticed a few years ago that my ears tended to ring for a while after riding and after a hearing test about 6 years ago, i had some permanent hearing loss... so earplugs went in, and honestly, i wished i had done it years ago and might have been able to avoid some of the "huhs" or "can you repeat that"'s that happen from time to time...
2010 Cross Roads
1992 Ninja 250 (nicknamed 'The Zombie' because its coming back from the dead)
Navy ET1 1994-2000 - Its not just a job, its an adventure
MonsterMash is offline   Reply With Quote
Old November 4th, 2019, 08:55 PM   #473
MrAtom
MOTM - July '15
I use the cheapo reuseable ones from the hardware store. I just find them more economical than the disposables. Remember to keep em clean, though.
What earplugs do you use? asdfman Motorcycle Gear 14 March 16th, 2015 05:20 AM
Should You Wear Earplugs? hamm Videos 12 March 17th, 2013 03:31 PM
custom earplugs??? alex.s Motorcycle Gear 12 February 15th, 2012 06:10 PM
FS: Used earplugs alex.s Gear-related 34 October 27th, 2011 09:33 PM
looking for earplugs alex.s Motorcycle Gear 13 June 8th, 2011 07:25 PM
