Old May 29th, 2013, 10:16 AM   #1
How to install a rivet style chain
Someone just posted up a great thread on a local forum on installing a rivet style chain. Considering stickying it here as well:
Old May 29th, 2013, 02:28 PM   #2
you don't need to grind off the rivet head to press it out.
Old May 29th, 2013, 02:44 PM   #3
bkh2
bkh2's Avatar
Motorcycle(s): 2006 GSXR 750; 1983 CB750SC
The limited times I've changed an OEM chain, I've found that grinding off the rivet head is the best way. Maybe I just don't have that much faith in my budget China chain breaker tool, whereas you've got a quality chain breaker.
bkh2 is offline   Reply With Quote
Old May 29th, 2013, 03:04 PM   #4
cheap harbor freight chain breaker works well to remove the rivet without any grinding so long as you use the correct size pin. i believe harbor freight is the definition of cheap chinese tools.
Old June 25th, 2014, 02:34 PM   #5
Yep, but it's a "Heavy Duty" chain breaker according to them.
Comparing it to the Cycle Gear "Stockton" and Motion Pro chain tool sets which include riveting accessories, it is much beefier. I use the Harbor Freight Heavy Duty chain breaker for breaking and the more expensive Stockton set (still only $30) for riveting. I honestly wouldn't trust the Stockton set for breaking a chain without grinding but I don't have a grinder and I wasted hours trying to do it with a cheap rotary tool years ago so I'm not going down that path again! If I had a grinder I'd just cut the chain off entirely and not deal with pressing out pins.
If you aren't going to grind, get a disposable tool like the Harbor Freight one. It works great!
RK 520XSO Chain Clip vs Rivet Master Link agentbad 1986 - 2007 Ninja 250R Tech Talk 5 May 15th, 2014 07:35 PM
Adding a rivet master link to the stock chain ??? Tiane 2008 - 2012 Ninja 250R Tech Talk 1 June 13th, 2012 12:58 AM
