Notices
Old April 26th, 2014, 09:04 AM   #1
baz666
baz666's Avatar
Motorcycle(s): 2000 EX250 Ninja
Question Missing idle circuit O rings? see photos...
Was cleaning carbs on my 2000 EX250. I took out idle circuit screws and springs. There were no rubber O rings below the springs. I'm guessing this isn't normal and not done for any good reason and that some PO decided he couldn't be bothered.
I'm also guessing this one of the reasons the bike will not idle. I've also replaced a torn diaphragm and cleaned everything out with carb cleaner and compressed air, follow ninja250 wiki instructions.
Anyone know the size of those tiny O rings?
thanks,
Baz
https://www.flickr.com/photos/69874352@N00/14040632603/
https://www.flickr.com/photos/69874352@N00/14020630875/
baz666 is offline   Reply With Quote
Old April 26th, 2014, 11:02 AM   #2
misfitsailor
Ninjette Jockey
misfitsailor's Avatar
Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP
I don't see any O-rings in the service manual drawings.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?.
misfitsailor is offline   Reply With Quote
Old April 26th, 2014, 01:53 PM   #3
Ninjinsky
Ninjinsky's Avatar
Were the idle screws on your model originally blanked ? like the anti tampering stuff in some states. In which case they would be superfluous so not fitted because no air gets drawn past the threads.
(So don't necessarily blame the PO )
Old April 26th, 2014, 04:07 PM   #4
baz666
baz666's Avatar
I'm not talking about the blanks that are fitted on top of the pilot jet (idle circuit). They were removed by some P.O.
I'm talking about the flat steel washer and rubber O ring that fit beneath the pilot jet spring. When I removed the pilot jets the washer and the O ring were both missing on both carbs, which might explain why too much fuel was leaking past the idle circuits.
Old April 26th, 2014, 04:08 PM   #5
baz666
baz666's Avatar
http://www.partzilla.com/parts/searc...TS/parts.html#
They are parts 92055 and 92022 on the above fiche.
Old April 26th, 2014, 04:11 PM   #6
misfitsailor
Ninjette Jockey
Sorry, I was looking in the wrong manual.
Old April 26th, 2014, 04:22 PM   #7
baz666
baz666's Avatar
No probs. I wish I knew the actual diameter of the O ring and the washer. I have a bunch of new tiny washers in my tool box and a few look as if they might fit. I'll might try them before driving 60 miles to the nearest Kawi dealer or ordering online and paying 20 or 30 bucks with shipping for a couple 20 cent parts.
Old April 26th, 2014, 04:38 PM   #8
Ninjinsky
Ninjinsky's Avatar
No What I am saying is the carbs with blanks don't have the O rings fitted because the blank seals the idle threads.
Last futzed with by Ninjinsky; April 27th, 2014 at 03:01 AM. Reason: Zen calmer applied :)
Old April 26th, 2014, 09:12 PM   #9
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Don't think that's true Ninjinsky. I have uncapped many EPA plugs and the spring, washer and o-ring have always been present.
j98sprint
j98sprint is offline   Reply With Quote
Old April 27th, 2014, 02:47 AM   #10
Ninjinsky
Ninjinsky's Avatar
Cool I Will bow to greater experience
on reflection you would need the o rings for accurate setup before re inserting the sealing blanks. re which it might be an interesting experiment to set the jets to book value and then blank the aperture with a square of duct tape or blue tack and see if the idle smooths out
(It was the op misreading and implying I was an idiot confusing the tamper blank with the o ring washers that irked me, as it would any one. )
Old April 27th, 2014, 04:55 AM   #11
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
O ring size
O-Ring - 2.7mm x 1.15mm - Keihin Fuel Screw
92055-1002
http://www.z1enterprises.com/ItemDet...tem=92055-1002
The washer is probably a smidge larger ID and a smidge smaller OD.
GeorgeRYoung is offline   Reply With Quote
Old July 3rd, 2019, 02:50 PM   #12
Aodhfin
Motorcycle(s): None yet
Is this the same for a 2004 250R?
Aodhfin is offline   Reply With Quote
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
[motorcycle-usa.com] - MotoGP Circuit of the Americas in Photos 2014 Ninjette Newsbot Motorcycling News 0 April 15th, 2014 09:20 PM
What if I'm missing the header gaskets/rings? peterpayne 1986 - 2007 Ninja 250R Tech Talk 2 September 23rd, 2013 05:37 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
o-rings omnomnom flyinhawaiian 2008 - 2012 Ninja 250R Tech Talk 18 September 3rd, 2010 09:57 AM
