December 6th, 2014, 04:49 PM | #1 |
Join Date: Nov 2014 Motorcycle(s): 2012 Triumph Street Triple R, 2008 Kawasaki Ninja 250R Posts: 19
Troubleshooting my Ninja
Hey ya'll. So, I bought this 08 ninja with 500 miles on it. Pretty much brand new condition although was never winterized correctly. So I had some basic problems... stalling w/ anything but very slow throttle turn, hesitant and boggy up to 5k revs, uneasy/crazy power surge @ 6k, very slow throttle response in general.
So, I replaced oil, coolant, and fuel, drained float bowls, ran some ethanol free and a bit of sea foam, and the bike improved immensely, now even with wot at idle the bike won't stall, but there is a huge lag before the revs pick up, then they drop slow. The revs will drop to 2k and hang there for about 10-15 seconds before finally dropping down to idle. Throttle response from idle is still very bad, a quick wide open blip and it hesitates to climb. Today I removed the snorkel just to see what happens, I believe I was running too lean to begin with so it didnt really help, I think it actually made it worse so I'll be putting the snorkel back on. What do you guys think I do now? I know a carb clean and possible shim may be in order but I want to exasperate all other options before doing that. maybe tinker with the mixture screws? Ride it for 200 miles or so with the new fuel? please help with any suggestions, thanks.
www.djmikesage.com |
December 6th, 2014, 04:54 PM | #2 |
MOTM - July '15
Couldn't hurt to check the airbox.
December 6th, 2014, 04:57 PM | #3 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Sounds like you may need a carb sync.
Hey Unregistered never go faster than your brakes can be applied... |
December 6th, 2014, 05:03 PM | #4 |
For obstructions? Do you think the problem is not enough fuel in the mixture?
You suggest I do it myself?
December 6th, 2014, 05:12 PM | #5 |
MOTM - July '15
Yeah, I mean, you're down there. Might as well. If it's been sitting chances are it needs to be cleaned a little, anyway. and if it doesn't help, try the carb sync. That's actually a much better idea.
December 6th, 2014, 06:26 PM | #6 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
If you took the snorkel off and it became worse then yeah its probably to lean, your adding more air to the mixture so it will run worse.
Sounds like you have a pilot jet clogged. If your able to clean the carbs I'd tackle that first. You can try to move the air fuel screws out maybe a turn each and see if it improves and then ride the bike for a good while with that good ethanol free fuel and it may clear it out but if you want results right away I'd clean the carbs but I do know its a pain to do so for some. You can see if the bike runs a little better with the choke on, that will richen up the mixture for you or obstruct the intake and see if it runs any better if so then your running lean and need more fuel and less air. CLEAN THEM CARBS! |
December 6th, 2014, 06:37 PM | #7 | |
If the caps are off of the idle mixture screws, check their current setting, then set them to 2 1/2 turns out as a staring point. Shimming the needles usually smooths out a lean flat spot as you open the throttle and the slides begin to lift. A carb sync is also a good idea. Best to do things one at a time, then check to see if there's an improvement, instead of doing everything all at once - just in case it gets worse instead of better. |
December 6th, 2014, 07:26 PM | #8 |
Thanks for your help guys truly appreciated.
Sunday funday tomorrow, I might pull the carbs I'll keep you guys posted throughout
Troubleshooting Battery/Alternator Help | bkh2 | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 20th, 2012 11:45 AM |
Return to idle RPM troubleshooting | Momaru | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 12th, 2011 05:35 PM |
Having some troubleshooting issues... | Cloud Strife | 2008 - 2012 Ninja 250R Tech Talk | 70 | April 19th, 2011 02:58 PM |
Troubleshooting '08+ CDI with '88-94 Service Manual | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 3 | November 11th, 2009 03:06 PM |
Troubleshooting Help (External Link) | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 20th, 2009 02:47 PM |
