Old September 8th, 2017, 05:40 AM   #41
Ram Jet
Ram Jet's Avatar
Originally Posted by Ghostt View Post
Looks good, don't forget to open the plug gap to take full advantage of the hotter coils.
Hotter coils? I just removed the resistors in the plug caps - no problems. In fact, I have removed the resistors in every Japanese motorcycle I've owned - no ill effects.
Just sayin'.
Bill
Old June 8th, 2019, 02:01 PM   #42
95PGTTech
I did this mod about two years ago and noticed no major change good or bad I wanted to ditch the bulky packs. When I went to rebuild the bike at the start of this season I had no spark on one cylinder and diagnosed it as a bad coil. Unfortunately I must have sold the other 2 coils and connectors (the ZX has 4). There is no way I would have thrown them out I have spare parts/track day bins for each of my bikes.
Frustrated I ordered another set on eBay. I didn’t pay attention to the years and ended up buying a set for a 09-12 zx6r (that’s the listing anyway)
I benefitted from my mistake in that although they run the same connector they are much shorter than the older bike ones I bought previously (per this thread instruction). They sit nearly flush to the ninja valve cover
95PGTTech is offline   Reply With Quote
Old June 8th, 2019, 02:06 PM   #43
95PGTTech
Next time my fairings are off I will try for a better installed picture. No noticeable difference (Id question the honesty of anyone who says they feel performance gains on a 250 of just about any mod).
File Type: jpg 34866B23-0631-4ACF-93BE-DE3216AE4947.jpg (139.6 KB, 1 views)
File Type: jpg 05403857-97B1-417A-9287-37AE77293591.jpg (28.6 KB, 4 views)
Old June 8th, 2019, 04:02 PM   #44
Ram Jet
Ram Jet's Avatar
I think the money is better spent on one good woman. No, not a one night stand - a partner. I know where most of your minds went. There is not a whole lot you can do to improve the performance of a Ninja (with the exception of the suspension).
Bill
Last futzed with by Ram Jet; June 8th, 2019 at 04:03 PM. Reason: spelling
Old June 10th, 2019, 03:48 PM   #45
Ceeloo Yello
Motorcycle(s): 250
I can add that the ninja 300 cops work great and are cheap on ebay
Zx coil over plugs alex.s Pictures 24 October 30th, 2015 04:26 PM
Ignition coil shorting? The_big_dill General Motorcycling Discussion 1 April 11th, 2015 09:54 PM
Ignition coil wire leads headshrink 2008 - 2012 Ninja 250R Tech Talk 7 June 25th, 2014 05:59 PM
