Old June 5th, 2016, 07:14 AM   #1
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
The Perfect Setup
I found this this morning (probably referenced here already) and it looks useful for track setup:
http://www.sportrider.com/perfect-setup
My particular issue: the bike was falling into turns, which I could ride around no problem at slower paces but made it very unnerving when trying to hang off of the bike and also hold the needed steering inputs mid corner and at the exit.
Ive dropped the forks 10 mm (as much as could be done) in the triple clamps. Will see if its enough at the next tbd trackday. Reducing rear preload will be next adjustment if needed.
Dave Wolfe is offline   Reply With Quote
Old June 5th, 2016, 07:31 AM   #2
That article is pretty darn good.
Old June 5th, 2016, 10:36 AM   #3
ULW
ULW's Avatar
Motorcycle(s): 2015 Ninja 300 X 2
Originally Posted by Dave Wolfe View Post
My particular issue: the bike was falling into turns...
What tires/sizes are you running?
ULW is offline   Reply With Quote
Old June 5th, 2016, 11:03 AM   #4
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
S20 Evos in 110/140 sizes. Front is shorter than tire it replaced, and rear is taller than old tire - it had stock IRCs on it before. The s20 evos really fall into turns more than stock IRCs but that should be expected for a smaller front and bigger rear (now that im a bit more educated on the topic).
Never mind the chassis setup is all from scratch too - its the first time on the track for the bike so its very much a work in progress. Im having fun and learning a ton.
Old June 5th, 2016, 11:13 AM   #5
Hey Dave, just wait until you run your first set up V profile tires.
Old June 5th, 2016, 12:38 PM   #6
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Those are fun! They fall like mad until you get to the flat part of the profile, then they just stay there.
Goin' fast on slow bikes!
Old June 5th, 2016, 12:44 PM   #7
........ Ive dropped the forks 10 mm (as much as could be done) in the triple clamps. Will see if its enough at the next tbd trackday. Reducing rear preload will be next adjustment if needed.
Regarding geometry and suspension, keep in mind two fundamental things:
1) Each change means a balance achieved between two desirable but incompatible features.
A rolling motorcycle is nothing more than a bunch of engineering compromises moving all together and in synchrony.
There is no way around that trade-off: in order to gain some characteristic, you must lose some.
2) There is no perfect setup for all conditions: that is the reason that keeps racing teams so busy at all times.
Any best set-up is only best for some specific conditions (pavement, circuit, weather, competitors, etc.).
Old June 6th, 2016, 04:46 AM   #8
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
Good find!
Already printed it to put in my notebook.
tgold is offline   Reply With Quote
Old July 1st, 2016, 08:42 PM   #9
Old May 7th, 2019, 10:29 AM   #10
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Bumpity bump bump
Old May 7th, 2019, 12:10 PM   #11
bruce71198
bruce71198's Avatar
Bumpity bump bump
Dave, get a hold of me at the track next time, I remember seeing your bike on track and things don’t look right. I’ll help you out with some of that.
Old May 7th, 2019, 12:47 PM   #12
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
U bet!
Old May 7th, 2019, 03:00 PM   #13
Zaph42
Zaph42's Avatar
That's a good article. Originally from Sport Rider. I've got the original summary page scanned and I kept it on my phone to refer to at the track.
I miss Sport Rider
Old May 8th, 2019, 07:00 PM   #14
Kowalski
Kowalski's Avatar
Motorcycle(s): 2014 Ninja 300
I picked up this book after talking with a local suspension tuner. Lots of good info and a very easy read.
https://www.amazon.com/Sportbike-Sus...49838221&psc=1
Kowalski is offline   Reply With Quote
[sportrider - tech] - The Perfect Setup Ninjette Newsbot Motorcycling News 0 April 20th, 2016 10:10 AM
[kropotkin thinks...] - 2014 Sepang Moto2 QP Result: Perfect Result In Near Perfect C Ninjette Newsbot Motorcycling News 0 October 25th, 2014 01:11 AM
FS: The Perfect Motorcyle: How To Choose, Find and Buy the Perfect New or Used Bike ( Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 10:45 PM
[motogp.com] - Lack of ‘perfect setup’ deprives Corti Ninjette Newsbot Motorcycling News 0 April 23rd, 2013 02:20 AM
15/43 setup? Yasko 1986 - 2007 Ninja 250R Tech Talk 4 January 14th, 2011 04:30 PM
