Old May 3rd, 2018, 05:04 AM   #1
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
godzilla reborn
most of the regulars know i picked up member jmgrande 2010 250r SE. now i’m figuring what direction to go. of course it will get a el cheapo slip on, radiator guard, swingarm spools. the bike has been sitting for years. garaged with fuel treatment/stabilizer and battery tender.(battery dead anyways) i have new shinko’s coming but i wonder if the stock tires are still good. no evidence of dry rot, cracking. what do y’all think?
"trying not to get old"
Old May 3rd, 2018, 06:12 AM   #2
Awesome deal! Might need some cumulative maintenance, but still incredibly clean bike!
I say test the tyres. Use pressure recommended in manual and on swingarm +2-3psi for your weight. Bring them up to speed gradually and see how they feel. Starting with high-silica rubber compounds in the ‘90s, tyres simply do not degrade like they used to. Even race tyres aren’t affected by heat-cycling like they used to. The 9-yr old factory BT-45 tyres on my street bike works as well as when they were brand-new. Their lap-times are right in-line with new versions. I can drag pegs and kickstand all day long on them.
I like how this guy tests unknown tyres: http://vfrworld.com/threads/shinko-t...-review.15098/
Old May 3rd, 2018, 06:15 AM   #3
maverick9611
MOTM - Feb '18
thanx danno
Old May 3rd, 2018, 06:24 AM   #4
maverick9611
MOTM - Feb '18
I don’t think I’m going to yank the airbox out on this one. Those carburetors are just too fussy with no air box. I will definitely shim the needles and play with the pilots though. stick coils for sure.
Last futzed with by maverick9611; May 3rd, 2018 at 06:06 PM.
Old May 3rd, 2018, 06:26 AM   #5
You have link to hi-res version of that picture? I’m gonna print out and make decal for my bike!!!
Yeah, stock newgen carburetors have lean spot in middle and too-rich up top. A couple of washers dials them in perfectly!
Old May 3rd, 2018, 06:45 AM   #6
maverick9611
MOTM - Feb '18
mains stay same size?
Old May 3rd, 2018, 07:16 AM   #7
Ralgha
Ralgha's Avatar
Not ideally (usually), but just shims is a marked improvement for many. I put on a full Area-P exhaust, and ended up going DOWN a size in the main jet for the optimal tune. Don't know how the shims relate to original since they're different needles.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old May 3rd, 2018, 07:23 AM   #8
maverick9611
MOTM - Feb '18
i’ll just start with shimming and pilot adjust and go from there.
Old May 3rd, 2018, 07:59 AM   #9
Yeah, I went from stock 98 mains down to 96. And that's with 20% more high-end flow too.
Last futzed with by DannoXYZ; May 3rd, 2018 at 09:59 AM.
Old May 3rd, 2018, 08:13 AM   #10
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
It's green; I'm a fan!!! Congrats
Old May 3rd, 2018, 03:53 PM   #11
maverick9611
MOTM - Feb '18
got zilla running. full choke only. time to hit the carbs!
Old May 3rd, 2018, 06:09 PM   #12
maverick9611
MOTM - Feb '18
zilla sticks
make me some some too. mirror it for each side.i kick ya some cash, email me
Last futzed with by maverick9611; May 5th, 2018 at 02:39 AM.
Old May 3rd, 2018, 06:53 PM   #13
Ram Jet
Ram Jet's Avatar
Maintenance item #1. Bleed the old brake fluid out.
Bill
Old May 3rd, 2018, 07:06 PM   #14
MLR
MLR's Avatar
I always go off tyre manufacture dates and replace if more than, ummm, 5 years (IIRC) from manufacturer.
I suppose how they were stored and how/if they were cleaned comes into play.
MLR is offline   Reply With Quote
Old May 3rd, 2018, 07:23 PM   #15
vulcan9611@gmail.com
I found a good clean picture! Will ask my wife about making decals, she's the artistic one.
Old May 3rd, 2018, 07:45 PM   #16
Ram Jet
Ram Jet's Avatar
Excellent! How about a tattoo? If you can get away with 8.5x11" or smaller you could make your own decal on an HP computer printer - it's easy.
Bill
Last futzed with by Ram Jet; May 3rd, 2018 at 07:48 PM. Reason: After thought
Old May 4th, 2018, 09:49 AM   #17
jmgrande
YEAH! Custom name tag.
jmgrande's Avatar
Motorcycle(s): 2010 Ninja 250R SE- SOLD to maverick9611
Good luck, I know you’ll treat her right. Can’t wait to see the transformation!
Don't touch it. Don't even look at it. Go on, get out, you heard me. Don't look at me either. Yeah, you better walk on. I'll hit an old man in public.
jmgrande is offline   Reply With Quote
Old May 4th, 2018, 10:34 AM   #18
maverick9611
MOTM - Feb '18
i thrashed on it for 5 hours and zilla lives!
drained gas tank
removed clean air crap
pulled carbs/cleaned
drilled out pilot screw covers
shimmed needles 2 washers
new fuel line, vw style filter(internal filter removed)
fired right up, adjusted pilots ready to go!
veterans tag monday
Last futzed with by maverick9611; May 5th, 2018 at 01:56 PM.
Old May 4th, 2018, 10:36 AM   #19
maverick9611
MOTM - Feb '18
Old May 4th, 2018, 10:44 AM   #20
maverick9611
MOTM - Feb '18
drained gas tank
blair’s stands rock
Old May 4th, 2018, 11:03 AM   #21
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Old May 4th, 2018, 02:43 PM   #22
maverick9611
MOTM - Feb '18
the f***ing king of monsters
Old May 4th, 2018, 02:56 PM   #23
maverick9611
MOTM - Feb '18
ok, which one do i ride?i have only 1 corbin seat with beadrider
Old May 5th, 2018, 02:45 AM   #24
maverick9611
MOTM - Feb '18
el cheapo akro knock off?of course!
getting letter c this time. exploited got letter a.
Old May 5th, 2018, 09:58 AM   #25
maverick9611
MOTM - Feb '18
more to come. godzilla is ready, getting tagged monday.
Old May 5th, 2018, 01:16 PM   #26
maverick9611
MOTM - Feb '18
kisan
kisan headlight modulator on the way
we use:
Old May 6th, 2018, 08:34 PM   #27
jp8484
following this post with great interest.. ha
we have the same bike! SE and all
gotta do some stuff on my carb too.. haven't touched it at all but was told by a mechanic to upgrade pilot to 40? instead of stock 38? and something about drilling something etc etc... I'm not very techy..
I did new front steel braided brake line, new tires, new brakes, r6 throttle tube, and swingarm spool.
jp8484 is offline   Reply With Quote
Old May 6th, 2018, 10:33 PM   #28
maverick9611
MOTM - Feb '18
38 pilots are fine. they just need to turned out some. on drilling carburetor slide: yes i did this on exploited ninja for kicks. it does work. try shimming needles with 2 washers. the se will like it. try doing some of the work yourself. all the info and every mod, tech data is right here.
Old May 7th, 2018, 04:26 AM   #29
maverick9611
MOTM - Feb '18
corbin seat
snakeskin corbin seat coming!
Old May 7th, 2018, 07:02 AM   #30
jp8484
thanks for the info!
yeah I been taking the bike to local DIY shop and wrenching it myself including tire change but nice weather is finally here.. I just want to go ride instead of wrenching.
Also was thinking I'd get to carb and all once I decide to upgrade to full exhaust system.
Old May 7th, 2018, 07:12 AM   #31
maverick9611
MOTM - Feb '18
check some of my el cheapo threads. you can save major cash.
Old May 7th, 2018, 10:51 AM   #32
maverick9611
MOTM - Feb '18
corbin of course
had to do a little snakeskin action
Old May 10th, 2018, 01:35 PM   #33
agnt_kruger
agnt_kruger's Avatar
Motorcycle(s): 11'Ninja 250r, 06 Ninja250r(Sold), 01'GSX-R750(Sold), 07'GSX-R1000(Sold), 96 GSX-R600(Sold),11' DR-400s(SOLD)
how much ya get her for? Dennis Kirk has a FMF slip-on on sale for like $140, I know they are usually for dirtbikes but I guess they make one for the NInja, Anyways, sweet find.
agnt_kruger is offline   Reply With Quote
Old May 10th, 2018, 01:43 PM   #34
maverick9611
MOTM - Feb '18
your kidding right? did you check out my el cheapo exhaust threads? anyways I paid $45 including shipping. nothing in the usa can touch this price. build quality?exact replica of a akro.
Old May 10th, 2018, 02:24 PM   #35
Well... the flow-path inside isn't quite as clean as Akro. But unless you're career racer with a paycheque that depends upon getting trophies, Ali clone can't be beat! I got TWO for $58!! Here's thread on how I installed them on my street and race bikes.
https://www.ninjette.org/forums/showthread.php?t=307767
Last futzed with by DannoXYZ; May 10th, 2018 at 03:39 PM.
Old May 10th, 2018, 02:33 PM   #36
maverick9611
MOTM - Feb '18
i hear ya dantana, i bet akro outsources to anodized.(ya never know)
by the way how's the stickers coming along?
Old May 10th, 2018, 03:00 PM   #37
agnt_kruger
cool, yeah some people like branded stuff but yeah for the prices, we got nuttin on china
Old May 10th, 2018, 03:03 PM   #38
maverick9611
MOTM - Feb '18
we are all consumers, right?
Old May 10th, 2018, 03:18 PM   #39
agnt_kruger
yeah, I got a cheap set of sato rearset knockoff's from China and I am having a hard time getting them to fit right. Not sure if I am doing something wrong but I am gonna try again next week. I guess you get what you pay for.
Old May 10th, 2018, 09:15 PM   #40
maverick9611
MOTM - Feb '18
its a crapshoot for sure. i bought a pair of xl riding pants that are totally on the small side. their sizing is way off!
[RideApart] - BSA Reborn in India? Ninjette Newsbot Motorcycling News 0 October 24th, 2016 11:20 AM
[superbikeplanet.com] - 2006 Ryder Notes from Japan: Godzilla ... Ninjette Newsbot Motorcycling News 0 October 12th, 2016 06:10 PM
[motorcyclenews.com - news] - Vertemati reborn Ninjette Newsbot Motorcycling News 0 June 6th, 2014 08:20 AM
[superbikeplanet.com] - Ryder Notes: Riders Fear Return of Godzilla if Motegi Round i Ninjette Newsbot Motorcycling News 0 June 3rd, 2011 01:40 PM
[roadracingworld.com] - Godzilla Not A Suspect: Next Weekend's Japanese Grand Prix Mo Ninjette Newsbot Motorcycling News 0 April 19th, 2010 03:30 PM
