Old June 25th, 2018, 08:22 PM   #1
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Race Fairing Stay
I have been looking around to find a diagram of a stay, since no one produces them, do any of you ex or current racers have a diagram on how to make a race stay for the 08-12 250?
TEAM ALFALFA
www.apexassassins.com
Old June 26th, 2018, 09:04 AM   #2
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
I have a very simple one I made from composite hockey stick shafts and 1/16" sheet aluminum. It is cheap, strong, and durable and has survived three crashes.
I'll try to get better pics than these, but it's very simple to make.
tgold is offline   Reply With Quote
Old June 26th, 2018, 10:11 AM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
If you got some directions on how to manufacture it, that would be great!
TEAM ALFALFA
Old June 26th, 2018, 12:14 PM   #4
ck.mecha
Motorcycle(s): 1969 Benelli Cobra 125, 1970 Honda CB160, 2009 Kawasaki 250R
Motoholders makes one, its nice:
http://www.motoholders.com/online-st...50-09-12-ninja
I bought mine direct but you can also buy from Yoyodyneti.
ck.mecha is offline   Reply With Quote
Old June 26th, 2018, 12:57 PM   #5
Do you need lateral locating of fairing? Or just vertical then using skin of fairing to locate laterally?
Can do a lot with tubing-bender and TIG welder.
Old June 26th, 2018, 09:54 PM   #6
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I was wanting to see if there were designs for this:
https://www.ninjette.org/forums/show...70&postcount=4
TEAM ALFALFA
Old June 27th, 2018, 08:40 AM   #7
Burphel
Burphel's Avatar
Motorcycle(s): Triumph Bonneville, Ninja 300
1. Take the stock one, cut off everything that isn't directly connecting the bodywork to the body.
2. Drill lots of holes in what's left.
3. Spray with Rustoleum.
4. Use zip-ties to hold your tach in place.
5. Use the money you saved on a track day.
Let he who has never re-used a crush washer cast the first stone...
Burphel is offline   Reply With Quote
Old June 27th, 2018, 08:46 AM   #8
That's pretty darn good!
I wonder about need for the knee-joint though. Seems like the stays can connect directly to bracket. I may make one!
Old June 27th, 2018, 09:15 AM   #9
tgold
MOTM - Nov '15
I doubt you'd save much money compared to the one I made from hockey sticks since I pulled it out of a trash can
Old June 27th, 2018, 02:02 PM   #10
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
1. Stock is junk and heavy
2. refer to 1
3. refer to 1
4. i have enough zipties on the bike to begin with
5. don't need to save money for trackdays
I have a bike that I have goals to achieve. shaving weight off will help.
TEAM ALFALFA
Old June 27th, 2018, 02:04 PM   #11
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I have been inspecting the pictures of this and attempting to come to some sort of idea on how to create it. the only problem is lack of tools necessary.
A couple observations:
1. use the stock and start a diagram
2. measure the distance from the frame mount to the mirror mounts.
3. measure the angle of the line from the top of the frame mount to the mirror mounts.
TEAM ALFALFA
Old June 27th, 2018, 03:23 PM   #12
I'm painting my bike this weekend. Will have stock unit to measure and going to make new one. I think we just need the following:
1. U-shaped bracket for head-tube
2. 2x 10mm stays, internally-threaded? weld nut to end?
3. length of stays needed from bracket to mirror mount holes
4. angle of stays up from bracket, weld stays to bracket
Old July 2nd, 2018, 03:19 PM   #13
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
did you get chance to work on this?
TEAM ALFALFA
Old July 5th, 2018, 10:27 AM   #14
Sorry, didn't get around to paint-job yet. Doing this weekend for sure. Will take some measurements for you.
Old January 11th, 2019, 07:00 PM   #15
SpotTheDogg
Motorcycle(s): 2009 BMW F800GS, 2010 BMW G450X, 1989 Hawk GT, 1974 CB360, 1990 VTR250
We make an aluminum race stay for the 250 and also ZZR250 and 300
SpotTheDogg is offline   Reply With Quote
Aftermarket Race Fairing Stay Ninja 250 SV Racing Parts Motorcycle-related 3 May 18th, 2015 05:11 AM
my new race fairing stay genosr1 2008 - 2012 Ninja 250R Tech Talk 3 May 17th, 2014 05:48 AM
