Go Back   ninjette.org > Marketplace > Motorcycle-related
Old November 29th, 2018, 08:37 AM   #1
Mechanikrazy
Mechanikrazy's Avatar
Motorcycle(s): Thruxton R, R6 450 triple, EX300 (sold)
Ninja 300/250 Parts - Racetech PCV Exhaust ETC
PM with an email address for photos. Prices include CONUS shipping except for bodywork and gas tank.
Should fit at least 2008+ 250/300:
Spears Racing no-drill Toe Sprocket Chain Guard Shark Fin - $40 (some small scratches, but otherwise great; required for some racing organizations and good to have in general; Spears lists it for both 250 and 300)
PSR SBK footpegs for OEM rearsets - $20 (some end scuffs; huge upgrade from OEM footpegs for 08+ 250/300)
Set of ebay replica OEM rearsets - $35 (brand new in the bag; these are complete OEM replacements, including shift and brake levers; buy with the PSR footpegs for $50)
Rest below are probably 300 only:
Healtech GIPro DS gear indicator plug and play - $55 (casing has scuffing and cable has a small patch section where the shielding wore through, but functions perfectly)
Woodcraft under fairing frame sliders - $40 (sliders have scuffing but are 95% there; bolt has a small bend at the tip, does not affect installation)
For local pick up (Orange County, CA) or shipping extra:
Catalyst Composite Fairings - $150 (has damage that needs to be repaired; right side of tail needs a patch; right side of the front fairing needs a patch; one of the mounting tabs on the front is half broken )
Black gas tank - $80 (no dents; one corner of the tank had a scuff and was repainted with an off-color black; has stomp grip grips and will include a set of the lower fairing stomp grips; no fuel pump or gas cap)
_____________
Exhaust - SOLD
PCV - SOLD
PVC map switch - SOLD
Front suspension - SOLD
R&G Racing Engine Case Cover Set - SOLD
Yoshimura Rearset risers - SOLD
Last futzed with by Mechanikrazy; January 8th, 2019 at 12:30 AM. Reason: update for 250 usage
Mechanikrazy is offline   Reply With Quote
Old November 29th, 2018, 10:18 AM   #2
AwDang
Motorcycle(s): 286, 296, 599, 799
is that for the complete forks? if so I'm interested along with the Yosh risers
AwDang is offline   Reply With Quote
Old November 29th, 2018, 10:50 AM   #3
Mechanikrazy
No, it is the internal components. Emulators, springs, predrilled damper rods, and preload adjusters.
If you're still interested in anything, send a PM if you want photos or payment info.
Old December 4th, 2018, 06:19 PM   #4
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Free bump...
Old December 7th, 2018, 03:05 PM   #5
Mechanikrazy
Originally Posted by snot View Post
Free bump...
Thanks
Also, 10% off ebay today with PHLDAYTEN so you can save some extra money.
The Power Commander and the Exhaust are up there!
PCV
https://www.ebay.com/itm/223272589164
Two Brothers Full Exhaust
https://www.ebay.com/itm/223272593154
Old January 4th, 2019, 10:52 AM   #6
Mechanikrazy
Bump with price drops!
Old April 14th, 2019, 09:09 PM   #7
Sirena
Sirena's Avatar
Motorcycle(s): Ninja 300, GSXR 600, CBR 500
Hello! do you still have the shark fin?
~ The way to go fast is to never slow down ~
Sirena is offline   Reply With Quote
Old April 29th, 2019, 10:30 PM   #8
Mechanikrazy
Update as I cannot edit the original post anymore. PM with an email address for photos. Prices include CONUS shipping except for bodywork and gas tank.
Catalyst Composite Fairings - $120 (has damage that needs to be repaired; right side of tail needs a patch; right side of the front fairing needs a patch; one of the mounting tabs on the front is half broken )
Black gas tank - $60 (no dents; one corner of the tank had a scuff and was repainted with an off-color black; has stomp grip grips and will include a set of the lower fairing stomp grips; no fuel pump or gas cap)
_____________
Exhaust - SOLD
PCV - SOLD
Rearsets - SOLD
Shark fin - SOLD
PARTS NINJAS FIRST NINJA 300 PART OUT! Full 2013 Ninja 300 in good shape! NEED PARTS? PartsNinja Motorcycle-related 75 October 23rd, 2016 04:08 PM
WTB: PCV for Ninja 300 ULW Items Wanted 0 June 30th, 2016 02:50 PM
PreGen -- Full race suspenson (Fox Racing, RaceTech) $300 NealWright Motorcycle-related 9 April 18th, 2016 11:36 AM
Ninja 250 parts for sale + Muzzys exhaust extremez31 Motorcycle-related 13 May 14th, 2013 12:52 PM
