Old May 2nd, 2019, 08:34 AM   #41
Robb235
Motorcycle(s): 2007 250EX
a member recently posted he used the $35 diaphragm with success via stretching, using hot soapy water, IIRC.
Hey give it a shot.
Got a link to his thread by chance? I tried a few search terms, but either I got a zillion results, or didn't find that particular thread.
Robb235 is offline   Reply With Quote
Old May 2nd, 2019, 08:42 AM   #42
ducatiman
ducatiman's Avatar
https://www.ninjette.org/forums/showthread.php?t=331389
go get 'em
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old May 2nd, 2019, 10:39 AM   #43
Robb235
Just ordered it. We'll see how it goes.
On another note, when I opened the tops of the carbs, the right one was torn, and the left one was shaped like a flower. Would not fit back into its grooves. So I boiled it in hot water for about 12 minutes and it shrunk back down and fit.
EDIT: Not sure why my pictures get uploaded sideways.
Old May 2nd, 2019, 11:52 AM   #44
Possibly the result of a solvent attacking the rubber and making it swell.
Old May 2nd, 2019, 12:02 PM   #45
Robb235
Never had an issue with the Mikuni carbs coming into contact with carb cleaner. Keihin must use a lesser grade of rubber or something? And it only affected one diaphragm and not the other?
Old May 2nd, 2019, 12:59 PM   #46
Not necessarily a lesser grade, rather a different type possibly. Maybe carb cleaner just got to one of them. I don't know, I'm just speculating.
Old May 5th, 2019, 01:50 PM   #47
Robb235
So putting the new diaphragm onto the slide was easier than I expected. Put the carb back together and the problem persists.
What's happening is only the right cylinder is firing. Figured this out because the right exhaust pipe is getting warm while the left one stays cold. When I get the bike to idle, I can smell what I think is raw fuel coming out the exhaust pipe. Wondering if maybe I have spark issue and not fuel.
Old May 5th, 2019, 03:10 PM   #48
Easy enough to test for spark.
1. unplug right spark-plug wire
2. shove extra spark-plug into wire
3. lay on top of engine so case of spark-plug is grounded
4. crank engine and see if spark jumps gap in plug.
Might want to do left side first as control test.
Old May 6th, 2019, 07:51 PM   #49
Robb235
Finally figured it out. It was a spark issue. Took the left plug out and put it on top of the engine. It would fire intermittently, and then not at all. Tested a new spark plug and it fired every time. Popped the new spark plug into the motor, and fired right up! Let it warm up for a little bit and took it on a ride. Did great.
Old May 8th, 2019, 09:28 AM   #50
Buzzerd
Motorcycle(s): 2000 Ninja 250
Persistence paid off! Remind me never to let my bike sit for a while.
Buzzerd is offline   Reply With Quote
Old May 9th, 2019, 02:35 AM   #51
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
When I buy a used bike that has been I first test for compression and spark. Also look for rust in the tank.
Pay the guy and load it up.
Get it home and remove the cabs for complete dissembling, ultrasonic bath and complete rebuild.
Then I start it up.
Starting is the last thing I try once I know I have spark, clean fuel and clean carbs.
This method has yet to fail me.
You can rant all you want about carbs. If you got them you are stuck with them or you can sell the bike and move on.
Cafe Racer is offline   Reply With Quote
Old May 9th, 2019, 03:06 AM   #52
Robb235
Bingo! That's exactly what's happening.
Old May 28th, 2019, 01:03 AM   #53
Robb235
And this bike is SOLD!
Old March 21st, 2020, 10:01 PM   #54
Cdnlouie
Motorcycle(s): 1985 Yamaha Venture Royale XVZ1200, 1982 Yamaha Vision XZ550RJ, 2006 Kawasaki Ninja 250R
Appreciate the heads up on the very small pilot orifice.
Thanks Rob for the great question as I googled it trying to figure out why my pilots had no hole and I could not get my smallest wire through. I appreciated Gordons idea for the guitar string, but searching around my shop I found some picture hanging wire and pulled a strand from the braided wire which nicely penetrated the pilot. This is key to this carb. Possibly the most problematic part on this carb. It doesn't take much to plug this jet. So thanks for the post and great carb diagrams here too. Runs like a charm now.
Cdnlouie is offline   Reply With Quote
Old March 23rd, 2020, 05:15 AM   #55
ducatiman
ducatiman's Avatar
As supplied Keihin 38 jets .38mm= .01496" inch
a .014" string is a good start at an initial poke to clear, but what about that other .00096" ? Further measures are called for to *fully* clear to spec.
Thus, i'm not a fan of using random, unknown size wire.
In the past, I've actually found stuck, broken off remnants within pilots, rare but happens.
Once cleared, I then prefer to "index" (measure) to assure jets have not been "hogged out". Rare, but also present time to time, sure enough requiring replace.
Hey, whatever works for you.
Custom Carb Service
Old March 23rd, 2020, 05:55 AM   #56
Cdnlouie
I would be curious to know what you use to "index" your jets? Clearing the jets is always my first priority. Any smaller size wire can do this job. If I was in doubt of the integrity of the passage I would normally replace the jet.
What size pilot jets are you guys running? Tylorwashere 1986 - 2007 Ninja 250R Tech Talk 12 January 15th, 2018 02:35 PM
Pilot jets KaTyStew 2008 - 2012 Ninja 250R Tech Talk 5 October 15th, 2016 04:09 PM
FS: Genuine Keihin 42 Pilot Jets GlassAnkles Motorcycle-related 0 March 27th, 2013 10:19 AM
Changing pilot jets on a stock 250 shadowman 2008 - 2012 Ninja 250R Tech Talk 4 March 15th, 2012 08:49 AM
WTB #40 Pilot Jets tjkamper Items Wanted 1 August 29th, 2010 05:32 PM
