Notices
Old May 8th, 2019, 07:53 AM   #1
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
no steering dampner = broken thumb
Food for thought, I hadnt thought about this before. I had an off from locking up the front wheel in damp grass. Best I can tell, the bars snapping to one side broke my thumb. Time to add a dampener to my bike!
Dave Wolfe is offline   Reply With Quote
Old May 9th, 2019, 12:36 AM   #2
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Time not to lock up the front wheel.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old May 9th, 2019, 03:34 AM   #3
Iowa129
Iowa129's Avatar
Motorcycle(s): 2017 ninja 300, 2012 ninja 600, 2012 ducati panigale1199
In conditions like we had at ACC this weekend with the run off areas soaking wet even looking at the front brake lever would cause it to lock up and most likely crash. A steering damper would not stop that from happening.
Sucks about the thumb it looked like it hurt but you didn't let it slow you down!
Next time your around I would take up Bruce on his offer to help, He knows those chassis pretty well and has helped me.
Iowa129 is offline   Reply With Quote
Old May 9th, 2019, 04:01 AM   #4
yeah... definitely a farkle for farkle's sake.
By the way,
Damper: adds velocity-dependent resistance to motion.
Dampener: adds moisture to something.
Two different things.
Old May 9th, 2019, 04:04 AM   #5
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Im pretty convinced it was the handlebara snapping sideways that broke the thumb. A damper wiuld have slowed down the handlebars. Or.. using the rear brake instead certainly would have helped.
But my main thought is you normally think about steering dampers to stop tank slappers on the pavement. I had never given them a thought for when you go into the grass for whatever reason, and that the bars can break a thumb *before* you fall off the bike.
Old May 9th, 2019, 04:08 AM   #6
The amount of damping torque that a steering damper applies to the bars is very minimal compared to the amount of torque applied during a crash. Sure, it *would* slow down the bar turning to some extent to some extent because damping is being applied, you're not wrong. I think you're just overestimating the effectiveness of such a device.
If you want a damper, that's 100% your decision because it's your bike and we're just a bunch of strangers on the internet, but don't kid yourself: the solution here is to not lock up the front wheel and crash.
Old May 11th, 2019, 01:59 PM   #7
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
Sounds like you need to adjust your steering stops to leave enough room between the bars and the tank.
GregS is offline   Reply With Quote
Old May 12th, 2019, 07:33 AM   #8
jrshooter
Motorcycle(s): ninja 300
i have wheel weights on each side of my steering stop, to limit the steering,
i know for the r3 you can buy a plate that mounts to the steering stop to limit it, often wonderd why i cant find one for the 300.
Old May 12th, 2019, 10:08 AM   #9
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Wheel weights work fine for the 250
Old May 12th, 2019, 04:18 PM   #10
By the way,
As much as I prefer "damper" to "dampener" in this context, both are considered correct.
https://www.merriam-webster.com/dictionary/dampener
[roadracingworld.com] - MotoGP: Jordi Torres Undergoes Surgery On Broken Left Thumb Ninjette Newsbot Motorcycling News 0 November 7th, 2018 10:44 AM
fork dampner rod ? jrshooter 2013 - 2017 Ninja 300 Tech Talk 8 March 3rd, 2017 06:26 PM
[roadracingworld.com] - Josh Day Undergoes Successful Surgery On Broken Thumb, Will T Ninjette Newsbot Motorcycling News 0 April 21st, 2016 09:50 AM
[roadracingworld.com] - Broken Left Thumb Forces Holden To Miss Barber Superbike Clas Ninjette Newsbot Motorcycling News 0 June 16th, 2011 10:50 AM
[roadracingworld.com] - In Spite Of Pinned-Together Broken Thumb, Ben Bostrom Says An Ninjette Newsbot Motorcycling News 0 August 6th, 2010 05:00 PM
