Old May 26th, 2019, 08:15 AM   #1
nickaw97
Angry Need Help! 06 250 pouring gas out front of carbs
Hi everyone! This is my first post on here and I’m needing some help. I recently picked up a nice 2006 ninja 250 for a good deal and was told it sat over winter but ran fine before. I’ve rebuilt carbs before so I wasn’t worried about it and got it running but it’s pouring gas out of the front of the carbs. I replaced both float bowl seals because they were pretty rough but it’s still doing the exact same thing! I’m at a loss of what’s going on, can anyone help?? I attached a video to help show what’s going on. I would appreciate any help or suggestions. Thanks in advance!
File Type: mov 0ADFACA7-FADE-4E5A-9614-11226173CC93.MOV (6.73 MB, 9 views)
nickaw97 is offline   Reply With Quote
Old May 26th, 2019, 08:55 AM   #2
The float valves are not shutting off the fuel flow when the bowls get full. If it's doing it with the bike just sitting, the petcock is also not stopping flow from the gas tank like it should.
Old May 26th, 2019, 11:14 AM   #3
SecN8ure
Motorcycle(s): 04EX250F
Float valve was my first thought as well. However, it could be other things too. Here's a good example.
https://youtu.be/2n43ddjI7mo
Work on a flat surface like table unlike the guy on the video lol.
SecN8ure is offline   Reply With Quote
Old May 28th, 2019, 11:46 PM   #4
Tooch
Tooch's Avatar
Motorcycle(s): 2008 Ninja 250, 2015 zx10r, 2010 Ducati 848
I had this same issue with fuel pouring out of the carbs after I shut it off. Turned out I simply had a vacuum line misrouted. Check and double check your vacuum diagram with your lines.
Tooch is offline   Reply With Quote
Old May 30th, 2019, 04:34 PM   #5
yes, confirm all your hose-routing is proper. And test petcock's vacuum function, should probably get rebuild-kit and fix it. Make sure your carb's float valves seal and shut off petrol flow otherwise you may have some issues on hand...
Old May 30th, 2019, 06:19 PM   #6
ducatiman
ducatiman's Avatar
Carbs removed, a wet test (gravity fed source) will easily reveal source of leakage.
Setup something like this, though the thin tubes are for measuring fuel levels in each bowl. As described, yours should pour without the tubes. With carbs removed, easy access to see under over, front, back.
Standard within my normal service, wet test for any leaks and fuel level checks/careful adjustments if needed.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
2005 pouring fuel out back of carbs sh123469 1986 - 2007 Ninja 250R Tech Talk 24 July 16th, 2017 09:14 PM
Gas trouble not carbs bowlbug 1986 - 2007 Ninja 250R Tech Talk 28 April 9th, 2017 09:06 PM
Possible gas leak from carbs or petcock issue agentbad 1986 - 2007 Ninja 250R Tech Talk 7 December 13th, 2013 07:45 AM
Gas Pouring out of Overflow Tube - Bowls or Petcock? Jim Moore 1986 - 2007 Ninja 250R Tech Talk 7 October 30th, 2012 01:03 PM
Gas leaking, carbs out, what to look for? CmichRider 1986 - 2007 Ninja 250R Tech Talk 7 August 12th, 2011 12:45 PM
