Old June 19th, 2019, 05:13 AM   #1
Oldskool
Motorcycle(s): 07 ninja ex250
Air screw tip broke in carb
Hey everyone I’m stuck at this moment 07 ninja 250 I went to re service the carb and when I went to take out the air mix screw I noticed the tip had broken off in the carb is there anyway to get it out?
Oldskool is offline   Reply With Quote
Old June 19th, 2019, 05:57 AM   #2
ducatiman
ducatiman's Avatar
yes, working within the venturi...a guitar string (larger diameter than used for pilot jets) lodged into the venturi drilling to press and pop the tip out. There may be carbon clogging the tip so a shot of cleaner may help dislodge.
Its a minute, extremely tight workspace , but as evidenced by my pic, can be done. in my case, long discarded carbs, and carbon around the tip froze it to the drilling, broke upon removing the pilot screw. The fuel deposits eventually solidify and act like epoxy..hence freezing jets and fuel metering surfaces. No secrets there.
So, you a geetar player? If memory serves a B or G string fits. As comes in varying diameters within sets, I can't remember the actual measurement I used.
And for any worry-wart surgical types wondering...the string will not maul the pilot opening...even if any tiny, minute opening did occur, fuel delivery would be compensated for via adjustment within correct, standard pilot setting procedure anyway.
So doanworryboudit. OP if you are truly stuck and so inclined, i'm at your service.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; June 19th, 2019 at 08:27 AM.
Old June 19th, 2019, 11:15 AM   #3
The broken tip can be pressed in from carb venturi side.
There may be anodic corrosion from dissimilar metals touching.
An ammonia-based cleaner can dissolve this corrosion and free up tip.
Old June 20th, 2019, 06:41 AM   #4
ducatiman
ducatiman's Avatar
so @Oldskool.....wha happen? You get it out?
Custom Carb Service
Old June 20th, 2019, 06:43 AM   #5
Oldskool
No haven’t had any luck on getting it out sorry for some reason my email didn’t send you reply’s
carb throttle bracket mount broke atxninjette 1986 - 2007 Ninja 250R Tech Talk 4 August 5th, 2014 07:22 AM
Carb Sync Screw Replacement? MasterCylinder 1986 - 2007 Ninja 250R Tech Talk 8 April 24th, 2012 07:54 AM
Carb Sync Trick/Tip WindMeUp 2008 - 2012 Ninja 250R Tech Talk 7 August 28th, 2010 08:30 AM
Carb screw holes Momaru 2008 - 2012 Ninja 250R Tech Talk 3 March 11th, 2010 02:16 PM
Dad broke the screw on my kickstand killswitch BlueRaven 2008 - 2012 Ninja 250R Tech Talk 31 June 30th, 2009 11:13 PM
