Old June 24th, 2019, 09:29 AM   #1
Cozen
Motorcycle(s): 2010 Ninja 250, 2007 DR-Z400SM, 2001 GSX-R750
Clip-On Clearance Fixes?
I have a 2010 Ninja 250r that I'm prepping for the track. I've purchased and installed some clip-on's which have significantly lowered the handle bar position. My issue here is that the bar clearance is now also significantly less, probably about 1/2-1/3 of what it used to be. I understand I don't need the full turn radius that the bike has stock but I'd like a bit more than what it has now. Are there any resolutions that you guys may have to this situation? Maybe an aftermarket fairing stay possibly? I don't mind removing the meter cover as long as I can keep the bike decent looking as I'm keeping the bike legal to ride on the street.
Cozen is offline   Reply With Quote
Old June 24th, 2019, 02:48 PM   #2
jrshooter
Motorcycle(s): ninja 300
on the 300 i lowered the instrument cluster, and used a dremmel on the fairings. the instrument panel lays flat and low.
Old June 24th, 2019, 03:22 PM   #3
What are the clip-ons hitting that's reducing your clearance?
Tank?
Dash?
Forward part of fairing?
Bottom part of fairing?
To clear fairing with lowered bars, I've done this mod where you chop off part of fairing that normally attaches to tank.
For even more clearance, you can remove even more of fairing.
Someone posted an easy method couple months ago to reduce steering-angle limits to prevent squashed thumbs.
Old June 24th, 2019, 03:56 PM   #4
Cozen
The dash is the issue. I have full clearance as far as the tank and fairings. My clutch lever hits the left side of the dash and slightly engages it. My brake line hits the right side. I saw some other posts on here stating to rotate the brake line which I will be doing. That will help but it will bring it to the having the same issue as the clutch side. I have a buddy who installed the same set of clip-ons and he has a little bit more clearance, but still not as much as I'd prefer. the only difference is that he has an aftermarket digital dash as opposed to the stock dash that I have on mine. I have no issues with the stock dash so I'd prefer to keep it if I can.
Old June 24th, 2019, 04:00 PM   #5
jrshooter
Originally Posted by Cozen View Post
The dash is the issue. I have full clearance as far as the tank and fairings. I have a buddy who installed the same set of clip-ons and he has a little bit more clearance, but still not as much as I'd prefer. the only difference is that he has an aftermarket digital dash as opposed to the stock dash that I have on mine. I have no issues with the stock dash so I'd prefer to keep it if I can.
had the same issue. move the dash way forward into the fairing.
Old June 24th, 2019, 04:06 PM   #6
jrshooter
here you go
Old June 24th, 2019, 05:21 PM   #7
Cozen
Originally Posted by jrshooter View Post
here you go
So it looks like you've just completely removed the meter cover entirely then?
Old June 24th, 2019, 06:05 PM   #8
jrshooter
yes and mounted right to the fairing stay. had make littlie aluminum brackets rivited to the fairing stay.
Old June 24th, 2019, 06:09 PM   #9
I've got similar arrangement with Trailtech Vapour dash. Bolted an aluminium plate to factory fairing bracket.
Old June 25th, 2019, 11:04 AM   #10
What you can try is angling bars back slightly. That should keep them from running into dash.
Any temp fixes for scuffed marks? IF13 2008 - 2012 Ninja 250R Farkles 2 September 4th, 2013 09:45 PM
driven clip ons sorta clearance issue kush452 2008 - 2012 Ninja 250R Farkles 1 March 22nd, 2013 02:42 AM
Clip-ons Installed, now Clearance Issues KURT 2008 - 2012 Ninja 250R Tech Talk 10 February 22nd, 2011 10:19 PM
[superbikeplanet.com] - Clearance Clarence: Suzuki Offers $1000 Off In Clearance Even Ninjette Newsbot Motorcycling News 0 February 15th, 2011 03:40 PM
so.. ninja lowsided... questions about fixes!! boyonfire 1986 - 2007 Ninja 250R Tech Talk 6 September 8th, 2009 02:27 PM
