Old July 3rd, 2019, 03:04 PM   #1
Aodhfin
Motorcycle(s): None yet
'04 Idle Air Mixture Screw O-Rings
Hello! I am working on a friend's '04 250R to help him get it running. The carbs were pretty much gunked up so I've done a through cleaning and rebuild but it's still not dropping down to idle when letting off the throttle. I think I've narrowed it down to the o-rings in the idle air mixture screws being old and deformed so I'd like to replace them. However the only thing I can find is a compete Idle Air Mixture Screw assembly for $15-20 each side. The screws, spring and washer are fine, I'd just like to replace the o-rings if possible.
Does anyone know what the part number is for just the o-rings?
The carbs were cleaned in an ultrasonic machine, all the passages were blown out with shop compressed air, passages confirmed clear with carb cleaner blown through them, boots on both air-box side and head side properly seated with no known vacuum leaks. Valve adjustment is in progress but I'm pretty sure it's an idle air mixture issue - though any additional thoughts would be appreciated!
Thanks!
Aodhfin is offline   Reply With Quote
Old July 3rd, 2019, 03:10 PM   #2
ducatiman
ducatiman's Avatar
contact me via PM re orings
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 3rd, 2019, 04:06 PM   #3
Aodhfin
Thanks! PM sent.
Air/fuel mixture screw o rings. How big of a deal are they? squirrel 1986 - 2007 Ninja 250R Tech Talk 17 February 20th, 2018 12:46 PM
what is the best idle screw mixture vmax 2008 - 2012 Ninja 250R Tech Talk 9 July 1st, 2017 10:45 AM
Question about idle mixture screw and low idle flux daverdfw 2008 - 2012 Ninja 250R Tech Talk 3 June 2nd, 2016 10:36 PM
Idle Mixture Screw Problem gogoKawi 2008 - 2012 Ninja 250R Tech Talk 6 April 23rd, 2013 07:07 PM
Wanted: Air mixture screw washers and O-rings dtmbcorp Items Wanted 2 August 4th, 2010 10:51 AM
