Old May 20th, 2019, 02:04 PM   #1
BabblingBS
Motorcycle(s): 2015 Kawasaki Ninja 300
Tachometer Problems
Hi all,
I recently purchased a used 2015 Ninja 300se, and after driving it away my tachometer has been giving me some issues. It does not affect my driving performance or speedo reading, however my tachometer is reading wrong. Upon initial startup, my tachometer will usually bounce up to around 11k and then it jumps down and will get stuck between 6 and 9k. It will stay at this range and act as if it zero (it will return to this range after acceleration). I have tried to tighten down the battery terminals to no avail. I'm not quite sure where the tach connections are and I have heard that this could be a ground issue. If anyone has any ideas or tips let me know.
Thanks a bunch,
Grant Hodgetts
BabblingBS is offline   Reply With Quote
Old May 21st, 2019, 01:34 AM   #2
Try turning key to ON, but don't start bike. What does tach do?
Old May 22nd, 2019, 12:03 PM   #3
BabblingBS
It will drop to 0 and then shoot up to like 11-12k bounce down a little and then stick between 7 and 10k. Usually after I start it and ride it and give the tach a work out it seems to normalize.
Tachometer problem Aman13 2008 - 2012 Ninja 250R Tech Talk 1 October 3rd, 2013 07:19 AM
Battery Connection & Tachometer Problems mystifiedwhiff 2008 - 2012 Ninja 250R Tech Talk 7 April 21st, 2013 08:06 PM
tachometer issues 00NissanNinja 2008 - 2012 Ninja 250R Tech Talk 11 July 12th, 2012 02:14 AM
Tachometer Accuracy longhorn 2008 - 2012 Ninja 250R Tech Talk 2 January 4th, 2012 09:10 PM
09 ninja tachometer kyle98927 2008 - 2012 Ninja 250R Tech Talk 9 June 30th, 2009 10:12 AM
