Old September 5th, 2019, 05:49 AM   #1
Frank06
Motorcycle(s): many!
[2015 Ninja 300] Air Filter Housing Separation
Hi All,
Do the plastic halves holding the air filter element just pull apart or is there something that's supposed to unscrew or ? I don't want to just yank it apart in my impatience...
thanks!
Frank06 is offline   Reply With Quote
Old September 5th, 2019, 12:41 PM   #2
What are you trying to accomplish?
Last futzed with by DannoXYZ; September 5th, 2019 at 04:10 PM.
Old September 5th, 2019, 12:52 PM   #3
Frank06
Just replacing the air filter.... I found a video showing the two halves of the plastic doo-dad sandwiching the filter element just snap apart. This is what I suspected but I didn't want to break anything. Thanks for taking time to respond.
Old September 5th, 2019, 01:33 PM   #4
[Hi Frank, I hope you're doing well.]
Old September 5th, 2019, 01:38 PM   #5
Frank06
hey Jim - all good, hope the same is true with you!
Just got back from several days LSR up at Loring, now in Nova Scotia, heading out to a track day tomorrow with the little Ninja.... Life is good!
Old September 5th, 2019, 01:46 PM   #6
Frank06
BTW, tons of cool pics on book of faces, look at Loring Timing Association if you're interested...
Old September 5th, 2019, 01:56 PM   #7
I hope you had an excellent time there. Good luck at track day... I still need to get to one here sometime. I even bought a suit for it.
Old September 5th, 2019, 04:09 PM   #8
There's two studs in middle that connect the 2-halves. Just grab ends of studs close to them and pull apart.
Old September 6th, 2019, 05:35 AM   #9
How did you do at Loring? Running the E-bike?
You get around!
Old September 6th, 2019, 06:27 AM   #10
stevect
Motorcycle(s): 08 250
You don't have to split anything to pull air filter out. Pull off the side cover on the throttle side of the bike using a 4mm allen, you will see 3 phillips screws on the air filter cover. Undo those and slide air filter out.
stevect is offline   Reply With Quote
New Air Filter from Hurricane Racing for the Ninja 300 & 250R DaBlue1 2013 - 2017 Ninja 300 Farkles 8 March 25th, 2013 04:46 AM
