Old September 17th, 2019, 06:54 AM   #1
kashun84
kashun84's Avatar
Motorcycle(s): 2010 Lime Green 250R
Headlight issue
I have a 2013 and my low beam has been not work for a while. I have checked the bulb, fuse nth wrong on those and I check voltage on the bulb socket itself. Funny thing is I got 12V only with out the bulb connected. As soon as I have a bulb connected, it dropped to 0V. This make me to think it might be a relay issue. I took out the relay box and put a jumper wire across the relay switch for the low beam (Pin 1 & 3 if refer to the manual at page 16-80) but still act the same. Did anyone experience the same? Thanks in advance.
kashun84 is offline   Reply With Quote
Old September 17th, 2019, 10:42 AM   #2
First, test your bulb to see if it's working.
- Measure resistance of filament in bulb itself.
- Connect bulb directly to battery with jumper-cables. Does it light up?
If not, replace bulb and repeat tests above. No use trying to light dead bulb.
Next, test your headlight wiring
- When measuring voltage at bulb socket, which terminal did you measure?
Old September 17th, 2019, 10:55 AM   #3
kashun84
kashun84's Avatar
Thanks for your input. The bulb should be fine. I have switched the bulb of hi beam and low beam around and both light up on the hi beam circuit. I will measure the resistance next time to confirm.
I was measuring the volt across the connector where the bulb inserted directly.
Old September 18th, 2019, 03:06 AM   #4
Try same tests on high-beam side.
You may have hidden break in low-beam wire or corrosion that's preventing sufficient current to flow across low-beam bulb. With little current flow through multimeter, it may register full voltage. But with higher demands, it drops to zero.
V=IR
Issue with headlight RKade15 2008 - 2012 Ninja 250R Tech Talk 9 October 4th, 2013 05:36 PM
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue Ninjette Newsbot Motorcycling News 0 May 11th, 2010 07:50 AM
Have a lean issue with my bike, issue with coasting enricher. twiggy2cents 1986 - 2007 Ninja 250R Tech Talk 7 February 24th, 2010 06:54 PM
HID headlight issue darkknight49 2008 - 2012 Ninja 250R Tech Talk 4 February 8th, 2009 03:08 AM
