Old September 26th, 2019, 03:14 PM   #1
paqmanbiker
Motorcycle(s): Ninja 300
Fork seals kit
So I am considering doing the fork seals on my 2013 300. But I'm not sure where to get tall the parts I need. I know the oil I will buy separately, but do you all know of a good kit that has all the parts I will need to do the seals? I haven't done forks before so I don't know the parts well enough to just order them piece by piece.
Is there a good place to get a kit? Or even just a good site where I can get all the parts I need? Just not sure which parts I really need to replace.
Thanks!
paqmanbiker is offline   Reply With Quote
Old September 26th, 2019, 06:19 PM   #2
Try Amazon
https://www.amazon.com/s?k=ninja+300+fork+seals
Old September 26th, 2019, 07:54 PM   #3
paqmanbiker
Ha ok I've looked on Amazon, and eBay, and yes there are plenty of kits out there. But I know nothing about them. I come to a Ninja forum to find out what the experienced Ninja guys prefer. I was hoping someone here would say, I've bought xyz fork seals from xyz.com and they were great, those ones on ebay are crap, get these ones.
Old September 26th, 2019, 07:57 PM   #4
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Just buy some OEM seals with thicker oil weight or the right springs depending on weight.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old September 26th, 2019, 07:59 PM   #5
paqmanbiker
Why a thicker oil weight? I don't want to change it, I want to leave it how it is. I assumed I was going to buy the proper oem oil.
Old September 26th, 2019, 08:49 PM   #6
BoBO
BoBO's Avatar
Well I don't know how much you weigh? But the Ninja 250/300 forks tend to be on the spongy side of the spectrum. I'm about 155 lbs and I find it too soft for daily and track. My preload adjusters does help a bit will have them rebuilt soon though with maybe a custom setup.
If you like the stock setup that's good for you it's cheaper that way. Thicker oil helps make the forks firmer along with aftermarket springs and valving.
94 900RR
Old September 26th, 2019, 08:57 PM   #7
paqmanbiker
I'm 160, and I don't go to the track, and I havent really ridden any other sport bike so I just don't have much of an opinion. Just want to save money, not make changes and keep it pretty stock.
Old September 26th, 2019, 09:25 PM   #8
You can always get OEM seals: https://www.ronayers.com/oemparts/a/...646/front-fork
Or go with All Balls:
https://www.allballsracing.com/56-123.html
Note installation requires some precision. A lot of reports of incompatibility or durability issues comes from sloppy and lazy installation mistakes (hammer & screwdriver not proper tools for removal and assembly).
Old September 27th, 2019, 04:50 AM   #9
paqmanbiker
Thank you! Yeah I'm still not entirely sure I want to do it myself or not. I found the writeup here to be very helpful, and I'm always very careful, but yeah I don't want to screw anything up and just cause myself more costly repairs.
Old September 27th, 2019, 09:16 PM   #10
BoBO
BoBO's Avatar
You definitely bought the right bike to save cash! Are you leaking oil or is something wrong with your forks? Its like $300 to have a rebuild done.If you're leaking oil just get motion pro fork savers.
94 900RR
Last futzed with by BoBO; September 27th, 2019 at 11:25 PM.
Old September 27th, 2019, 09:37 PM   #11
paqmanbiker
Well I just noticed one fork is completely clean, the other has oily dirt and residue up on the tube. So I assumed the seal had gone bad and oil was leaking out. I think I am going to try something like those seal mates to try to clean the seal out and see if maybe it is just some dirt trapped in there causing the leak. At least before I go spending money and/or time on new seals.
Edit: Just got a couple pics. Here is the good fork:
And the leaky one:
Old September 27th, 2019, 11:24 PM   #12
BoBO
BoBO's Avatar
My 250 looked like that when it was leaking oil. The motion pro fixed the leak after a few try's it took only a few minutes. Once in a while I'll clean the area where the seal meets the fork.
94 900RR
Old September 30th, 2019, 06:50 AM   #13
paqmanbiker
Thanks, yeah after this thread I've decided to try the seal mate first and just give it a good cleaning.
DIY- Replace fork seals, dust seals and fork oil shortstuff 2008 - 2012 Ninja 250R Tech Talk 212 November 6th, 2023 10:53 AM
Pre Gen Fork Seals?? Dsheumaker 2008 - 2012 Ninja 250R Tech Talk 3 March 27th, 2015 04:59 PM
Fork / dust seals from EX500 D Graugaard 2008 - 2012 Ninja 250R Tech Talk 2 February 4th, 2013 10:33 AM
Fork Seals for 2009 Ninja 250R slowninja 2008 - 2012 Ninja 250R Tech Talk 3 November 8th, 2012 01:05 PM
