Old May 7th, 2020, 12:11 AM   #1
bseos
Motorcycle(s): 2013 Kawasaki Ninja 300 ABS
Yoshimura Rearset Bracket Ninja 300 (2013) - Need Replacement Shift Link Rod R-K8SR15
I have previously had the Yoshimura Rearset Brackets installed on my Kawasaki Ninja 300 ABS 2013 but had taken them off for when my brother was learning on it. Now want to put them back on, however I no longer have the four socket bolts and more importantly the shift link rod.
I've already ordered some "M8 (8mm) x 20mm Metric Allen Screws" on eBay and picked up some 8mm washers to go with them.
However I'm having difficulty finding the size/length of the shift link rod. The part number is listed as R-K8SR158SS in the installation manual.
Does anyone know of it's dimensions or of any other part that could do the same job?
Hmmm, one time I didn't have time to wait for stuff to come in due to race that weekend. What I did was just cut head off 20mm bolt and welded threaded section to existing rod.
Eventually these showed up. Both ends were right-hand threads, but once adjusted to proper length, no need to change. So no big deal. Got two complete sets of rods + ends for about U$D 8.50 each. One set on bike and spare in toolbox.
http://www.ebay.com/itm/172252462236
http://www.ebay.com/itm/352063383949
I was able to actually help guy in Expert 250 class who blew up his R3's engine on Sat. and needed bike on Sunday. He bought used N250R from another racer and needed to replace shift-rod. Luckily, I just happen to have one he could use for Sunday's race.
This^ previous post by DannoXYZ seems promising. However I still will need to know the length of the Shift Link Rod from the Yoshimura Rearsets before i know which one to order.
If anyone knows the dimension of theirs or can give it a quick measure I'd greatly appreciate it.
Last futzed with by bseos; May 7th, 2020 at 05:51 PM.
bseos is offline   Reply With Quote
Old May 7th, 2020, 09:38 AM   #2
Topaz
Topaz's Avatar
I have the Yoshi brackets in my N300. They came with the bike when I bought it used. I assume the shift rod is the Yoshi one. And if it isn't, I guess it's long enough. I have the rear sets in the most rear and highest position and the shifting works fine.
It's kind of hard to get a precise measurement with the rod on the bike. Specially because it's screwed into the two 'terminals' where it goes.
Anyways, I just measured 17.5cm from terminal center to terminal center. And I measured 13cm as the visible part of the rod. Hope it helps.
Old May 7th, 2020, 11:37 AM   #3
What you can do is install rearset and position everything how you like it. Then zip-tie/duct-tape ball-joints rotated to proper angle. Measure gap between them. Add 3cm and that's your desired rod-length.
Old May 7th, 2020, 11:49 AM   #4
Topaz
Topaz's Avatar
Yeah, the 'ball joints'! That's what I meant by 'terminals' LOL. Thanks Danno.
Old May 7th, 2020, 05:30 PM   #5
bseos
Thanks mate, greatly appreciated.
I'll give that a go too, thank you.
Old May 8th, 2020, 12:49 AM   #6
