Old June 14th, 2020, 10:28 PM   #1
Frank Bernardo
Motorcycle(s): Ninja 300
My Ninja 300 leans too much on kickstand
Just bought the bike today. Great bike except the bike looks like it leans too much on the kickstand and when I put a 1 inch spacer under the kickstand, it leans less and looks normal. The bike has never been down. If my kickstand was one inch longer, I would be happy. What can I do? I'm not a welder to add 1 inch to the bottom of the kickstand.
Frank Bernardo is offline   Reply With Quote
Old June 15th, 2020, 05:18 AM   #2
I don't know that particular stand since I have a 250, but put it on the center stand and take a look at the pivot bolt to see if it's tight. Also feel the play of the stand to see if the pivot it worn badly, and see if the stand is bent. You can then attack the problem(s) you find.
Welcome to the board, Frank!
Old June 15th, 2020, 06:37 AM   #3
Frank Bernardo
The2014 Ninja 300 doesn't have a center stand, the kickstand doesn't look bent, there doesn't seem to be excessive play at the top of the kickstand. The bike just leans at a terrible angle. The bike has never been down, and the guy took excellent care of the bike. If I knew of another kickstand that was a little longer, I would find that one, somehow. They only seem to sell adjustable kickstands that are for bikes that have been lowered.
Old June 15th, 2020, 10:21 AM   #4
You can drill some holes through kickstand pad and screw in an aluminium block underneath.
Old June 15th, 2020, 10:28 AM   #5
Frank Bernardo
It could work! Thanks
Old June 15th, 2020, 05:23 PM   #6
Frank Bernardo
Fixed the kickstand!
Thanks guys for the suggestions. I went looking for a piece of aluminum at Home Depot. Couldn’t find anything I needed. Passed the wood tool aisle, and my
McGiver mind found this aluminum square and the rest is history! Cut a chunk off of it and now it’s on my kickstand.
File Type: jpg 4FA9EF26-6952-4A89-A323-C8A823FBF558.jpg (69.4 KB, 9 views)
File Type: jpg A5424371-F4A6-4FEA-9CFB-43A9C82228ED.jpg (72.3 KB, 9 views)
Old June 15th, 2020, 05:49 PM   #7
Ceeloo Yello
Motorcycle(s): 250
I wonder if your bike has a taller tire than stock? I have that same problem on my 250 which has taller than stock pirellis.
Old June 15th, 2020, 06:00 PM   #8
Frank Bernardo
I’ll check that! I wonder what the stock tires should be?
Old June 15th, 2020, 06:05 PM   #9
Frank Bernardo
They’re stock size 110 front 140 back
Old June 16th, 2020, 05:18 AM   #10
Stock aspect ratio too?
Old June 16th, 2020, 06:41 AM   #11
Frank Bernardo
Yep!
[motorcycle.com] - Kawasaki is Developing a Slingshot Competitor That Leans Ninjette Newsbot Motorcycling News 0 May 27th, 2020 11:25 AM
[visordown.com] - Rider leans too far and lowsides into another biker... Ninjette Newsbot Motorcycling News 0 April 16th, 2018 04:25 AM
A trike that leans to turn like a bike and...........flies like an autogyro !!! Motofool Videos 17 January 20th, 2013 11:50 AM
[hell for leather] - TreMoto Monstrosity leans into the future Ninjette Newsbot Motorcycling News 0 May 24th, 2010 02:30 PM
