Old October 6th, 2020, 03:06 PM   #1
Hollywood314
Motorcycle(s): 2008 Kawasaki ninja 250r
Layed it down trying to fix damage
Hey guys, in a little bit of a jam trying to fix the damage I did after laying my bike down gently. LOL my question is I had to replace the blinkers and now after replacing them they turn on but they don’t blink. Sidenote had to replace the left control switch as well. I need direction on trying to find out why they won’t blink? Again they do turn on they just don’t blink And headlights won’t turn on. Thank you in advance
Hollywood314 is offline   Reply With Quote
Old October 6th, 2020, 03:34 PM   #2
Hi Steven! Welcome to Ninjette!
Turn-signals not blinking can be caused by failed flasher-relay or bypassing flasher-relay (troubleshooting step).
Did you replace left-hand controls with OEM unit?
Or aftermarket? If so, which one?
As test, plug in your old left-hand controls and see if blinkers flash?
Last futzed with by DannoXYZ; October 6th, 2020 at 05:50 PM.
Old October 6th, 2020, 07:51 PM   #3
Hollywood314
Dannoxyz
I did replace the left control switch with OEM part. Unfortunately the old blinkers are toast.
Old October 6th, 2020, 10:03 PM   #4
Hi, no I mean plug in old left-hand control switches. Then see if they work properly to make new blinkers work.
Since you changed two things at once, it’s not possible to determine which change caused non-blinkiness. So... undo just one change to test. Easiest to unplug new control switches and plug in old one temporarily to test.
Heck, it’s possible there’s 3rd change in system. Crash very well may have damaged your flasher relay. After all, it is mechanical part. Put your ear on it when activating turn-signals. Does it click or make buzzing sound? Try tapping it with screwdriver to see if it wakes up. If it doesn’t click, then most likely it’s died, kaput!
[motorcycle.com] - Polaris Slingshot Recalled to Fix Problem Caused by Fix to Previou Ninjette Newsbot Motorcycling News 0 June 12th, 2017 01:30 PM
So, first time out my wife layed it over! bshelton 1986 - 2007 Ninja 250R Tech Talk 12 November 15th, 2013 07:42 AM
Layed over my 250 at 35 mph RebelRider !%@*#$%!)@#&!%@ I crashed! 17 July 25th, 2012 07:55 AM
So I layed down my bike today =( Robinhood !%@*#$%!)@#&!%@ I crashed! 25 February 23rd, 2012 11:40 AM
How can I fix this? the big mike 2008 - 2012 Ninja 250R Tech Talk 18 August 25th, 2011 10:23 AM
