Old October 23rd, 2020, 07:30 AM   #1
Kotello
Motorcycle(s): Ninja 250r 2008
Question 2008 Ninja issue
Hi there,
I was wondering if anybody has ever had the problem with their ninja 250 like I do now
The bike starts, when in idle runs for a minute or two and then it dies. When I keep the revs up, it's ok.
It doesn't sound like it used to, sounds more muffled and dry.
Also, when I drive it in that condition, the bike is pulling, sort of like if it didn't have any fuel left.
There was a white smoke going out of the exhaust for like a few seconds as well.
I will take off the tank and see if it has anything to do with the throttle.
Any ideas? I would appreciate any suggestions!
Thank you!
Kotello is offline   Reply With Quote
Old October 23rd, 2020, 07:45 AM   #2
Have you checked the condition of the air filter and airbox for oil?
Is the tank clean inside? Have you checked the filter at the carb inlet?
Have the carbs been synced, and idle mixture and idle speed adjusted?
Have the valve clearances been checked recently?
How old is the gas?
Old October 23rd, 2020, 08:29 AM   #3
White smoke is not good sign. What’s it smell like?
Do you have choke turned off after first couple minutes?
Do compression-test when you get chance.
Last futzed with by DannoXYZ; October 25th, 2020 at 08:14 PM.
07 ninja 650R clutch issue VanGhost General Motorcycling Discussion 11 February 12th, 2017 08:01 AM
2008 Not starting - battery issue? Ash 2008 - 2012 Ninja 250R Tech Talk 8 April 14th, 2015 08:51 AM
Idle issue 2008 250 TS250 2008 - 2012 Ninja 250R Tech Talk 8 February 7th, 2014 09:50 PM
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue Ninjette Newsbot Motorcycling News 0 May 11th, 2010 07:50 AM
Have a lean issue with my bike, issue with coasting enricher. twiggy2cents 1986 - 2007 Ninja 250R Tech Talk 7 February 24th, 2010 06:54 PM
