Old November 24th, 2020, 03:12 PM   #1
pjed
pjed's Avatar
Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900
What system is this?
Just picked up an 09 250 and it came with a extra full exhaust system. It has no markings on it and is missing the clamp. Curious if anyone on the forum can tell what it is.
pjed is offline   Reply With Quote
Old November 24th, 2020, 03:17 PM   #2
can you post photo showing 2-1 transition? Y or U shape will tell lots about manufacturer.
It appears to have sudden jumps in diameter instead of using cones. Welds have look like they were squeezed out of toothpaste tube.
Old November 24th, 2020, 04:15 PM   #3
pjed
pjed's Avatar
Here's a pic of top and bottom of where it goes 2-1.
Old November 24th, 2020, 04:53 PM   #4
U-shaped joint formed by bending tubing instead of using proper merge collector. That's Area-P exhaust.
Old November 24th, 2020, 05:40 PM   #5
pjed
pjed's Avatar
That doesn’t sound very positive on Area-P...thought they were one of the best? I’ve had a couple Tyga full systems on my 250s which I really liked. Figured AP would be at least as nice.
Old November 24th, 2020, 05:54 PM   #6
pjed
pjed's Avatar
Looked again real close at the can. There’s absolutely no witness mark from any kind of badge. That’s what made me think it was some kind of cheap knock-off.
Old November 24th, 2020, 10:32 PM   #7
Badges are simple stickers. Easily removed when hot and adhesive marks removed with alcohol. I have exact same system in box somewhere.
While Area-P is one of best, Tyga is the best. Dyno charts shows Tyga making ~1.5 bhp more. Ninja 250 is tiny market for Area-P here, so they've rightfully limited R&D and went with cheaper-to-make design. Tyga has much larger Ninja 250 market in Asia with much more discriminating customers. So they've got better design which results in more costly manufacturing (might even have some robotic welding done, or some damn good extremely skilled welders). They do cut some costs going with cheaper 409-stainless instead of prettier 304.
Check out my Exhausting Tale thread for comparisons. They're both quite good, about 90-95%. Only change I'm going to try is reverting back to pre-gen header interface to head so that pipe doesn't have to protrude into already-small port and narrow down even more. I'm not fan of spring & loop method of attaching muffler, looks too busy. So I would use split tube with bolt pulling it together like older bicycle seatpost clamp.
Last futzed with by DannoXYZ; November 27th, 2020 at 07:25 PM.
Old November 25th, 2020, 09:48 AM   #8
pjed
pjed's Avatar
While Area-P is one of best, Tyga is the best. Dyno charts shows Tyga making ~1 bhp more. Ninja 250 is tiny market for Area-P here, so they've rightfully limited R&D and went with cheaper-to-make design. Tyga has much larger Ninja 250 market in Asia with much more discriminating customers. So they've got better design which results in more costly manufacturing (might even have some robotic welding done, or some damn good extremely skilled welders). They do cut some costs going with cheaper 409-stainless instead of prettier 304.
Interesting stuff...thanks for your input! Going to email Area-P to see if I can get the clamp, decal and whatever else I'm missing. Regretting selling my last full Tyga system now. Maybe if I see another one pop up for sale, I'll snag it.
Old November 25th, 2020, 04:06 PM   #9
let me dig through by boxes. Might have clamp for that muffer somewhere. I sold muffer while back, not sure if clamp went with it.
Old November 27th, 2020, 08:29 PM   #10
Sorry, no muffler-clamp. It went with muffler I sold.
In pinch, I've used big hose-clamps.
Old November 28th, 2020, 08:50 AM   #11
pjed
pjed's Avatar
No worries...thanks for checking!
Cooling system help acook3323 1986 - 2007 Ninja 250R Tech Talk 24 April 10th, 2017 05:54 PM
Get yourself a SONOS system! Joshorilla Off-Topic 1 October 30th, 2013 08:36 AM
Brake system help! james.gravley 2008 - 2012 Ninja 250R Tech Talk 12 August 20th, 2011 07:35 PM
Anyone seen or tried this luggage system? bob706 Cargo Space 1 July 7th, 2011 05:16 PM
