Old December 31st, 2011, 04:52 PM   #41
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Originally Posted by sombo View Post
Need more proof?
No I think that proves my point perfectly. From mounting point to mounting point, is considerably longer than 2mm difference. If I had to eyeball it, I'd say it's closer to 7-8 mm differrence.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old December 31st, 2011, 04:58 PM   #42
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
That came from ninja250.org where they measured it to be 2mm from mounting point to mounting point.
Mounting specs are almost identical. The top fitting is 0.5mm less wide on the EX250J. That could easily be due to one of the fittings being out of spec, or having been slightly bent. The other spec difference is that the EX250F shock is 2.0mm less tall (from center/center of mounting holes). It's likely that the '06 EX250F shock settled while in use and that they were closer to identical when new.
To me that looks about right.
sombo is offline   Reply With Quote
Old January 1st, 2012, 11:55 PM   #43
abhijitz
Motorcycle(s): Many Two Wheels ..
cool. thx a lot for the pics. my buddy is going to lend me his old gen to try the penske and i will swap it out and take some pics. will measure static & rag sag and report back ..... It also has revalving done @ front , so i need to see if i can swap it out with mine. He is practically giving me the bike for stupid low money. hhhhhhhhhhh
abhijitz is offline   Reply With Quote
Old January 2nd, 2012, 04:04 PM   #44
copperaxe
Deviant Gentleman
copperaxe's Avatar
Motorcycle(s): two wheeled motorcycles
I hope the Penske works for you. I see you have the Ninjette listed as track and race. Have you changed the wheels over yet?
copperaxe is offline   Reply With Quote
Old January 2nd, 2012, 09:01 PM   #45
abhijitz
Am running a 2010, so oem 17" wheels, do not have much options to play around with production class
Old April 27th, 2012, 09:30 AM   #46
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
So I busted up the motor in my 2009 250 race bike.. I wonder if the old-gen engine will fit into the frame....
Rexbo is offline   Reply With Quote
Old April 27th, 2012, 10:17 AM   #47
Pretty sure the frame caps fit. The swingarm joints they cover can be swapped pregen chrome ones can be seen on the prototype newgen in the user and service manuals.
Old April 27th, 2012, 12:00 PM   #48
copperaxe
Deviant Gentleman
copperaxe's Avatar
Rexbo,
I think you can bolt the old gen motor in if you obtain the front motor mounts. The guy who bought my old gen Ninjette actually did the opposite by using a new gen motor and he mentioned that the motor mounts are different there because how they mount to the engine.
And FYI... Brian Bartlow had told me that it is critical to always fill your oil to the top of the window (above the top fill line) to help preserve the bottom end. Also I confirmed that the deeper sump pick up on the new gen bolts to the old motor too, for extra insurance against oil deprivation. If you have the engine apart, make sure you do the necessary grinding for the oil mods, which give big rewards in longevity.
Good luck!
Old April 27th, 2012, 03:51 PM   #49
Rexbo,
Good luck!
Custom exhaust headers, I imagine?
Old April 27th, 2012, 04:00 PM   #50
not really THAT custom. Check out the headers Eric made:
http://www.ninjette.org/forums/showthread.php?t=96567
these could be used with the oem pregen exhaust if desired.
Old April 27th, 2012, 04:08 PM   #51
Ah. I just remembered the thing about the engines being mounted at different angles and, thus, the exhaust ports did not align but an aluminum gasket explains it.
Last futzed with by CZroe; April 27th, 2012 at 06:17 PM.
Old April 27th, 2012, 05:44 PM   #52
copperaxe
Deviant Gentleman
copperaxe's Avatar
Yes, the headers are different in fit and performance. Check out the threads regarding Area P exhaust; the one for the old gen motor was notably different to extract the best performance from that engine.
Old June 5th, 2012, 10:29 AM   #53
JLinde1339
Fighterer in Training
JLinde1339's Avatar
Motorcycle(s): 2001 Ninja 250R
Does anyone know if a tail swap is possible? New gen tail on a pregen frame?
JLinde1339 is offline   Reply With Quote
Old June 5th, 2012, 11:04 AM   #54
sombo
sombo's Avatar
Not unless you do your own welding. You would have to swap out the rear framework to do a tail swap. Besides, it would look all kinds of wrong with the old front combined with the new tail. Not sure what you would be trying to gain from it either.
http://mefi.us/images/fuelly/sig-us/112292.png
Old June 5th, 2012, 11:48 AM   #55
JLinde1339
JLinde1339's Avatar
I'm looking to update the look of the tail. The pregen tail is so dated looking. And theres no front that it needs to match to. Just wondering before I went thru the trouble of trying to fab one from scratch. I was looking at the parts diagrams for both, and the sub frames look pretty close...
Old June 5th, 2012, 12:23 PM   #56
Update the rear fender, then the front end. Until those are taken care of, I wouldn't even THINK about the tail.
I'm planning a group buy on the Airtech upper and lower fairings for the pregen, if you're interested. I also have some ideas on how to update the headlight and windscreen areas.
Old June 5th, 2012, 12:51 PM   #57
JLinde1339
JLinde1339's Avatar
Thanks for the offer, but I just need the tail. Thats the only piece of plastic on the entire bike. No fairings, no fenders, no nothing. Would just like to put something a little more modern looking back there, and hopefully update the seat from the banana seat to a solo butt pad.
Old June 5th, 2012, 01:38 PM   #58
Then you still might want to get in: Airtech sells a solo seat cowl as well. Also, CustomSeatCreations.com sells seat covers with false cowl lines.
Old June 13th, 2012, 09:17 PM   #59
OK, I tried my newgen clutch lever on the pregen and it seems to fit perfectly.
The only notable difference other than the pregen lever having ugly knuckle nubs is that the pin it pivots on goes through and threads into the perch on a pregen and a loose nut on the underside with the newgen. The pin is the same size except for the threaded tip, so they fit either lever. If you lost the pregen pin and had a newgen one, it still extends out the bottom to thread the nut on because the threaded part is a smaller diameter.
Old June 15th, 2012, 01:50 PM   #60
easiest way to make the tail look better is to raise it. Mucho sexyo
Old July 3rd, 2012, 10:01 AM   #61
JLinde1339
JLinde1339's Avatar
Yeah, working on that too. Its the banana seat that bugs me. I want to replace it with a single seat, but want a better looking tail on it. Right now, got no tail on her
Old July 3rd, 2012, 07:22 PM   #62
Then get a Custom Seat Creations seat cover with a false cowl line.
Old July 28th, 2012, 07:12 AM   #63
alley
Motorcycle(s): 1999 ex 250
Anyone know if a new gen gas tank will fit on a pre gen frame? I'm not worried about the plastics.
alley is offline   Reply With Quote
Old July 28th, 2012, 07:23 AM   #64
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
look up air tech. They have a race cowl for the pre-gen. That's about your only pre-made choice. Everything after that is up to you.
dirty nasty is offline   Reply With Quote
Old July 28th, 2012, 09:42 AM   #65
There's a seller on eBay that makes them (gel-coated fiberglass). His have all the mounting holes.
Old July 28th, 2012, 09:49 AM   #66
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
seller name? link?
please
iplante is offline   Reply With Quote
Old July 28th, 2012, 09:57 AM   #67
Originally Posted by iplante View Post
seller name? link?
please
http://myworld.ebay.com/hks_parts/
This guy. I don't see it listed anymore but he just shipped mine two days ago (I got mine custom-made with all the holes filled in).
Edit: Oops. Actually, it's this guy: http://www.ebay.com/itm/EX250-EX-250...item3f1a477aec
Last futzed with by CZroe; July 31st, 2012 at 03:49 PM.
Old July 28th, 2012, 10:25 AM   #68
iplante
iplante's Avatar
Thanks!
Post pics when you get it
Old July 28th, 2012, 02:05 PM   #69
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '12 Ninja Kaw, '22 CFMOTO 300NK
Thanks!
Yes! I second this!
jcgss77 is offline   Reply With Quote
Old July 28th, 2012, 03:15 PM   #70
It didn't fit out-right, but there is one member who fabbed it to fit.
Thanks!
Will do!
Old July 29th, 2012, 06:49 AM   #71
alley
I can't seem to find it. any help?
Old July 29th, 2012, 10:03 AM   #72
Trust me, I was already looking for it and frustrated that I couldn't find it, but I kept looking and finally got results:
http://www.ninjette.org/forums/showthread.php?t=47456
Unfortunately, his picture host is gone. He continued responding after that, so hopefully he still has them.
Old July 30th, 2012, 07:03 PM   #73
Monkeytofu
I told you bro
Monkeytofu's Avatar
Starter Solenoids look to be exactly the same.
Old July 31st, 2012, 03:48 PM   #74
Oops. I was wrong. Here is the seller:
Ask him if he still makes a cowl, tail, etc. I know he doesn't make the lower anymore.
Old August 17th, 2012, 01:08 PM   #75
Lychee
sail away
Lychee's Avatar
Here is the guy to contact if you want a very simple way to mount 17" wheels on your old-gen Ninja250...
His name is Jeff, he races with WERA, jjuskowich@hotmail.com
I believe he charges $150 for the whole kit (front and rear). So a person could quite simply buy a kit from Jeff, buy a set of wheels and tires, then bolt them on, torque and saftey wire as needed.
The stickiest tires available for the old-gen bikes too, as simple as that!
Out of curiosity I emailed Jeff to confirm this and here is his reponse:
Hey Jon,
Attached are some pics with the 17s and also the parts that you will need; which is a new front brake bracket to offset the caliper to line up with the new gen rotor, modified rear brake bracket and torque link, and also new front wheel spacers. Other than the wheels (with rotors), that will be all that is needed, you will reuse the original stock rear wheel spacers.
If you would like me to make the kit for you, I have been asking $150 plus shipping, but I will need the parts to make the kit.
I will need your stock front caliper bracket, rear brake bracket and torque link (silver parts in pic), and two front wheel spacers (2x the one in the pic).
If you don't want to give up your stock parts, then I can get them off ebay for an additional $50. Some of the guys have been going to junkyards to get the parts for me also.
Let me know if you're interested.
File Type: jpg new front brake bracket to offset the caliper to line up with the new gen rotor.jpg (33.5 KB, 23 views)
File Type: jpg modified rear brake bracket and torque link.jpg (120.7 KB, 25 views)
Old August 17th, 2012, 01:12 PM   #76
Lychee
sail away
Lychee's Avatar
Could you take pictures of the new gen clutch lever on the pregen? I emailed someone who sells both gen levers and their response was that the new ones would not fit. They do look very similar in the photos though.
Old August 18th, 2012, 11:03 AM   #77
Nothing is mounted yet so remind me if I don't get back to you soon!
Old August 23rd, 2012, 02:41 PM   #78
Monkeytofu
I told you bro
Monkeytofu's Avatar
Anyone know if a manual cam chain tensioner for the new gen will fit our pregen bikes?
Old February 19th, 2013, 11:27 AM   #79
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
Maybe I missed it. Are the handlebars interchangeable?
cookiebug79 is offline   Reply With Quote
Old February 20th, 2013, 12:27 PM   #80
Nope. The height is about the same as the bars used on the 300 and J/K 250s, but the risers are different lengths because the bases sit differently with the triple. The newer bikes have a bar riser base that sits on top of the flat triples while the F bike's triple is staggered so that the bar riser base is flush with the rest of the triple. The base size and bolt spacing is different, so they won't simply sit lower when used on an F-bike.
The OEM tensioners are pretty different, so I doubt it.
Pre-Gen Parts for sale wardie Motorcycle-related 1 November 20th, 2013 05:05 AM
FS: Pre-gen random parts Singh2jz Motorcycle-related 32 May 21st, 2013 12:07 PM
are any pre gen parts compatible with the new gen Jordan91 2008 - 2012 Ninja 250R Farkles 1 April 22nd, 2012 09:15 PM
need some pre gen parts dbking321 Items Wanted 0 March 14th, 2012 09:45 AM
Pre Gen (88-07) misc parts expat Motorcycle-related 9 January 26th, 2012 12:15 PM
