October 12th, 2013, 03:03 AM | #1 |
Join Date: Oct 2013 Motorcycle(s): Kawasaki Ninja 250r Posts: 4
turn signal issue, help plz
hi all
so my front left turn signal isnt working, the rear and indicator are solid. the right ones and indicator blinks with the right ones. I thought, thats easy, volts are plitting equally so ill change ill change the front bulb and everything will be ok. I got two signal bulbs (for future use) from the local dealarship and snapped one in on the front left signal. Sadly that didnt work after doing some research I heard some say that there is a ground problem (which as a newbie i have no idea what this is), some also say that the female wiring is not connected so i opened the signal up and checked for any loose wires, no no everything is perfect from the signal side. As I know, if the fuse is burnt, neither signals would work, so at this point, is it a technicians job, or is it something that can be done at home. BTW if you meantion something, please get into details im like a 12 yrs old studying Calculus |
October 12th, 2013, 03:21 AM | #2 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
I was just about to make a thread on this. Left front/back turn signals work fine, but my right front doesnt work and my right back signal stays solid.
Hope we can get an easy solution D: |
October 12th, 2013, 03:34 AM | #3 |
disclaimer: not an electrician or an expert but this is what I think I know. mods please edit if information is incorrect
so the battery has a positive side and a negative side. each one connects to either pole of whatever you want to power. the negative side is often wired to the frame - instead of running a positive wire and a negative wire to whatever you need, you just run one and connect the other side to a ground, it makes it loads easier. if something is touching the frame and grounding itself at a point before it reaches the bulb, it'll go the path of least resistance instead of lighting up the bulb. so you can have a perfectly good bulb, perfectly good relay, but a stray wire can cause problems. |
October 12th, 2013, 04:03 AM | #4 |
before getting a bulb just test it on the other side and see if it works, if it doesn't work, then a new bulb should fix your problem. if it worked, stay tuned on this thread maybe we'll find a good way to solve the problem.
October 12th, 2013, 04:13 AM | #5 | |
what do the others think about it? |
October 12th, 2013, 05:49 AM | #6 |
The issue is somewhere in the circuit for your front L (or the front R for @Aggrotech). Either the bulb is bad (you said you eliminated that) or there is a loose connection. Since that one is not working, there is not enough load on the circuit to operate the thermal flasher which is why the rear stays on but does not flash.
As you said, try a known good bulb from the other side and see it that does it. If not, pull the fairing and check all of the connections between the bulb and the fuses. If you have a meter, the job is a lot easier. If you don't, go buy one, even a cheap analog one for like $10 will work. They are pretty easy to operate, way easier than Calculus.
"We're not always doing business, but we're always open." "For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan Last futzed with by red5; October 12th, 2013 at 09:10 AM. |
October 20th, 2013, 11:09 AM | #7 |
Wannabe Reborn
Just had similar issue on my 08. I pulled fairings and did a bunch of work, and when putting back together was finished, I checked turn signals. Right side both front and back blinked, but left rear stayed on solid, left front didn't do anything. I guess when I was plugging that connector back in, I must ahve pulled too hard, and one of the terminals inside the turn signal housing came apart, opening the circuit. I plugged that back in, and everything was good.
Check your connections. Swap your bulbs. It's one or the other.
turn signal tail light mod help plz | BukkShot | 1986 - 2007 Ninja 250R Tech Talk | 3 | March 18th, 2015 08:44 PM |
Turn Signal issue, looking for opinions | ArsnlTim | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 2nd, 2013 02:47 PM |
Stock turn signal issue | sshikari | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 25th, 2012 04:59 PM |
Turn signal issue... | YMCMB | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 21st, 2012 04:58 PM |
Throttle issue HELP plz | Shaol1n Monk | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 19th, 2011 08:43 PM |
