Old February 20th, 2018, 08:54 AM   #1
AubreyGuad
Will not run properly.
I have had the carbs off, and THROUGHLY cleaned. I put new needle valves, idle screws, springs, and o-rings in them. Runs with the choke but does not want to run on its own. I have tried to adjust the idle screws in the carb to get it to run, but it still doesn't want to. When I put the carb back together, I did my homework and turned the idle screws out 2 1/2 for staters. When adjusting after the bike warmed up, I had them almost completely out and it still did not want to idle by itself. So I am not sure if my issue is on the carb? Could I possibly have a vacuum issue, if it does not want to pull fuel? Tried to figure this out all afternoon yesterday.
Mind you this bike has been through some things with previous owners, so I did not get it in the best shape either.
AubreyGuad is offline   Reply With Quote
Old February 20th, 2018, 09:37 AM   #2
My first guess is that when you were cleaning, you missed seeing some little passages somewhere in the idle circuits.
Old February 20th, 2018, 09:39 AM   #3
That sounds like the idle mixture passages may be plugged (like TJ said...).
Can you get it to run by opening the throttle slightly? You may need to adjust the idle speed screw. Syncing the carbs, once it will run, is also a good idea.
You can check that you have fuel in the floatbowls by opening the drains and catching the gas. The amounts should be the same with no signs of water or debris.
There is a filter at the carb inlet that can get plugged, and the petcock needs vacuum to open and flow fuel.
To check for a vacuum leak, spray carb cleaner around the boots between the carb and engine and listen for a change in RPMs.
Old February 20th, 2018, 11:23 AM   #4
Did you confirm and measure flow-rate through each of the secret passages? Needs flossing with wire and soda-blasting to really clean. Carb-cleaner will not dissolve dried gas varnish that has turned to plastic.
Originally Posted by n4mwd View Post
Here are the secret passages in the carbs. They are kindof hard to figure out sometimes and this picture guide will show where they are for cleaning purposes.
Carb Pilot jet Circuit
Carb Main Jet Circuit
Carb Fuel and Overflow Drain
Carb Diaphragm Intake, upper choke and vacuum ports
Carb Choke Circuit
01 Ninja250 not starting properly petersophy 1986 - 2007 Ninja 250R Tech Talk 3 August 29th, 2014 08:52 PM
Ninjette suddenly won't idle/run properly... infinitethrill 2008 - 2012 Ninja 250R Tech Talk 29 April 15th, 2012 02:03 PM
Oil leaking out of airbox bike wont run properly peeweecollins General Motorcycling Discussion 18 July 9th, 2011 10:05 PM
Bike doesn't run properly after sitting only 2-3 days shiftdrift06 1986 - 2007 Ninja 250R Tech Talk 15 April 23rd, 2011 05:06 PM
