#1 |
Join Date: Jan 2013 Motorcycle(s): 2008 Ninja 250R Posts: 15
H7 LED Headlight options vs HID
I've had a 33W 6000K HID kit on my 08 250R for awhile now and it sucks. Doesn't light up the roadway all that great. I've been looking around for alternatives and so far I have several options but I would like to hear, from those who actually have used these options sv those who speak based on hear say.
-First up is a 55W 5000K HID setup running dual bulbs in a H7. Who's used this setup and how is your night riding with and without tinted/dark visors? -Second up is LED H7 Headlight bulbs: * http://www.cafehusky.com/threads/led-headlights.38304/ * http://m.ebay.com/itm/261417237344?nav=SEARCH * http://m.ebay.com/itm/171250619739?nav=SEARCH Thanks! ![]() |
#2 |
You should use 4300k. The higher the number the less the road is going to be visible.
#3 | |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
if it sucks that bad. grab some led floodlights and put them at the front cowl is where the yellow reflective indicators go. http://www.jaycar.com.au/productView.asp?ID=SL3915 like cbr250r http://www.youtube.com/watch?v=ezxmDWgFdBs |
#4 |
You need a true HID setup besides those cheap bulbs and ballast setup. Bkmoto has a semi plug and play setup and hidretrofitsource has a kit that requires modding. HID bulbs require proper projectors, angles, and shields to put out the proper light scatter.
Phillips Motovision has a great halogen bulb which I use.
#5 | |
"scandal!"
#6 |
Sounds good. I'll look into these options. Thanks folks
#7 | |
You can use halogens in halogen projectors or halogen reflectors. Look at the new Ford Explorers, etc with halogen projectors. Halogen reflectors are nothing new. You can use HID bulbs in HID reflectors or HID projectors. Look at older Prius's with HID reflectors or many BMW's/Audi's withd HID projectors The difference in halogen vs HID and reflector vs projector lies in the light source. HID bulbs and halogen bulbs do not put out light in the same manner and therefore require different methods of controlling the output. HID's are an arc-based light source, while Halogens are a filament based light source. The 'hot spot' of the bulb is in very different places and is a different shape. This is why specific light controlling hardware is required and why mixing is not recommended. Basically, to get optimum output for your light source, you need hardware that's been designed for it. To use HID bulbs, you need a reflector or projector that's designed for HID bulbs. For halogens, you need a reflector or projector that's designed for halogens. Don't put HID in a headlight intended for halogens. Even if it has a sharp cutoff at the top so you don't blind people, you're going to have uber-bright light in all the wrong places. The easiest way for you to get more light is to either get one of the ultra-effective bulbs (silverstar or similar) and aim it properly or upgrade your wiring harness and get a higher wattage bulb to put out more light (and heat). Hope that helps you. |
#8 |
auxiliary LED lights are a great thing as well. Turn them on when you need them, off when you don't.
I wouldn't touch those LED replacement bulbs though. They look hard to aim. Same argument as the halogen vs HID. it's all in matching the light source with the method of controlling/aiming said light. |
#9 | |
Great information! Thank you! |
#10 |
"scandal!"
#11 |
Join Date: Jan 2011 Motorcycle(s): 2014 Ducati Panigale 899 Posts: 325
I have to agree that getting a color temp closer to daylight will give you much better night visibility and useful light.
Here's my bike, converted from 35W (3Five) morimoto 4300K to Cree 25W per LED (x4 LEDs) 4500k headlights. The HIDs I hade where techniclly brighter but not visibly so. I really wanted to test the new LED technology because I'm a big Cree fan and a former flashaholic. Also regardless of what people may say HIDS willl blind oncoming traffic unless used in projectors or with appropriate glare shields. This is mostly because of the light shining directly from the bulb and not due alignment and reflector issues. HIDs are good for conspicuousness but terrible for oncoming drivers; no amount of re-aiming can reduce this glare, only the use of glare shields will (which I made and used). Priuses with factory equipped HIDs and reflectors utilize glare shields which is why they do not blind oncoming traffic. Some factory halogen housings also include glare shields which can help with HIDs in Halogen housings but YMMV. BTW the housing for the Ninja 250r DOES NOT have any sort of shielding. The LEDs "bulbs" are 180 degree, 25w, two per bulb. They appear much whiter and the beam distribution is much closer to stock. There is no glare due to the fact that no light comes directly off the top of the "bulb" into oncoming traffic. I also like the instant on for the high beam, and white color unlike the halogen that I was forced to use in conjunction with my HID due to the warm up that HIDs need to be useful. As far as not producing glare, the same cannot be said for the LED fogs/driving lights which have a tight focused beam (8degrees or so) but can still dazzle oncoming traffic since the LEDs are directed straight ahead. For this reason I mounted them low and aimed them low. I may still readjust them depending on further testing. The LED fogs are 2x Cree 10W. The headlights are H7 units but again have 2 leds per "bulb". I'm thinking about ordering the H4 ballasts which allows for better control of the bulbs. the idea would be to use both of the upper LEDs per bulb to light as the low beam, and all of the LEDs to light for high. This would get rid of the "your headlight is out" look that having only one side illuminated gives. ![]() ![]() ![]() |
#12 |
4300 is the optimal color temperature for best visible light in the dark. Your eyes mostly use black/white vision at night. Once you start going very blue (6K+), you lose usable light. 5K is a pretty good compromise, but 4300 is the best.
and all that stuff @choneofakind said. |
#13 |
Blind 250 Loving Whore
If you want better lighting you need to pony up. I have 6ks and don't have any issues tho they're more blue than both my cars. You do a proper projector setup and you'll have a really wide field of view with a great beam pattern. Too many people on here slapping bulbs into the stock housing.
#14 |
Certified looney toon
MOTM Jul '13, Jul '14
Question @warlord, where did you get your LED headlights?
![]() Hey Unregistered! The code [you] shows the username currently logged in. ![]() IBA # 56020 AMA # 521481 ![]() Hold yourself to the same rules you expect others to follow. |
#15 |
Those look really cool and are a step in the right direction, but this statement is false. Yes, the open tip on an HID bulb is a part of the problem. But go look at the math behind reflectors. Moving a bulb out of the foci of the reflector ruins the scatter produced by the reflector and requires a different reflector. That's all there is to it.
#16 |
EX500 full of EX250 parts
I'm interested in your LED headlight bulbs too. I'm considering a HID projector retrofit for the 500, but would go LED if I can get brighter, whiter light with less work (and maybe even less cost). The good LED replacement headlights I've seen were $300-$500 each, so I don't trust the really cheap ones, and I've been wary about dropping a decent chunk of money on the ones that appear to be better (but may not actually be any better).
#17 | |
@ NevadaWolf All of the Cree emitters were sourced from eBay. The H7 kits were $47 and I don't recall the cost of the fogs. @ InvisiBill I feel the same way about low cost LED kits but for the price I thought it was worthy of experimentation. I wouldn't have posted anything about my LED headlights experiment except for the utter lack of information available on the web or forums such as these. |
#18 | |
I'd prefer to find one without a fan. I realize that once it's generating a certain amount of heat, you simply need more airflow to cool it down, but I'd rather not have a crappy little fan (based on my experience with computers and other electronics) sitting somewhat exposed on the bike. There's a lot less between the road and the back of my headlight on the 500 than in a typical car, so I'm a little more concerned about stuff (including water) getting kicked up into it. I suppose I could always rig up a huge heatsink contraption that went down to the useless ducts in the fairing... |
#19 | |
I'm on my phone. I don't have time to go find a scholarly source other than my engineering classes and text books. |
#20 |
^correct.
it's not just the exposed bulb that creates the "glare", it's the light that's now bouncing off of the reflector in different directions than designed. Poor beam dispersion IS glare when it occurs above the typical "cutoff" line. Ever have a maglite? understand how you can change your beam pattern by twisting the top? now imagine if that reflector was designed to have a distinct horizontal cutoff. As you twist the top to change the beam pattern, light is going to go everywhere. |
#21 |
But I will admit. There is a lot of glare produced from the top of the exposed bulb vs a capped halogen bulb. There just be glare all over
#22 | |
BTW, how do the photons emitted directly from a light source traveling into the eyes of the observer have anything to do with a reflector they never make contact with? You're really glossing over that one. Or perhaps you can realize we're not even talking about the same thing... but you still keep quoting me. Do you really think I'm wrong, ignorant, or misleading? Sent from my mobile phone. Plaes ingore ny misteaks. |
#23 | |
#24 |
Relax.
1. Think of a filament as a line. It's a long and relatively skinny coil oriented across the reflector. Now, let's assume the drop-in LED IS centered perfectly where the center of the filament normally should be. There's still a problem. That LED is a large circle, not a slim line. Its center is in the correct place in the lens, but there is still a large amount of light emitting area (the yellow patch in your pictures) that is producing light that is NOT in the correct place. All else equal, this will cause glare (and a poorly controlled beam) from the reflector. Do you follow that? 2. I did agree (see above) that there is a lot of glare from the exposed tip of a drop-in HID bulb. I never said you were wrong. I said that is only part of the problem. Unless your headlight hardware is specifically designed for HID bulbs, don't use them. Same goes for LED's. The reflectors for each of those respective light sources simply aren't compatible/interchangeable. 3. A standard reflector is designed to make a 'cutoff'. It won't pass DOT inspection if it doesn't. Drive towards a wall with your car and you'll see a line where there is significantly less light above. Though not as sharp as a proper xenon cutoff, it is still a flat 'cutoff' |
#25 |
@warlord one last thought. Would you take pictures of your light output at a wall and again at a distance? I'm still seeing shine and washed out portions of the pictures, which tells me you've still got glare.
Even with my crummy fluted pregen lens, the bixenon projector controls the light well. It doesn't show any dazzle to the camera until the high beam is on or until the camera is put below the cutoff; and my cutoff isn't even that sharp. |
#26 |
Can confirm, and +1 (2 actually).
#27 |
Which lights are you using on the fork? I use the Mondomotos, but I like the subtle filter on yours.
#28 |
@warlord
It seems as though you already have your mind made up, but I highly recommend you set aside your predisposition and read these articles. http://www.danielsternlighting.com/t...nversions.html http://www.danielsternlighting.com/t...dvantages.html I have engineering instruction and design experience in the design of lighting and luminaires (light fixtures), this is all right up my ally. I don't have time to address every single thing you have to say, but I will guarantee you're probably getting worse light output (poor light dispersion, hotspots, glare) from your setup than the stock halogen setup. An exposed bulb will create some glare, but it pales in comparison to the concentrated light being reflected from every other direction that the bulb emits light. Keep in mind you will be hard-pressed to find a car with a low beam that lacks a shield, and those headlights glare like crazy when you put in HID kits. Modifying any headlight to install a different type of bulb than what was designed is illegal for use on the street. If you chose to break the law, at least due the prudent thing and install something proper. A projector designed for LED bulbs (come stock on corolla and other more premium cars) or HID bulbs (lots of oem and aftermarket options) will likely pass typical DOT tests, even though your headlight is still technically illegal. Last futzed with by dfox; April 9th, 2014 at 05:52 AM. Reason: made less abrasive |
#29 |
#30 | |
#31 | |
![]() I have not assumed anything about your intelligence or experience and therefore have nothing to be embarrassed about. If you have inferred that I am insulting you, I apologize. I will say that some of the information you have provided in this thread is contrary to current lighting engineering practice, particularly the assertion that moving focal points doesn't create glare, only exposed bulbs do. Moving focal points is exactly how high beams function in cars/motorcycles with only one bulb. There are two filaments located in two different spots. Light up one, low beam. Light up the other, high beam (glare). The attached links cover the basics about moving focal points in automotive lighting, including laboratory tests, and how that creates glare. The only reason I posted this information was due to your responses to choneofakind. I would much rather have a discussion regarding the technical merit behind the LED retrofit that you have done than a battle trying to evoke emotional responses. If you would like to provide technical information, I'd be happy to continue this discussion, but until such time, I'm out. ![]() |
#32 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
LED drop in replacement bulbs are a waste of time, I have no idea why they are even made.
A proper HID projector retro fit is the way to go. |
#33 | |
Through debate comes sharing of info and learning by all. Name calling and emotionally charged posts do nothing to contribute to either of those outcomes. Deuces. |
#34 | |
Why do you think that choneofakind needs you to hold his or her hand anyway? He's the one that started off on an incredibly irrelevant tangent and has prescribed positions incorrectly to me in the first place. All you're doing is propagating those incorrect assertions and taking them to a new level. The fact that you're oblivious about what you're doing should be cause for embarrassment for any sensible person -but you can't even see what you're doing when it's pointed out to you. Now if you guys think you're being mature, helpful, appropriate, or even relevant then you need to re-evaluate what those words actually mean. If anything I posted has gotten you upset in any way, you need to realize that isn't my intent. Again my intent is to share an interesting experiment -not to declare that my toying with cheap LED lights is the end-all of Ninjette lighting solutions. If you two truly wanted to discuss the Pros/Cons and the viability of an LED retrofit then that's what your posts would have been instead of the epeen "I know everything" nonsense and thread-crapping you've been doing. |
#36 |
individual low - high - fogs then low with fogs - high with fogs |
#37 | |
I did just finish rewiring the kit so that both upper emitters (LOW) come on first then all emitters turn on with the high beam switch. One of the interesting things you can do when each emitter only uses half the reflector. No more of that "headlight out" look. I still need to take it out at night in this configuration to see how the light distribution looks. There are plenty of vids on you tube showing the comparable fog output. They're the same 10w cree used in a wide variety of different manufacturer driving light kits *cough*Denali*cough*. Mine have a narrow angle lens in order to provide more throw, rather than flood. They can be had in a variety of beam patterns, none of them being traffic friendly. The solution that most systems use is dimmer switch so that they can be used at all times for conspicuity and full power (usually wired to the high beam) for additional road lighting. |
#39 | |
![]() Calling all trolls! You guys actually troll your own forums as MOTMs, WOW! That's like pooping where you eat. Good for you guys! As I have no actual need to share the info I've been gathering let's just say I'm done posting. No worries though, unlike choneofakind I walk the talk and can keep my word. I'm sure those who are interested in the differences between stock halogens, Morimoto HIDs, and Cree LEDs in the stock reflector housings can figure things out once they've invested the time and money it takes to play around with all three lighting options as I have. This is clearly not the right place to share such information. You may now return to playing amongst yourselves, lol. ![]() |
![]() 0 out of 1 members found this post helpful. |
#40 | |
is this guy serious? don't take the internet so seriously.
2 damaged headlight assys: Cheapest HID projectors? Cheapest salvage/repair options? | CZroe | 2008 - 2012 Ninja 250R Farkles | 12 | May 22nd, 2014 01:40 PM |
HID headlight conversion. | agentbad | General Motorcycling Discussion | 6 | May 21st, 2014 07:13 PM |
