Old March 23rd, 2012, 02:16 PM   #1
andyuc88
Motorcycle(s): 2009 Ninja 250R Pearl White
Rear turn signals don't blink, front turn signals don't turn on
Hi,
I just purchased a 2009 Ninja 250R -- haven't ridden it yet (MSF course this weekend ) but I was testing out the blinkers and they are acting weird.
The rear blinkers aren't blinking while the front blinkers aren't blinking at all. I believe the previous owner replaced the rears with LED's, which I think might be the issue. I know LED's likely need a relay of some sort which the owner may not have installed... but would this affect the front blinkers? I've done some searching on the forums, and it appears the blinker connections are under the seat?
Has anyone run into this before or have any tips on troubleshooting this?
Thanks,
Andy
andyuc88 is offline   Reply With Quote
Old March 23rd, 2012, 02:28 PM   #2
Whiskey
Well if a bulb is blown or there's a loose connection the other bulb on that side will stay illuminated, as will the dash light.
The rear connections are under the rider's seat, the front connections are behind the fairing panels & the wires clamp into the panels
AFAIK it will need a relay to work
Old March 23rd, 2012, 02:45 PM   #3
Originally Posted by andyuc88 View Post
Hi,
Thanks,
Andy
the LEDs dont draw enough current to heat the OEM blinker enoough to trigger it. you need to get a different flasher
Old March 23rd, 2012, 02:47 PM   #4
andyuc88
So there are different relays for the front and the back? Rear being under the passenger seat and the fronts on the left side of the fairing?
I did some research and it looks like this relay will work (Tridon EP34 Flasher)
http://www.amazon.com/Tridon-EP34-Fl...KS/ref=lh_ni_t
Do I need two of these?
Turn Signals Light Up But Don't Blink Proteus 2008 - 2012 Ninja 250R Tech Talk 12 April 6th, 2015 01:00 PM
Blinkers/ Turn Signals don't flash 08GreenNinja 2008 - 2012 Ninja 250R Tech Talk 17 March 6th, 2015 09:23 PM
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
Front/Rear turn signals C L 2008 - 2012 Ninja 250R Tech Talk 4 October 8th, 2011 08:23 AM
07 turn signals, OEM front and rear identical? davidemartindale 1986 - 2007 Ninja 250R Farkles 4 September 16th, 2011 11:56 PM
