Old June 30th, 2009, 01:44 PM   #1
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
Motorcycle(s): 08 250R
Problems running, seems very rich?
Currently my bike has a yoshi full system and a K and N filter. I drilled my main jet out to a 108 and had the needles shimmed a bit. My mixtures were set at 3 turns out. I rode like this for a few hundred miles the only issue was a small hesitation in the mid range (lean I believe because it was worse in the cold) and the idle would fall below 1300 the climb back up (rich).
In a recent service I replaced the coolant, cleaned my air filter, and changed the oil. I also added one more washer to the needles and set the screw at 2 3/4. After this the bike would only idle at 3/4 throttle. After further testing I found it would run better with the fuel line removed until the float bowls were empty. Then it stopped running at all. Both plugs had went out but they weren't fouled. It blows a lot of smoke when running which makes me think it is running rich. I have checked everything I know of on where extra fuel could be getting in and was wondering if anyone had any advice. Thanks
maxedpenny is offline   Reply With Quote
Old June 30th, 2009, 01:58 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
I would just back track, look at the washer install again. Think I would much rather use a different needle than shim. Also, why bother drilling jets when they can be replaced??? I could see drilling them back in the late 80's, as they were pressed in.
Also, just a little fyi. Your mixture screws get there fuel from the pilot jet. If your 3 turns or more out, you need a larger pilot jet. 1 turn or less, smaller
Old June 30th, 2009, 02:04 PM   #3
which K&N filter do you have? the drop in replacement for the stock filter or have you removed the airbox and are running only filters?
how do you know your drilled out mains are accurate? (sorry, I don't understand why people do this instead of spending $10 for the correct jets. )
Old June 30th, 2009, 03:13 PM   #4
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
I found the problem. The washer I had used was a slightly larger diameter than the previous ones I had used. This caused it to get caught on the plastic keeper on the end of the spring. The needle was sitting about a half inch higher than it was supposed to. Once I had the problem I bought a jet kit which will be here in about a week. Thank you for the advice Kelly. That little washer caused me to remove and replace the carbs almost 10 times.
To drill the jets I measured the diameter of the jet with the longer piece on it. (The one that gets removed with a socket.) Then I clamped a a piece of wood in the drill press and drilled a hole in it a few thousandths larger then that stem. Then removed the larger drill bit and put the size that I wanted into the chuck. Then it was perfectly centered in the jet with the jet tightly into the hole in the wood.
Old June 30th, 2009, 03:19 PM   #5
Miles,
Yes, the washers either need to be 3mm metric or #4 SAE. anything bigger will cause interference problems, anything smaller and the needle won't fit through the washer hole.
at least you're an expert in removing he carb tops.
btw, which K&N filter do you have?
Old June 30th, 2009, 03:30 PM   #6
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
Just filters. I think the part number was 9090 or something like that.
Ya I am a expert just hope I will never have to do it again.
Old June 30th, 2009, 03:35 PM   #7
lol.. well, you'll need to at least once more to install the jet kit.
which jet kit?
Old June 30th, 2009, 08:51 PM   #8
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
Dynojet. I am hesitating when/if I should install it. The bike is running great. Im kind of feeling if its not broken don't fix it. Pulls strong all the way to the top. I might get a dyno run just to make sure I am good. I am going to call a few places tomorrow and get some quotes. Does anyone know what a fair price would be for one run with AF?
Running Lean or Rich? need help mkulchar 2008 - 2012 Ninja 250R Tech Talk 105 October 3rd, 2021 01:13 PM
am i running rich? willtrimble 1986 - 2007 Ninja 250R Tech Talk 19 April 18th, 2014 01:20 PM
Running rich, any help? hillbilly86 General Motorcycling Discussion 15 June 5th, 2013 05:32 AM
Running rich? SabreValkyrn 1986 - 2007 Ninja 250R Tech Talk 4 November 15th, 2012 08:36 AM
Bike running rich demp 2008 - 2012 Ninja 250R Tech Talk 49 September 9th, 2010 11:29 AM
