Old June 14th, 2020, 01:19 PM   #1
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Oil Pressure Hose Leaking
So I have the hose on the outside of the crankcase that pulls oil from the crankcase, through the oil pressure sensor, to the cams and it's leaking. I bought a new hose, but am wondering - do I need to drain the oil and replace before I put the new hose on?
Do I need to prime the hose in anyway?
Ive got this weird fear that if I put on a new hose I'll starve the cams of oil on startup because the line will be dry
I've got a manual and it only talks about removing the pressure switch and using silicone sealant on the threads when putting the switch back together, I couldn't find anything about the removal of the actual hose
Old June 14th, 2020, 01:27 PM   #2
I don't know of any reason to do that.
Old June 14th, 2020, 08:01 PM   #3
Just replace crush-washers and you should be fine.
Old June 19th, 2020, 12:51 PM   #4
nocturncal
nocturncal's Avatar
Perfect, thanks!
Unfortunately the hose is leaking from where the metal crimp (? Not sure what to call it) meets the rubber hose.
Waiting on the part. Hopefully it comes in soon
Old June 20th, 2020, 09:45 AM   #5
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Originally Posted by nocturncal View Post
Perfect, thanks!
Oh, by the way, all my orders from the usual suspects (BikeBandit, Revzilla) are taking forever to leave their warehouses. Is this the COVID-effect?
arthury is offline   Reply With Quote
Old June 20th, 2020, 11:16 AM   #6
nocturncal
nocturncal's Avatar
I think so. My prior orders have all arrived later than they normally do.
In the case of my crankcase hose, there is no ETA update per Kawasaki dealer in SF...so I'm just waiting till they are able to aquire a hose. Till then she's just got a slow leak and gotta frequently check my oil level
Old June 20th, 2020, 11:32 AM   #7
arthury
arthury's Avatar
Would eBay (or AMZN) give you a faster delivery date (if they have it), you can cancel your order with SF Dealer?
Leaking oil? JayJay 2008 - 2012 Ninja 250R Tech Talk 8 June 26th, 2015 11:09 AM
New venhill SS hose is leaking at the banjo M42 1986 - 2007 Ninja 250R Tech Talk 11 June 22nd, 2014 01:22 PM
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
radiator hose burst :( leaking coolant h0yitsdom 1986 - 2007 Ninja 250R Tech Talk 11 June 3rd, 2011 11:06 PM
Issue with leaking oil ... no hose on air box ? thsadmin 1986 - 2007 Ninja 250R Tech Talk 10 May 9th, 2009 06:18 PM
