Old July 4th, 2020, 08:24 AM   #1
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Supporting Engine: to install sliders
Hey folks,
I'm intending the install the Black Path Racing sliders onto my 2008 250R. Instructions says to support the engine block when removing engine mounts.
Question: Where do I support the engine at the bottom? The oil filter area or somewhere else? I'm assuming I can use a car pneumatic jack to do the job?
arthury is offline   Reply With Quote
Old July 4th, 2020, 11:09 AM   #2
Emu
Emu's Avatar
Motorcycle(s): 2011 Ninja 250r
Originally Posted by arthury View Post
Hey folks,
I've seen a bunch of videos where people just slide the new mounting bolt in from the opposite side. The factory bolts slide in from the left side of bike with a nut on the right, you can slide the new bolt in from the right side of the bike and put the nut on the left. You do this by literally pushing the factory bolt out with the new one so the motor is always supported.
Also, there are 3 mounting bolts in total, 2 on top and one on the bottom. I assume you are only removing the one closest to the air box on top, if you put a piece of wood down or something thick and soft you can just use a car jack to lift and take the pressure off the bolt.
Hell you could even say yolo and just take the mounting bolts out one at a time, a buddy of mine did that and it worked out fine for him.
Do what you feel comfortable doing with the tools you have.
Emu is offline   Reply With Quote
Old July 4th, 2020, 11:39 AM   #3
I used lift-block on hydraulic jack made from piece of 3/4" thick wood. Drilled 1" hole in centre for oil-filtre bolt.
Old July 4th, 2020, 02:35 PM   #4
arthury
arthury's Avatar
What you both said made sense to me. Thanks for the input.
[motorcycle.com] - MO Wrenching: How To Install Frame Sliders Ninjette Newsbot Motorcycling News 0 July 20th, 2017 03:00 PM
Streetbikes Unlimited Frame Sliders Install????? jboyd12 2008 - 2012 Ninja 250R Tech Talk 3 July 1st, 2012 12:50 PM
Frame sliders - Install Help BenBris 2008 - 2012 Ninja 250R Tech Talk 5 May 23rd, 2012 06:51 PM
Easiest Frame Sliders to Install? ajcadoo 2008 - 2012 Ninja 250R Tech Talk 4 February 22nd, 2012 12:30 AM
Frame sliders install nixthewiz 2008 - 2012 Ninja 250R Tech Talk 1 October 28th, 2011 10:23 AM
