Old July 19th, 2020, 06:42 PM   #1
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Missing a bolt hole?
REF: https://www.partzilla.com/catalog/ka...cowling-lowers
Looking at bolt (part #: 92151) at the bottom of the side cowling, it looks like it is screwed into a screw-hole on the frame?
Mine has broken off. Any solution for this?
arthury is offline   Reply With Quote
Old July 19th, 2020, 07:53 PM   #2
Look closely at hole in frame with bright torche. Can you see through hole? Or is broken bolt stuck in there?
If there's enough sticking out, you can grab it with vice-grips and twist it out?
Then get any 6x1mm bolt to replace. I like to add large washer between bolt and bodywork to press firmly without cutting through bodywork.
Old July 19th, 2020, 09:58 PM   #3
arthury
arthury's Avatar
Oh, I was not clear.
I meant to say that the female of where the bolt was supposed to screw in broke off from the frame, I think.
Based on the diagram, it looks as if the large bolt at the bottom is bolted to the frame.
Old July 20th, 2020, 01:35 AM   #4
Simple enough to braze or weld that bracket back on.
Old July 20th, 2020, 06:53 AM   #5
arthury
arthury's Avatar
Thanks, I'll see what I can do.
Old July 21st, 2020, 10:32 AM   #6
What I would do is get angle bracket. Weld nut to it. Then weld bracket to frame.
Home Depot - angle bracket
As with anything else, measure twice, cut once.
Old July 21st, 2020, 10:39 AM   #7
arthury
arthury's Avatar
Thumbs up
Thanks, Danno./
What size bolt hole is this? Hero Danny 2013 - 2017 Ninja 300 Tech Talk 4 April 29th, 2015 10:01 AM
Rotor bolt hole spacing and pattern. Rassie 2013 - 2017 Ninja 300 Tech Talk 4 August 23rd, 2014 03:33 PM
Missing essential bolt! Need help! Floki 2008 - 2012 Ninja 250R Tech Talk 4 October 6th, 2013 03:08 PM
fairing bolt missing kittyslasher 2008 - 2012 Ninja 250R Tech Talk 3 July 30th, 2013 04:44 PM
Help with missing bolt dk58 2008 - 2012 Ninja 250R Tech Talk 22 May 11th, 2011 07:07 PM
