View Poll Results: How often do you clutchless upshift?
Never 76 32.20%
Rarely 60 25.42%
Sometimes 56 23.73%
Most of the time 26 11.02%
Always 18 7.63%
Voters: 236. You may not vote on this poll
Old September 11th, 2010, 02:51 AM   #41
shaun2891
Motorcycle(s): 09 Ninja 250R
normally for me road riding is always clutch. got some advice today at a track day to go clutchless upshifting and it worked great at the higher revs. worked very well and was very smooth. god i need a bigger track bike though haha :P
shaun2891 is offline   Reply With Quote
Old September 26th, 2010, 09:31 AM   #42
JMcDonald
Motorcycle(s): 2008 250R
Originally Posted by kenji_808 View Post
Basically that's the reason why there is no grinding of gears on a bike because there are no synchromesh gears to grind, the gears just go to the next gear.
You can definitely grind gears on a bike. They use the same engagement mechanism as cars (dogs), but without syncronizers.
I used to clutchless shift, up AND down, all the time. One time I did the entire commute to work with one hand, just to see if I could do it... stopsigns involved squeezing the brake until the engine was JUST about to die, then going again. But, one night when riding around with friends, I missed several gears on upshifts, so now I mostly use the clutch.
However, I still sometimes clutchless upshift when the engine is cold and I am keeping the RPMs low. The loads are small during calm, low-RPM acceleration, and because I have to shift 5 times by the time Im doing like 35mph, I would rather make it a little smoother.
I also clutchless downshift when I am making a turn without a turn lane, and want to use my left hand to signal to traffic behind me (in addition to my blinkers). Well, maybe I do it more than that; I sometimes forget which technique I use at any given time, heh. Downshifts are still very smooth and quite fun. Upshifts under high loads just make me a little nervous now, for my tranny's sake.
JMcDonald is offline   Reply With Quote
Old September 27th, 2010, 02:11 PM   #43
Blackwidow
one of the things my MSF instructure told us was that people tend to get into bad habits about motorcycle riding because they learn from people that posses those bad habits themselves. I would think using clutchless shifting would be a bad habit, if the clutch is there why not use it? It takes a second to pull in the clutch and up/down shift...I always use the clutch and will always continue to use it. but to each their own.
sometimes I aim to please, but mostly I shoot to kill
Blackwidow is offline   Reply With Quote
Old September 27th, 2010, 06:38 PM   #44
Ytse Frobozz
Not dead yet!
Ytse Frobozz's Avatar
When I first got my bike I wouldn't have even entertained the thought of clutchless shifting, but after I read this thread a month or two ago, I decided to give it a shot on the way to work the next day, and I was shocked at how easy it is. I find that for me it's not very smooth going 1st-2nd and sometimes 2nd-3rd. It still seems to pop right in, but I think I need to work on the RPM/throttle position a little bit, as sometimes it's a bit herky-jerky. From 3rd gear on, it seems really easy and smooth, and so I tend to do it more while I'm in the upper gears.
I've downshifted to 3rd-ish with no clutch, and that seems to go pretty well, but that's still a work in progress for me.
I practice every now and then just because it could conceivably come in handy if I'm on a bike and something goes wrong with the clutch, and as sort of a game to see if I can make it shift really smooth that way. The thing it's impressed upon me the most is that when you do use the clutch, you certainly don't need to haul it all the way in every time.
Oh, I almost forgot. This comes in really handy when you need to shift and wave at the same time!
Ytse Frobozz is offline   Reply With Quote
Old September 27th, 2010, 08:03 PM   #45
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
I prefer the clutch unless I'm really getting on it and passing someone or in the case I have a passenger on back. In both cases, clutchless is much smoother. Many of the pros (Lee Parks, for example) recommend clutchless saying it's smoother on the transmission (when done correctly), and less wear and tear on the clutch cable. It's a good skill to be comfortable with in case your clutch cable ever goes out on you mid-ride.
Postwhores are COOL! ~Allyson
Old September 29th, 2010, 10:17 AM   #46
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Shifting clutchless can be fun
Old July 15th, 2011, 09:41 PM   #47
wtfh4xx
Opinionated individual :)
wtfh4xx's Avatar
Motorcycle(s): 2010 Ninjette Special Edition (red/black)
Up-shifting without clutch
Someone on the boards asked about it so I tried it when I was out today.
Seems to me that shifting into 3'rd and above without the clutch is very easy with no lurch when done right. Going into 2'nd from first lurches because of the gearing difference I believe.
For me When I hit 8.4Kish rpms I just pressured the shifter lightly then rolled off throttle and right back on.
Slips right into the next gear and keeps going.
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete
2010 SE 250R!
Miles in the saddle: 1000
wtfh4xx is offline   Reply With Quote
Old July 15th, 2011, 09:59 PM   #48
ducducgooseit
Motorcycle(s): ...
Clutchless up is not that bad on the engine. Clutchless down is
ducducgooseit is offline   Reply With Quote
Old July 15th, 2011, 11:04 PM   #49
Originally Posted by ducducgooseit View Post
Clutchless down is
why do you say that?
Old July 15th, 2011, 11:10 PM   #50
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Use a clutch, save a trany.
You can replace the clutch much easier/cheaper.
It's like people who downshift all the time and let the engine run rpm down.. (stoplights)
Save your engine/gas/trany, use your brake pads, when possible.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old July 15th, 2011, 11:19 PM   #51
jamesio
jamesio's Avatar
Motorcycle(s): None
Shifting/using the cultch is one of my favorite things about riding
'09 Ninja 250R SE
TB Slip-On l Puig DB l Pazzos l Pro-Grips
jamesio is offline   Reply With Quote
Old July 15th, 2011, 11:21 PM   #52
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
clutchless upshifting is for stunts.
Maybe even drag racing..
Cars can shift without the clutch too if you are careful and know how.
LMFAO!
Weaksauce
Old July 15th, 2011, 11:57 PM   #53
i use clutchless ups and down on a regular basis for various uses. fyi one bike has almost 40k miles... the other getting close to 15k.
Old July 16th, 2011, 07:36 AM   #54
Search for "clutchless" on this site, and a bunch of threads come up on this same discussion.
Here's one of 'em.
Old July 16th, 2011, 07:44 AM   #55
ally99
Ninja chick
ally99's Avatar
LOL! Ok, guess it can be used for such. It can also be used correctly to save wear and tear on the tranny and can result in very smooth upshifts, particularly when really getting on the the throttle (ie: when passing someone). So there are practical uses for clutchless too.
Old July 16th, 2011, 12:38 PM   #56
wtfh4xx
wtfh4xx's Avatar
I noticed its best when your really beating on it, for the smoothest shifts that is.
Anyways, yes its fun to shift. I was doing this because someone asked.
Not because I dont like clutching lol.
2010 SE 250R!
Old July 17th, 2011, 10:10 PM   #57
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I'm sorry. Using your clutch is smoother in every way on the ninja250. It shifts much harder than a SS or 600 does. CLUNK! A lot of books tend to generalize things that can vary greatly from bike to bike.
It is nice for predictability when going from first to second in a wheelie though.
You know you'll make it into second if you hold up on that shifter until you jiggle the throttle.
There's no question on which part I'd rather place my load for normal every day use.
A commuter would benefit (IMO) from using their clutch more than their engine for braking and shifting.
I upshift without a clutch when I'm lazy, coming off a hill and can't feel my knees anymore from contorting them into awkward positions while playing with the devil.
"Generally", if there is any question weather or not something is gonna be good to a part not meant to be easily replaceable when it's worn, I'll go with the side of the part that will.
When I'm gonna pass, I also usually downshift to higher RPM and gun it. Upshifting comes after I've passed the mofo. The jetted/poded/piped ninjette will spank somebody in one gear rather quick. Usually the gear lower than I'm cruising in.
LMFAO!
Weaksauce
Old July 17th, 2011, 11:36 PM   #58
i disagree... maybe urnotdoinitrite? i will say it is not as nice as a SS transmission but ... "clunk"? it sounds like something is wrong there.
It is nice for predictability when going from first to second...
i agree.
... in a wheelie though.
... i ... wait what?... you really like wheelies don't you? lol
iif you do it right, yes. if you do it wrong, no.
umm... isn't the engine lubricated and designed to have these forces on it? doesn't the clutch use a friction mechanic that is designed to wear away over time? like brakes?
i clutchless upshift when i'm applying a lot of load. it is much smoother (no pogo) and works better and is quicker than the clutch. (maybe by only 1/16th or 1/32nd of a second) especially on my 600... if i'm WOT and use the clutch it will slip for a quarter second or so (needs replacing)... no clutch, no slip. but the same is true for the 250 just minus the slipping clutch... keep the load on, no pogo.
i'm still not sure what exactly is damaged on a clutchless upshift when done correctly? can you please inform me? maybe can you provide photos of a part that has been damaged due to clutchless upshifts? i'm not talking about a shot tranny due to improper shifting, but rather for example, a transmission run its paces in a race bike operated by someone who knows what they're doing?
unless they're a dick riding a zr1 trying to screw with you...
Old July 17th, 2011, 11:45 PM   #59
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
That's my story and I'm sticking to it!
LMFAO!
Weaksauce
Old July 18th, 2011, 03:46 AM   #60
ally99
Ninja chick
ally99's Avatar
Never apologize for your opinion. We all have our own. Something else to consider is maybe you are doing clutchless incorrectly. When done right, it's about as smooth of an upshift as you could imagine.
Old July 18th, 2011, 04:20 AM   #61
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I do it all the time once I am in the open .But not in traffic .It is fine IF done right.It is like magic. If done wrong is will cause problems. But mostly it just wont shift. The biggest problem is not the trans. If you are going hard and miss a shift with or with out a clutch,The engine could over rev and cause the valves to hit the pistons.
Old July 18th, 2011, 09:15 AM   #62
rockNroll
rockNroll's Avatar
urnotdoinitrite
I approve of this word
I shift w/o clutch often when I'm droning on the interstate, skooched to the right, with my left hand kinda on my hip, or when I'm tryin to give that Civic VTEC in the next lane a beat down
Old July 18th, 2011, 09:30 AM   #63
Jerkson
Motorcycle(s): Blue 2010 Kawasaki Ninja 250r
Careful.... hes got the VTEC yo!
AreaP Quiet Core CF | 8000k HID | FP Jet Kit | Puig db | A&L rearsets | hotbodies undertail | airbox delete + k&n pod filter | Pazzo blue shorty levers | solo seat cowl
Jerkson is offline   Reply With Quote
Old July 18th, 2011, 11:38 AM   #64
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Your image is broken.
Vtec is safe as long as you're not around to get sucked into tue vortex when he hits it.
Old July 18th, 2011, 12:34 PM   #65
Jerkson
Image shows on 2 pc's here oh well.
Old July 18th, 2011, 06:13 PM   #66
i see the image as well
Old July 18th, 2011, 06:15 PM   #67
no image here. you guys must be members of that forum that the pics are from?
Old July 18th, 2011, 06:16 PM   #68
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
LOL
How the hell could you not do it right if your not using the clutch.
C'mon guys..
Let off the gas and up the gear goes if you're holding the shifter up. Slips right in.
Still twice as loud and violent as my GSXR which doesn't even stutter when you do it.
My GSXR is at least twice as smooth on a clutchless upshift.
Ninja is not a super tuned sport bike made for clutchless upshifting.
LMFAO!
Weaksauce
Old July 18th, 2011, 06:18 PM   #69
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
kkim copy paste image link into addy bar
It didn't work here at first.
LMFAO!
Weaksauce
Old July 18th, 2011, 06:20 PM   #70
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Oh, dang, man!
That just might sound catastrophic to the engine completely, ey?
To prevent the even slightest possibility this could happen, it's a good idea to use a clutch.
All I'm saying.. (to the rest of the crowd. You have supported my theory in a way.)
I won't get anywhere with this conversation because neither side can or can't prove it.
Like I said earlier, that's my story and I'm sticking to it.
Put the load on the parts that are made to wear. As a self proclaimed mechanic, that is the advice I would give. That way I can fix it if it breaks. The two things I can't do are engine heads and trany's (yet). Fairly sure I can tackle a clutch tho.
..and V-tech is no match for a GSXR.
I don't race cars anymore. lol.
They were fun while they lasted.
Now all the cars I could actually afford are TOO SLOW. The 250R is faster.
LMFAO!
Weaksauce
Old July 18th, 2011, 07:23 PM   #71
Oh, dang, man!
bring your bike over and i'll prove it
Old July 18th, 2011, 08:47 PM   #72
Boom King
So, where's the reverse?
Boom King's Avatar
I tried this a few times; didn't seem that difficult although I have no idea if my technique was right. Basically applied some light pressure underneath the shifter, rolled off the throttle and the shifter clicked up and then gradually reapplied throttle again. It was cool for about 5 seconds just to try it out . I just don't have any real reason to not use the clutch.
Old July 19th, 2011, 03:57 AM   #73
ally99
Ninja chick
ally99's Avatar
You would know if it wasn't right, so if it felt smooth, it was probably ok.
My bike must be pretty darn "tuned" because its clutchless upshift is very smooth, easy, and quite fun!
I won't add to the argument because there is no "right" way. I will say this, however, it's really good to know and be comfortable with clutchless shifting in case your clutch cable ever breaks while you're riding. Otherwise, there is no right or wrong way to shift, clutch or not, but there is a faster, more fun way!
Old July 19th, 2011, 09:45 AM   #74
there may not specifically be a "right way" but there is definitely a "wrong way"
as to your bike being tuned... i'd say it's more likely your right wrist being tuned.
Old July 19th, 2011, 10:04 AM   #75
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
So.... What about clutchless down shifting? I've gotten pretty darn good at it and honestly it makes riding easier if I need to drop a gear really fast for something
----> My Youtube! <----
Old July 19th, 2011, 11:33 AM   #76
its a very handy tool in my opinion... i'm a firm believer that when done right can be very smooth as well. i know a lot of people think its bad... i don't know. if it's that smooth i can't see how it could be bad... maybe they suffer from Urnodoinitriteitus?
Old July 19th, 2011, 11:53 AM   #77
Put the wear/damage issue of to the side for the moment. The reason that people don't recommend clutchless downshifting it that it's somewhat pointless. When you're downshifting, you are making the engine go faster for a given road speed. If you do it instantaneously without clutching in and out, the moments it takes to get the engine up to speed cause the rear wheel to lose traction, even if for a moment.
So if you're planning to downshift without the clutch because of braking hard and want it to happen quickly, that's a terrible time to intentionally cause the rear to break traction. Watch how smooth people are when coming into corners on track with the clutch hand, very slowly letting it out to allow the rear wheel to exactly match the engine speed without ever breaking traction.
But if you're going slowly enough and just experimenting in a straight line while not at the traction limits, sure, it can be done, but with zero performance benefit, and a greater risk of futzing up your shift forks as it's harder on the drivetrain to have the engine accelerated by the rear wheel than it is for it to decelerate naturally on upshifts.
Old July 19th, 2011, 12:03 PM   #78
i absolutely agree when trying to go fast... or rather slow down fast. but when i'm just putting around on the street and casually slowing down for a turn or whatever where someone else has to yield to me, on my fzr the revs are usually around 3kish... it doesn't seem like its nearly enough to lose the rear... if i do it right it feels very smooth... do you think its still doing damage? it definitely doesn't give any performance benefit but i personally found that noone seems to ever see my signals when i use them... i have to go through a few intersections frequently where cars going 'straight' for them have to yield to the other flow of traffic and when i used signals i would get cut-off fairly frequently... it seems to me like i noticed (although it may just be me overthinking it and nothing is actually changed) people respond much more accordingly to my hand signals... so if i'm using hand signals and need to get another down shift in, clutchless is very handy to me. what do you think? i'm probably overthinking it... maybe?
Old July 19th, 2011, 12:45 PM   #79
Clutchless downshifting isn't recommended. I wouldn't make it a habit.
Old July 19th, 2011, 12:58 PM   #80
Xoulrath
Xoulrath's Avatar
Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X)
I haven't bothered to cluchless upshift the ZX yet. It's fast enough that I don't need to worry about losing a 1/4 of a second when shifting. The 250, on the other hand, I made it a habit to clutchless upshift. It was noticeably quicker, since it was putting down the power faster, and it was smoother than using the clutch.
R.I.P EthioKnight (Alex)
Xoulrath is offline   Reply With Quote
[sportrider - riding] - Riding Skills Series: Sport Bike Clutchless Upshifting Ninjette Newsbot Motorcycling News 0 April 13th, 2010 04:00 AM
[sportrider - riding] - Riding Skills Series: Sport Bike Clutchless Upshifting Ninjette Newsbot Motorcycling News 0 March 29th, 2010 11:40 PM
[sportrider - riding] - Riding Skills Series: Sport Bike Clutchless Upshifting Ninjette Newsbot Motorcycling News 0 January 26th, 2010 08:10 PM
Clutchless Upshifting & Lee Parks LazinCajun Riding Skills 8 September 9th, 2009 09:34 PM
[sportrider - riding] - Riding Skills Series - Clutchless Upshifting Ninjette Newsbot Motorcycling News 0 January 16th, 2009 01:31 PM
