Old April 15th, 2014, 12:02 PM   #1
Akane
Motorcycle(s): 2010 ninja 250r
airbox realignment problems after carb removal
Hi guys, I took my carbs out to see if they needed to be cleaned and went through the steps in taking it out (removed the battery, battery box and pushed the airbox back. I'm installing everything and ran into a small problem. I am having the hardest time getting the airbox to line up with the bracket that sits above it (the bracket the gas tank bolts to) I have pushed and pulled it to the front of the bike as hard as I could and cant get it to budge anymore. The way its sitting now it wont line up correctly and its blocking the lid that goes on top of the battery. I've included a pic of whats not wanting to line up. I'm sure its something easy that I've overlooked but I cant figure it out.
Akane is offline   Reply With Quote
Old April 15th, 2014, 12:28 PM   #2
cuong-nutz
cuong-nutz's Avatar
You have to make sure that the carb is seated properly into the boots on the engine cylinder head and the boots on the airbox. If they are not seated, than they will hold you up from doing so. Also, there's an oil drain tube from the crankcase hosing under the airbox that attaches to the left lower section of the airbox.
HalfFast Racing Team
Old April 15th, 2014, 01:04 PM   #3
Akane
Thanks for the reply, I got the issue solved.
Airbox to Carb Connection Ralgha 2008 - 2012 Ninja 250R Tech Talk 5 September 15th, 2014 06:38 PM
Post airbox removal questions htsang07 2008 - 2012 Ninja 250R Tech Talk 16 May 23rd, 2013 06:33 AM
Airbox removal and jetting + other questions kamikaze 2008 - 2012 Ninja 250R Tech Talk 3 February 18th, 2012 08:04 PM
Airbox removal + Kleen air removal? MikeBudd 2008 - 2012 Ninja 250R Tech Talk 6 February 16th, 2012 04:57 PM
Quick Airbox removal question forevertwowheels 2008 - 2012 Ninja 250R Tech Talk 11 June 14th, 2011 04:31 PM
