Old April 21st, 2012, 09:25 PM   #1
Avenged7Fold
Ninjette Noob
Avenged7Fold's Avatar
Motorcycle(s): 2004 YZF-600r ---- 2006 Kawasaki Ninja 250r
Buzzing Noise on Ignition
Everytime I push the ignition switch in to start the bike, all I hear is a buzzing sound from somewhere around the fuse box. It was working fine earlier, since then I flushed the cooling system with water and replaced with new 50/50 coolant, and washed it. To wash it I removed all the fairings, and sprayed a little bit on the bike aswell. Maybe I reconnected the turn signals wrong? Maybe I sprayed something electrical? Or possibly the battery is dead? Any help please?
Avenged7Fold is offline   Reply With Quote
Old April 21st, 2012, 09:38 PM   #2
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
Battery's dead or terminals are loose.
kevlar250 is offline   Reply With Quote
Old April 21st, 2012, 09:39 PM   #3
Jono
Jono's Avatar
You probably sprayed water in a place where water should not go. Why did you take off the fairings to wash the bike? They are there to protect the electrical stuff behind them from water and such.
Try jump starting it. That will determine if the battery is dead or not.
Check all the fuses.
It isn't the turn signals.
Old April 21st, 2012, 09:40 PM   #4
Avenged7Fold
Ninjette Noob
I tried to move the terminal wires from the batterys terminals and they can't move so I assume that means they're not loose. Should I just buy a new battery? It was literally just working a few hours ago.
Old April 21st, 2012, 09:44 PM   #5
Avenged7Fold
Ninjette Noob
I took them off to clean the cooling system, and decided to just wash them while they were off. Then I sprayed down the back fairing (wasn't removed) and the front light. Can I just start it with my car using the same wires, or what?
Old April 21st, 2012, 09:55 PM   #6
Jono
Jono's Avatar
Yeah. Just make sure the car is NOT running.
Old April 22nd, 2012, 12:12 AM   #7
Avenged7Fold
Ninjette Noob
So I jump started the bike and rode around for about 10 minutes, it'll start again but will die eventually. Seems like everything is good, right? Just need to either ride long enough for the battery to get a good charge or get a new one.. correct?
Old April 22nd, 2012, 12:37 AM   #8
bikez gunna esplode!!!
Old April 22nd, 2012, 06:31 AM   #9
greg737
Motorcycle(s): -
The only electrical component on the EX-250 that can make a "buzzing" sound is the main relay, which is just to the left of the fuse box (as you face the right-hand side of the bike).
A relay will make a sizzling/buzzing sound when it's not getting proper voltage (either poor grounding or lack of power). It has a spring-loaded disconnect inside it and that allows its internals to vibrate if the voltage isnt high enough in the relay's control circuit.
But I'm not saying the relay itself is the problem, it is just reacting to improper voltage (either a grounding problem or voltage input problem) which could easily be caused by water in the fusebox.
Old April 22nd, 2012, 01:25 PM   #10
Avenged7Fold
Ninjette Noob
But if it starts by jumping it, and then it starts for a couple times after that... but then needs jumped again later.. doesn't that mean the fuse is okay and the battery is just dead?
Old April 22nd, 2012, 01:31 PM   #11
greg737
Motorcycle(s): -
yeah, like I said, the buzzing of the relay is probably just a symptom of some other problem with either voltage or grounding. Yes, it could be the battery. Does it always make the buzzing noise? Does it buzz when the jumper cables are hooked up to a good battery?
Old April 22nd, 2012, 01:33 PM   #12
Avenged7Fold
Ninjette Noob
When the jumper cables are hooked to the battery, it starts as normal. Otherwise it does make the buzzing.
Old April 22nd, 2012, 05:24 PM   #13
greg737
Motorcycle(s): -
do you have a multi-meter available to check the battery voltage? You should do that.
also, you should check the bike's main ground to make sure it's secure. It's a small bolt on the back of the right-hand side of the engine (start from the oil sight glass and go up the engine a bit and you'll be looking at it, or follow the battery's negative lead down to the main ground bolt). If the main ground is loose or corroded you should correct that.
Old April 29th, 2012, 12:55 PM   #14
Avenged7Fold
Ninjette Noob
Jumped the battery and rode it for an hour, no problems since. Thought it'd post it up now in case anyone is having the same problem.
Old October 5th, 2012, 02:21 PM   #15
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
my battery shoes 13v with multimeter from a friend
The King
rabies is offline   Reply With Quote
Buzzing noise at lower rpms? kamikaze 2008 - 2012 Ninja 250R Tech Talk 17 June 30th, 2015 06:36 AM
Fuse removal and buzzing Jiggles 2013 - 2017 Ninja 300 Tech Talk 13 April 3rd, 2013 09:38 PM
flasher relay buzzing? rawbert625 2008 - 2012 Ninja 250R Tech Talk 9 July 17th, 2012 12:21 AM
Hearing loss and buzzing with earplugs!? what to do? 5evenz General Motorcycling Discussion 13 October 29th, 2011 10:38 AM
Electrical buzzing noise when riding cjkirch 2008 - 2012 Ninja 250R Tech Talk 9 March 24th, 2009 03:19 PM
